Radar detector options Pista | FerrariChat
Discussion in '458 Italia/488/F8' started by Nsd991, Feb 28, 2023.
  1. Nsd991
    Nsd991 Formula Junior
    Jul 19, 2012
    538
    Given the location of the cigarette lighter port and the battery concerns with the Pista what are good options for using a radar detector? Having the cord reach across the central tunnel between the two seats is not optimal. Any experience with wire tapping directly into the rear view mirror? I’ve done that with some other cars and then used a blendmount. Wanted to ask as I don’t want to risk an issue with Ferrari electronics. I don’t want a built in system as I don’t want the car dismantled. Thanks in advance for any replies.
  2. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Fort Lauderdale, Florida
    Todd
    the best has always been and probably always will be the K40 hard wired radar that they install clean and the indicator is built into your rear view mirror
    mdrums likes this.
  3. Thecadster
    Thecadster F1 Veteran
    7,547
    I use a Uniden R7 in mine and I have it tapped to the mirror. I had my Ferrari shop perform the install, so no worries there. There’s not a Blendmount option for the Pista. At least, not one that I have found.
    Nsd991 likes this.
  4. Nsd991
    Jul 19, 2012
    538
    yes I’ll probably have Ferrari mirror tap. I’m cheap and know it takes 2 minutes, BUT I also know how finicky Ferrari electronics can be so I don’t want to give them an excuse in case I have future issues. I did look on the blendmount website hoping that one existed for the 488 GTB as I’m sure it’s the same mirror. Unfortunately no such luck.
  5. rw99
    rw99 Karting
    Jan 1, 2019
    127
    SF Bay Area
    Rich
    Thecadster and Nsd991 like this.
  6. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,231
    Tampa FL
    Yep…my 488 came with K40 installed. It works very good
  7. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,632
    SF Bay Area, CA
    Ruben
    I use a Valentine V1 Gen 2 in my Speciale and place it right just to the right of the rear view mirror, routing the flat wire under the pass sun visor and into the rubber moulding around the door opening (easily bent back to hide the wire) towards behind the pass seat where I can then dangle it behind the pass seat to plug it in.
    Super easy, virtually invisible, no hacking up of any electrical system, and easily transferable to other cars (I do this same method on my 308, 412, and 550 as well).
  8. Lucid moment
    Lucid moment Karting
    Sep 24, 2017
    58
    Just tap into the mirror/dome, and use a blend mount. I use an escort redline.
  9. Nsd991
    Jul 19, 2012
    538
    Thanks lucid. I have the trim piece removal tools etc. I’ve done this before in other cars. Was it easy to pop trim loose? I’m still not brave enough to do this on a Ferrari.
  10. Lucid moment
    Sep 24, 2017
    58
    Yes very easy, small U shape trim piece will pop off, then there are 2 bolts that need to be loosened and the dome light assembly will come off. See photo below once trip piece has been removed.
    Nsd991 likes this.
  11. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,723
    Just East of Weird
    Bob
    Nsd991 likes this.
  12. Nsd991
    Jul 19, 2012
    538
    I have the Redline 360 (normal version) and it’s the best radar I’ve ever had. It really filters out all the false alerts. I don’t want car taken apart for a concealed install.
  13. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    I mentioned in a other thread but wasn’t really the topic…. Has anyone tried installing (suctioning) a detector to the rear window instead of the windshield? Like right behind your head facing out the front as normal? Does it still pick up the signal as well? Only a few feet backwards from windshield. This would make a clean plug in to the lighter socket — just a thought. Anyone done it?
  14. Nsd991
    Jul 19, 2012
    538
    Not sure how the suction mount would work and also you would not be able to see what band the detector was alerting or the direction of the signal. It will also likely hinder your rear visibility to some degree..
  15. Bob in Texas
    Apr 23, 2012
    2,723
    Just East of Weird
    Bob
    Yes, my radar detector was mounted on the rear glass, successfully! Been doing it for years on my Porsche's and now my Ferrari's. This radar trick is for the Valentine 1 Gen 2 with remote display.
    I was using a suction cup mount on the rear glass before I figured out a small mod that makes a huge difference, ascetic-wise.
    This is on a 458 with the Bose speakers mounted to the rear bulkhead. I used an "L": shaped piece of plastic and slipped it down behind the speaker enclosure. The V1 is velcroed to the L-plastic. The cable was run to the cigarette lighter where I tapped in to the switched power lead using a vampire clip. Then the cable went to the remote display at the front of the console.
    Detection is the same front and back, no degradation that I could detect side by side with a car with a windshield mounted unit.
    05F430F1 likes this.
  16. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    That’s exactly what I was imagining… excellent— and plus the sound alert will be right next to your head which is perfect also. Thanks.
  17. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    Can’t see out the back window of an F8 anyway so …. Lol [emoji38]
  18. Bob in Texas
    Apr 23, 2012
    2,723
    Just East of Weird
    Bob
    Here’s one more with the suction cup mount on my previous 430. Just to the left of the passenger seat. Sorry for the poor photo quality…
    Sent from my iPad using Tapatalk Pro
  19. Dazed2day
    Dazed2day Karting
    Jun 9, 2021
    129
    Fred
    I mounted my V1 to the rear window as well. Bought a flat mount and used two sided tape… I like it there because it’s less visible to cops or anyone else.
  20. ferrefeh
    ferrefeh Karting
    163
    Illinois
    Feh H
    Just did my V1Gen2 hardwire using the leads above in a 2018 488 Spider, and worked perfectly. Thanks for this.
    For clarity, this lead does provide switched 12V power, comes on in accessory mode and shuts off with the car's ignition.
  21. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    And where/how did you mount the actual detector? Front windshield next to the mirror?
  22. ferrefeh
    ferrefeh Karting
    163
    Illinois
    Feh H
    so basically I put it left of the mirror and tied up to the stalk for strain relief. Just using suction cup mount for now until I can find if there’s a blend mount option.
  23. Lucid moment
    Sep 24, 2017
    58
    There is a Blendmount option, I used one. Let me see if I can find part #.
