Radiopilot does it again - 308 Clock | Page 3 | FerrariChat
Discussion in '308/328' started by bzubi, Jan 19, 2010.
  1. Radiopilot
    Radiopilot Karting
    Dec 10, 2009
    112
    Savannah, GA
    Nick R.
    Unfortunately no the Pantera is a 'clock' customer, but I have a friend that owns one here in Savannah and I'm working on this instruments as well.
    http://www.michaelspantera.com/clocks.html
    That is me in the pic... and if you click the 'photos' button you'll see his Pantera.
    Nick
  2. mej7000
    mej7000 Rookie
    Feb 13, 2013
    1
    Florida
    Michael
    Hi Nick,
    can you send me contact information?
    thanks,
    -mike
  3. BigTex
    79,406
    Houston, Texas
    Bubba
    That's an '82 Spider, not '92??
    The clock with the blue hands actually fits my 308GTB, the Dino clock has plain white hands..I know it's never absolute, with Ferraris.
    Great pics!!!
  4. TVC
    TVC Rookie
    Apr 8, 2013
    1
    Devon. UK
    Andy
    Hello, I have a Veglia quarzo with the resistor which is first in the circuit from the 12v input blackened to the point that i can't read its value, does anybody know what value this resistor should be, I'm geussing it has failed or changed value due to looking like it being burned out, but does still have a resistance of about 38ohm. Not sure if this is why my clock is not working.
  5. chris_columbia
    chris_columbia Formula Junior
    880
    Columbia MD
    Chris
    How are you guys getting to the clock in the 1980 and newer 308's? It sounds like people are taking the entire center consul out? Can't the little panel holding the oil temp and clock be removed after taking out the two screws on its face?
    I ask this because I tried, and failed. I removed the two screws and that little panel doesn't budge! Took out ash tray to get my fingers under the little panel, but still no movement, and I'm pushing hard.
    My goal is to make a voltmeter out of a spare 308 oil temp gauge to replace the clock. Who needs a clock? What a worthless instrument. Now a voltmeter is something a 308 could really use.
  6. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    Chris,
    There are two metal tabs at the front end and a velcro fastener at the rear of the small gauge panel.
    I'll post a picture shortly.
    Jim
  7. i-velocita
    2,520
    Colorado
    James
    #57 i-velocita, Apr 12, 2013
    Just noticed that you have an 83 not an 80 as stated in post. That will be a bit different.
    Here is a picture of the back of my 1980 clock panel for reference.
  8. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    #58 ME308, Apr 12, 2013
    no...and yes ... ;)
    can be really sticky like glue but should come out
    (just swapped my gauges from US to EURO)
  9. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    Do any of your guys have the wee black screws for the clock/oil temp bezel lying around in spares?
  10. i-velocita
    2,520
    Colorado
    James
    #60 i-velocita, Apr 12, 2013
  11. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    Wow that is nice.........and, I see that it only took him 2hrs 40min to boot :) !
  12. vaccarella
    vaccarella Formula 3
    Apr 16, 2011
    2,291
    Paul
    Has anyone got a setting knob? Is the stem a standard thread on clocks?
  13. i-velocita
    2,520
    Colorado
    James
    #63 i-velocita, Apr 12, 2013
    Are you talking about the small black phillips head screews that hold in the leather clock/oil pressure gauge panel?
    I looked around in my boxes of interior parts and found the small screws below. Not sure if they are the correct size but you are welcome to them if you think they might work. Heads are 5.4mm across, length is 23mm. Took a picture with clock for scale.
    Jim
  14. RED HEAD
    RED HEAD Karting
    220
    London
    H
    Mine is missing too any ideas?
  15. chris_columbia
    880
    Columbia MD
    Chris
    "can be really sticky like glue but should come out
    (just swapped my gauges from US to EURO)"
    OK Michael, I'll pull on the panel harder. What is the material used, in case I have to replace it? I see it's aluminum on Jim's 1980. Is it aluminum or fiberglass on 81+?
  16. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    I don`t remember, probably alu, but you cannot break it either way...
    if you already have the ashtray and the gate out (what should not be neccessary),
    you can also reach in there and try to push it from behind
  17. mwr4440
    58,073
    Bavaria, The 'Other' Germany
    Mark W.R.
    My "81 NA, it is relatively thin metal rapped in leather. It can stand a little pull. The leather layers likely just "boned over time and with a little leather cleaner down in the joints of the parts that turned to glue.
  18. chris_columbia
    880
    Columbia MD
    Chris
    I've had the ashtray and gate out, but thought I'd break something. Maybe I'll try to wet the seam with water for a few minutes and give it a try.
  19. Specracer 85
    Specracer 85 Rookie
    Oct 15, 2010
    9
    St Petersburg, FL
    Jim Ellinger
    Mine is missing from my 328. I'm guessing we are not the only three.
  20. matumorales
    matumorales Formula Junior
    Jun 8, 2011
    470
    Asunción, Paraguay
    Daniel Morales
    I'm working on building myself a replica of the 308's clock for my project 37313 resurrection, using a Veglia clock taken from a Fiat 124. The clock is identical in size, and the setting screw seems to be identical as well; maybe you could purchase a used one from eBay (they sell for around 6 bucks + shipping), take it apart and see if the internals match the 308's...
    Just my 2 cents...
  21. tomberlin
    tomberlin Formula Junior
    854
    Bethesda
    tom berlin
    Does anyone know if Radiopilot is still around and/or know if he's still doing clock repairs.
  22. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,829
    Australia
    Mark R
    Does the fogging issue occur with 328 clocks or is it mainly 308's?
  23. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Fogging is found on any clock that has a stem coming through it. It needs a hole in it for the stem and Veglia decided to use plastic instead of glass. The plastic fogs over time from cleaning solvents used and fine scratches from using dirty rags to clean it. If your face is clear only use optical plastic lens cleaner and a clean soft cloth. If there is gritty material on the face remove that first with gentle dabbing with a damp cloth. Don’t wipe or it will scratch the soft plastic.
  24. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    By the way there is an alternative fix. Replace the plastic crystal with glass. Available from Unobtaniumsupply.
  25. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
