Question About Speed Sensor Removal | FerrariChat
Discussion in '308/328' started by Lawrence Coppari, Nov 11, 2020.
  1. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,194
    Kingsport, TN
    Lawrence A. Coppari
    For the repair, Palo Alto speedometer shop wants my speed sensor shipped to them along with my speedometer.
    The sensor is below the fluid fill point of the transaxle. It also has a CU sealing washer. Does that mean my Redline MTL will exit the transaxle when I remove the sensor?
  2. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,767
    Argent/Brasil
    Guido
    No, just a few drop...
  3. Lawrence Coppari
    Apr 29, 2002
    2,194
    Kingsport, TN
    Lawrence A. Coppari
  4. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,558
    NY/SC
    David
    LMK if you need a new sensor; when my speedo function was acting up (see reply to your other thread on this matter; it was not the sensor) I bought a new one and that wasn't the problem. So I believe I still have the new unit if you need one and want to save a few skins over another new one.
  5. craiggo
    craiggo Formula Junior
    418
    Redwood City
    Craig
    Before you send it all the way out here for repair, try this: https://www.ferrarichat.com/forum/threads/cheap-repair-of-a-speed-sensor-type-2-vegilia-68-0517.529168/#post-144843186
  6. Lawrence Coppari
    Apr 29, 2002
    2,194
    Kingsport, TN
    Lawrence A. Coppari
    Excellent work. My sensor was putting out a signal so I think it is OK. If it were not doing so, I'd make an attempt at fixing it myself. I have a little experience in ferreting out bad transistors with audio equipment.
