Quick Blinking Turn Signal | FerrariChat
Discussion in 'Boxers/TR/M' started by jim94-348, Nov 5, 2015.
  1. jim94-348
    jim94-348 Formula Junior
    Aug 19, 2010
    981
    Greenville, NC
    Jim
    I have a weird quick flash of my turn signals when they are on. I know this is usually cause by a bad bulb but I just got back from the Hilton Head Concour where I showed the car and all bulbs were checked and they all work. Has anyone had this problem and if so how did you fix it?
  2. Steve Magnusson
    26,571
    When selecting either direction, or is one direction normal and the other direction fast?
    Do the hazard lights flash more normally?
  3. jim94-348
    Aug 19, 2010
    981
    Greenville, NC
    Jim
    I need to check the hazards but it seems they were correct. I'll check today. The quick blinking on the turn signals is for a left or right turns and none of the bulbs are LED. I assume that someone would ask that.
  4. blown daytona
    blown daytona Formula 3
    Feb 6, 2008
    1,679
    maryland
    If on both sides, a bad flasher?
  5. jim94-348
    Aug 19, 2010
    981
    Greenville, NC
    Jim
    I'm not following you on this? If it were a bad flasher wouldn't it be tied to the left or right side that the flasher is on?
  6. blown daytona
    Feb 6, 2008
    1,679
    maryland
    Just going from general knowledge of simple non computerized car electrics, every car I ever worked on has one flasher which works both left and right sides. A Ferrari should be no different....but I know better to say that I am never wrong :)
  7. Steve Magnusson
    26,571
    No, the same (single-path) flasher (and the +12V power plus much of the upstream wiring and connections) is used by both sides and the hazard function as BD indicated. If one direction was OK, but the other direction was fast = I'd first suspect a poor contact inside the turn signal switch for that direction. If both directions are bad = could be the flasher, but could also be a bad shared upstream connection. If the hazard flashing is also bad/fast = that would be more evidence against the flasher (but not necessarily completely conclusive).
  8. jim94-348
    Aug 19, 2010
    981
    Greenville, NC
    Jim
    I just checked and the hazards flash at the same quick rate. Any ideas?
  9. jim94-348
    Aug 19, 2010
    981
    Greenville, NC
    Jim
    I've got the wiring diagrams and I can begin searching that but do you know where the flasher is physically located? If it is fairly standard I can get a new one or at least check for corrosion and make sure it is physically seated properly. Any other suggestions?
  10. Steve Magnusson
    26,571
    It's mounted behind the fuse-relay panel -- see the figure from Tim in post #2 here:
    http://www.ferrarichat.com/forum/boxers-tr-m/487507-hazard-turn-relay.html
    It's not a typical older autoparts store 60s-70s "generic", and I can't recall anyone posting a replacement, so please let us know if you do find an equivalent (but like your plan to give it a look/wiggle/reseat first).
  11. jim94-348
    Aug 19, 2010
    981
    Greenville, NC
    Jim
    As a final update, I replaced the flasher relay and it corrected the problem. It's odd that the old flasher worked but was just too fast. Oh well, at least it is fixed for Cavallino
