Question on CS | FerrariChat
Question on CS
Discussion in '360/430' started by wazza, Jan 23, 2004.
  1. wazza
    wazza Formula Junior
    Oct 9, 2003
    614
    Any Idea what this litle thing is for?
    I'm hoping that it's some where to attatch a DAS/Datalogger
    But I doubt it.
    It's located in the fuse box under the lefthand side of the hood on my
    Stradale.
    The next pic should show the position a bit clearer.
    Wazza
  3. wazza
    Oct 9, 2003
    614
    Hopefully this shows the location a bit clearer.
    Many thanks In advance Guys
    Wazza
  4. wazza
    Oct 9, 2003
    614
    Come on Guys.
    Can anybody help?
    It's to plug something in.
    But what ?
    thanks
    Wazza
  5. Hubert
    Hubert F1 Rookie
    Jan 3, 2002
    2,642
    The Left Coast
    probably a diagnostic pinout
  6. wazza
    Oct 9, 2003
    614
    But I thought the SD2/Diagnostic pinout is under the driver/passenger footwell ?
    Seems strange to have two?
    Wazza
  8. Brian C. Stradale
    Brian C. Stradale F1 Rookie
    Mar 17, 2002
    3,603
    Dallas, TX, USA
    Well since nobody seems to know... I'll volunteer a SWAG or two... for a CD Changer? Or for a Trickle Charger?
  9. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    Yep, I agree with Brian. It's not any diagnostics. I think CD or luggage lamp, or some minor accessory.
  10. thomas_b
    thomas_b Formula Junior
    Sep 15, 2003
    765
    all nice and tidy in my car (see picture)
    only connector I can see in the wiring harness diagram that dangles around is called "Joint Pre-Set For Daytime Lights On Canada Version" – if this is the connector (three contacts): in Canada lights have to be always on and I assume that this is controlled by the connector
  11. wazza
    Oct 9, 2003
    614
    Thanks Guys
    I think we're getting close here.
    It's definately not the trickle charger as thats under a screw down box on the otherside Near the battery cut out switch.
    And the luggage lamp is already fitted.
    My guess it's going to be the CD changer which I didin't bother going for.
    Thanks Alot
    Wazza
  13. wazza
    Oct 9, 2003
    614
    Actually Thomas
    You Maybe right it might be the Canadian Daytime light connection.
    It's certainly 3 Pin.
    Anyway. It looks like it's going to be no use to me.
    I was hopping for somewhere to plug a datalogger .
    I guess it was never going to be that simple.
    I've just ordered an upgrade of the DL90 it's a DL1 and should be coming towards the end of Feb.
    Wazza
  14. Brian C. Stradale
    Mar 17, 2002
    3,603
    Dallas, TX, USA
    Doesn't it just use the OBDII connector? I believe you can access that under the dash... in any case, it MUST be accessible somewhere.
    DL1?? Hmmm... gotta go check that out... (I'm still trying to figure out what datalogger to install.)
  15. wazza
    Oct 9, 2003
    614
    Sorry "OBDII connector" ?
    Is that where they attatch the SD2 to check the ECU.
    Yes it's is under the dash.
    But excuse my ignorance but I didn't realize you could attatch any datalogger to it.
    I was originally going go the DL90 just becuase you could plug it straight into the 12v/cigarlighter jack at least until I got used to using it. Plus I didn't to have to hard wire in something new at this stage.
    (I think i'm being a bit over causious with a new car).
    But when I went to order it they told me this new product was coming out in Feb. which would send the data to an in-car mini DV recorder.
    Although this system was orginally suposed to be for my race car (Formula Vee).
    I think I can easily swap them around.
    Check out the web sites ( I have no afilliation)
    http://www.drivedata.com/index2.html
    or
    http://www.race-technology.com/WebPage/FlashIntro.html
    Wazza
  16. Brian C. Stradale
    Mar 17, 2002
    3,603
    Dallas, TX, USA
    Yes, OBDII gives you a standard connector and a standard "minimum" protocol that must be provided... anybody can build a device to use that protocol. On top of that, manufacturers can add whatever additional information they want for their own diagnostic tools... and most generic tools won't be able to use any of that... but given all new cars have OBDII, most generic dataloggers are supporting that as an input.
  17. wazza
    Oct 9, 2003
    614
    Wow.
    Now that should be a big help.
    I should not need to buy any additional sensors as I expect the car already has them fitted.
    So by plugging in my data logger a can just pick up all that info and transfer it on to my PC as long as I have the software to make sense of it all.
    And as the system works off GPS rather than a static beacon I can just plug and go.
    This all sounds to easy.
    Wazza
  18. Brian C. Stradale
    Mar 17, 2002
    3,603
    Dallas, TX, USA
    Sweeeet!!! Its my dream data logger, I think!
    And it does have the OBDII connection option.
    They have new info coming out first week of Feb
    and then the unit that I want will be shipping in
    March... just in time for my car, perhaps!
    Damned expensive, though.
    Thanks for pointing it out!
  19. thomas_b
    Sep 15, 2003
    765
    but make sure that the OBDII connection works with the 360 - make them commit that they fix incompatibilities
    there is a thread about the OBDII error codes and Scanners that work on the other F forum
    furthermore plan on have the connector relocated - it is in a very stupid position
