Radio Code Card | Page 3 | FerrariChat
Radio Code Card
Discussion in '360/430' started by jlonmark, Jul 30, 2012.
  1. vrsurgeon
    vrsurgeon F1 World Champ
    16,488
    Charleston, SC
    Curt
    Sweet! That's the code my program spit out! Then the calculator I have works! :)
  2. little_daz
    little_daz Karting
    Jul 28, 2012
    176
    Ahh right, so it was the code I supplied to you (23131). I got confused as you said:
    as Scott's code was 53131.
    Just wanted to check that my software was correct.
    LD
  3. bobp
    bobp Karting
    Jul 21, 2011
    80
    New Orleans
    Bob
    little_ daz
    My apologies for not correctly recognizing your help.
    THANKS to every-one, it truely is a great community of help, and if I can get a new amp to fit in the very nice original leather bound holder I may be able to listen to NPR soon.
  4. pawkoper
    pawkoper Rookie
    Apr 26, 2013
    5
    Chicago
    Thank you code works and I have radio for week days
  5. jlonmark
    jlonmark F1 Rookie
    Mar 29, 2005
    3,201
    Beverly Hills, CA
    Jay
    What a valuable asset to the community! Anything beats paying becker $ for your own code. Who honestly would want to steal one of these radios? I often have hoped that mine would get stolen so I could upgrade the stock system. Ok, maybe not that extreme.... but close
  6. little_daz
    little_daz Karting
    Jul 28, 2012
    176
    No Problem Bob, I'm happy you got sorted out. I wish I could help with the amp, but I've not seen one. It might be worth checking the other marques that becker radios are fitted in as standard. Check to see if a similar amp might have been fitted in Mercedes, BMW, Mini even Porsche as there is a good bet that if it doesn't say Ferrari or have a Ferrari badge then it'll be cheaper! For example it's like parking sensors from BMW cost £75 you can get the exact same part from Land Rover for £25!
    Good, Happy to help.
    LOL, You'd be suprised, there's probably some kid driving around in a Nissan with a Ferrari radio! I think it's more to do with the speakers. A good upgrade would be an amplifier and component speakers (then maybe a small subwoofer behind the 2 seats in the middle, or in the passenger side footwell). If I'm right in thinking you can get a lead that plugs in to the existing head unit that gives you RCA Line outputs that will go in to an amp... But that's another story for another thread if someone wants to do it.
  7. bulent
    bulent Rookie
    Jun 30, 2013
    27
    hi Little_daz favor please,i have 2000 F 360 just change my battery after i turn on my becker radio code was ask when i input the code it doesnt work.
    2000 ferrari 360
    model: BE 4372
    serial Y5003233
    the code is 8462 but it doesnt work
  8. little_daz
    little_daz Karting
    Jul 28, 2012
    176
    Hey Bulent. That code is right for that serial number. Is this information from the side of the radio, or the code card.
    The only things that can have happened otherwise is the radio has been swapped, or someone has re-coded it and cloned it with another code, but I can't see that as it's rare with these beckers.
    I'll be away for a week, so if you haven't pulled the radio out, do it then check and post the serial or PM me and I'll do it when I get back.
    HTH
  9. bulent
    bulent Rookie
    Jun 30, 2013
    27
    thanks little_daz,i will do that,i just got that code from the code card included on my manuals.ill try to pulled out the radio soon and check the correct serial numbers.again thanks sir
  10. little_daz
    little_daz Karting
    Jul 28, 2012
    176
    No problem. I'm guessing the radio has been switched at some point. Check and let me know.
  11. bulent
    bulent Rookie
    Jun 30, 2013
    27
    Hi little_daz,you've got pm
  12. tazandjan
    39,085
    bulent- Call Scott and he can give you the code based on the serial number you pull off the stereo, not the card. You will have to pull the stereo. Did you get the little tool set with the stereo?
    La Jolla Audio
    Scott Cairncross
    5161 Santa Fe Street Ste B
    San Diego, CA 92109
    858-581-6545
  13. bulent
    bulent Rookie
    Jun 30, 2013
    27
    just found out stock stereo was replaced before i got the unit and it says
    Model no: BE 6104
    serial no: 25004306
  14. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,649
    South East
    Jimmie
    Try 2944 (using a calculator that gave the correct answer tested on your 4372 code so may be ok)
  15. bulent
    bulent Rookie
    Jun 30, 2013
    27
    Great, thanks greyboxer still waiting for the go signal to PIN the code you give,TIA
  16. galt
    galt Formula 3
    Jun 19, 2005
    1,141
    With my 2009 16M there is a seven digit code printed by hand in one of the books. Could this be the radio code. I know it is not the electronic code or mechanical code because those are on separate cards.
    This one is labeled "Codici Componenti" but that is translated as "part code". Throws me off because I thought the codes were supposed to have less than 7 digits...
    Anybody know?
  17. little_daz
    little_daz Karting
    Jul 28, 2012
    176
    Hey Galt.
    They're always 4 or 5 digits. That's either a serial number, or part code but it's definitely not a radio code.
  18. galt
    galt Formula 3
    Jun 19, 2005
    1,141
    Thanks Little Daz. Will bring it in somewhere to get the serial number--unfortunately I don't have the tool to pull it myself.
  19. obm
    obm Rookie
    Oct 3, 2013
    2
    little_daz, would you be able to help me as well? :) Changed battery and the radio is asking for a code now. Radio SN is be4372150102582001, it's a 2001 360 :)
  20. lalostrada
    lalostrada Rookie
    Dec 3, 2013
    1
    LaloStrada
    Im glad i forund this forum,This ist my first comment, i've been having the very same trouble with the same unit as "bulnet" with my f430.
    "greyboxer" your help was full success, would you have some time to help with mine?
    Model: BE 6104
    Serial No: 45017411
    thanks
  21. greyboxer
    Dec 8, 2004
    12,649
    South East
    Jimmie
    No promises : 3214 - I didn't think 430s had 6104s ?
    PS just seen OBM might be 6400
  22. little_daz
    little_daz Karting
    Jul 28, 2012
    176
  23. Col. Kurtz
    Col. Kurtz Formula Junior
    Jun 20, 2013
    276
    New England
    Walter E.
    Hi Guys,
    Can anyone help me with the code to the below? Please PM to me the code.
    Becker from F 360 (not sure what year)
    Model: BE 4372
    Serial#: X5002318
    It's my unit, I just purchased it.
    Thank you!
    CheerZ
    Vincent
  24. little_daz
    little_daz Karting
    Jul 28, 2012
    176
    Code is 6501
  25. little_daz
    little_daz Karting
    Jul 28, 2012
    176
    Please note: If you have a post count of less than 10-20 I will not be providing radio codes and I recommend that others do the same.
    There seems to be a few hit and run people asking for codes on here, who ask and then disappear. I get lots of PM's where people ask for codes and I never even get a thank you and the same is happening on this thread. So I urge others that if someone has a low post count that you do not provide codes.
    By the way this isn't aimed at the last poster VR300zx who has a healthy post count, it's something that's been annoying me for a while.
