QA 1 for 308 | Page 3 | FerrariChat
QA 1 for 308
Discussion in '308/328' started by etip, May 25, 2013.
  1. Verell
    Verell F1 Veteran Consultant Owner
    May 5, 2001
    7,025
    Groton, MA
    Verell Boaen
    DavidB,
    Thanks for the update on DS602s. I"ve updated the white paper with your experience.
    re: 'topping out'
    From this Fchat thread which is referenced in the white paper:
    http://www.ferrarichat.com/forum/308-328/157432-qa-1s-gt4-slightly-worried.html
  2. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    Simple: Go over a medium-sized bump at some speed, springs compress, as they should, and then decompress, followed by a loud thumb coming from the rear (and sometimes even the feeling that the wheels would come off the ground).
    Putting a 1" extension on solved this immediately, never to be felt again.
    The thing is simple, really - without the extension, the piston inside the shock isn't positioned halfway the shock, but is rather higher up. So the shock could compress quite some distance from its resting position, but hardly decompress at all without coming to the end of its travel. Putting the extension on, the car sits equally high, the springs do the exact same, but the piston is merely pushed in one inch further, placing it nicely in the center of its possible travel.
    I haven't cross-checked with the new QA-1 numbering, but at the time, the next size up would have been too long, placing the piston too low inside the shock, risking bottoming out. The 1" extensions on said shocks was the sweet spot.
    The extensions cost a few $ only and are very simple to assemble, so this is really a no-brainer.
    GT4 ONLY!!! The GTB/GTS are fine without them.
  3. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
  4. DavidB_SD
    DavidB_SD Karting
    Sep 7, 2008
    65
    San Diego, CA
    David B
    Hans and Verell,
    Thanks for the clarification. I understand the issue now.
    -David
  5. Verell
    May 5, 2001
    7,025
    Groton, MA
    Verell Boaen
  6. DavidB_SD
    DavidB_SD Karting
    Sep 7, 2008
    65
    San Diego, CA
    David B
    Verell,
    I went with a 14" 300 lb. Eibach rear spring. Measuring from the spots you jack the car up from (about the lowest points on the car I think and a good place to take a reference) I have ~4.5" of ground clearance in the rear and ~4.25" in the front. This is running 225/50/16 rear tires with good tread left.
    The rear coils are just about maxed out in terms of how low you can make them (from memory here, there might have been 1/4" or less left).
    I'll see if I can get a good measurement this weekend of the height of the spring while wheels are off the ground. I remember going back and forth between the 12" and 14" before I bought them and what worried me about the 12" was that it might have needed a helper/tender spring at full droop.
    -David
  7. Verell
    May 5, 2001
    7,025
    Groton, MA
    Verell Boaen
    Thanks!! I've quoted you in the QA1 white paper.
  8. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Reviving an old thread, considering a QA-1 setup for my 87 328 GTB. Do the 308 QA-1 part numbers correspond to my early 328? One thing I really want to avoid is having to notch my front a-arm. What's this about Verell's paperweights? They allow an offset shock mounting to preclude any a-arm modification? The comments I found on it seemed to indicate they're actual paperweights, so can somebody please clarify?
    Thanks,
    Greg
    Edit- just went to unobtanium supply and saw the paperweights and bushings, very cool! Now I just need to know if my early 328 uses the same shocks as a 308. I would imagine so.
    Sent from my LG-H901 using Tapatalk
  9. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    The paperweights are not actual paperweights, but modifications for the shock ends to clear the A-Arms
  10. 455Fosbery
    455Fosbery Karting
    Oct 3, 2013
    212
    You may want to have a look at this thread (Post 46)
    http://www.ferrarichat.com/forum/308-328-sponsored-yellow-compass-group/504766-front-nose-high-stance-will-new-springs-cure-3.html
  11. airdelroy
    airdelroy Formula Junior
    May 10, 2007
    420
    Austin, TX
    Aaron Richardson
    The part numbers are NOT the same between the 308 and 328 for the front shocks. I believe the part numbers for everything else though is the same (ie: same part numbers for rear shocks, front springs, and rear springs).
    I have a set of front shocks that still havent made it to ebay sitting in my garage that will fit a 328. ;)
    thanks,
    Aaron
  12. Verell
    May 5, 2001
    7,025
    Groton, MA
    Verell Boaen
    The early ( ie: non ABS 328s use the same front QA1s as the 308).
    I've written a white paper to help people considering changing to QA1s to help answer questions like this. The latest version will always be downloadable from the SUPPORT page on Unobtainium's web site:
    Unobtainium Supply—SUPPORT
  13. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Thanks Verell, I'll check that out. How about the rears?
  14. Verell
    May 5, 2001
    7,025
    Groton, MA
    Verell Boaen
    See the white paper.
  15. PenP
    PenP Formula Junior Rossa Subscribed
    Jun 20, 2006
    669
    Los Angeles
    Pen Pendleton
    The white paper on the Unobtainium Supply Co website has everything you need to know, to do the QA1 conversion, including the very important GT4 anomaly (uses a longer rear shock than GTB/S). This community is so fortunate to have people like Verell and Birdman who give back so much to us – and have been doing so for quite a while, with their enthusiasm and dedication never seeming to wane.
