Project-Scuderia | Page 27 | FerrariChat
Project-Scuderia
Discussion in '360/430' started by RBM, Nov 7, 2011.
  1. 24000rpm
    24000rpm F1 Rookie
    when you say "new system", do you mean ferrari update it in its later production cycle?
  2. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    I was referring to the windshield washers I am installing in the new hood.
  3. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    I replicated the design used in the Porsche 928 windshield washer system. The continuous loop equalizes the pump pressure across the nozzles. The T-valves to the nozzles have integrated 1-way check valves.
  4. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,007
    Cape Town South Afri
    Dave
    I Should have read the whole thread , apologies .
    Great job on the links
  5. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    The next step is one of the most delicate parts of the hood install. The OEM washer nozzles snap into very small, very precisely sized rectangular holes. Too small and they won't fit. Too large and they won't lock in. The composite hood did have the raised areas where the nozzles go, but no holes were cut.
    Bas likes this.
  6. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    43,212
    ESP
    Bas
    Loving this thread, Scuderia is aging rather well I think...
  7. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    I masked the areas on the raised locations of the hood and drew templates for the cutouts. Using a fine cutting wheel on the Dremel, I cut two rectangular holes in the hood.
  8. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    The finished holes on the reliefed portions of the hood for the washer nozzles. This is the right (passenger) side. Position and orientation of the holes are important to ensure the nozzles have 'line of sight' to the windshield, as they are well under the edge of the hood. The individual nozzles are movable, so the jets can be fine-tuned once installed.
  9. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
  10. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Installing the hoses and nozzles. You have to run the hoses first from the inside out, and then connect the nozzles before installing them from the outside in.
  11. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
  12. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
  13. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
  14. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    The continuous loop configuration uses more hose than the OEM system, and so requires more attachment points to hold the hoses in place. Small holes around the outside edges of the vents, and small zip ties through the holes and around the hose (not over-tightened), provide a simple solution.
  15. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
  16. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
  17. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,147
    Josh @jtcarprojects
    Perfection
    ZF123 likes this.
  18. Audipwr1
    Audipwr1 Karting
    Apr 6, 2017
    110
    curious of your ultimate plan here - lots of "no going back" changes happening
  19. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    singletrack likes this.
  20. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    The complete answer to your question can be found in the first 600 or so posts of this thread. The short answer I usually give at cars & Coffee is, "a Scud is 99% racecar and 1% Italian.... I'm fixing the 1% Italian." If you review the thread closely, you will see that 100% of the changes are bolt-on. The car can go back to being 100% stock, which I have demonstrated on multiple occasions.
    armedferret likes this.
  21. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
  22. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    RANDY6005 likes this.
  23. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
  24. 24000rpm
    24000rpm F1 Rookie
    why you prefer this tool to a screw-driver styled tool , or a ratchet styled tool? I've never used such a tool, nor do I like it. Just saying.
  25. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
