For Sale - RARE: F355 Challenge / Serie - Fiorano Brake Package | FerrariChat
For Sale RARE: F355 Challenge / Serie - Fiorano Brake Package
Discussion in 'Ferrari Parts & Collectibles' started by X-TNSIV, Jun 13, 2019.
  1. X-TNSIV
    X-TNSIV Formula Junior
    May 2, 2007
    347
    Irvine, CA
    Allen
    #1 X-TNSIV, Jun 13, 2019
    Ferrari Factory 355 Challenge / Fiorano Brake Package:
    These Ferrari brakes were developed by Brembo for Ferrari's F355 Challenge Race Series and at the end of the F355 production (circa 1998/1999), Ferrari began to offer these race spec brakes on select special edition cars (including the Serie Fiorano limited edition cars)
    This rare brake set includes:
    • Front and Rear calipers in RED (made by Brembo for Ferrari
    • Front and Rear cross-drilled rotors (made by Brembo for Ferrari)
      • Front Rotors/Discs Brembo - Measure 27.6mm (Minimum 26mm)
      • Rear Rotors/Discs Brembo - Measure 23.5mm (Minimum 22mm)
    • Brake pads (almost brand new condition)
      • Front Brake Pads - Measure 10.5mm Average
      • Rear Brake Pads - Measure 10.1mm Average
    • Front brake pad sensors
    • 2 brake lines
    • Mounting clips for the brake lines
    Selling for $1995.00 + shipping
  2. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,758
    Lake Villa IL
    There is nothing shared between Fiorano and Challenge brakes.
    f355spider, Yassa and slracing like this.
  3. X-TNSIV
    May 2, 2007
    347
    Irvine, CA
    Allen
    After your post, I did a little more research and you are correct, these are indeed not the same as Challenge brakes. I apologize for the confusion.
    These are the Fiorano Handling Package Brakes used on cars with factory built with the FHP and the Serie Fiorano (limited to 104 cars)
    INTMD8 likes this.
  4. ILLA NOIZ
    ILLA NOIZ Karting
    Mar 28, 2015
    132
    Concord, North Carolina
    Drew
    Will this kit fit a 348 without modifications?
  5. X-TNSIV
    May 2, 2007
    347
    Irvine, CA
    Allen
  6. Yellow02Z06
    Yellow02Z06 Karting
    Nov 2, 2013
    214
    Whats the difference between these and the stock 355 setup (sorry for ignorance / dumb question - humor me please) ? Do you have any brackets?
  7. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,758
    Lake Villa IL
    No brackets needed. Brakes are the same as stock with the exception of the color of the calipers and the drilled rotors.
    Yassa likes this.
  8. f355spider
    f355spider F1 World Champ
    18,044
    Brakes are the same for all years 355s. 1998/1999 added the option of painted calipers (red, yellow or silver, over the standard gloss black) and cross drilled rotors. The 355 Fiorano had a slightly more aggressive brake pad, otherwise the brakes were the same as other 355s.
  9. X-TNSIV
    May 2, 2007
    347
    Irvine, CA
    Allen
    I believe this is perfect for the owner that wants to enhance the look of their brakes and provide some increased performance. I know when I had my previous Ferrari with black calipers, I desperately wanted to change them to red.
    f355spider likes this.
  10. StartedFromTheBottom
    StartedFromTheBottom Formula Junior
    533
    Europe
    So basically it’s a fact that the difference of this set to stock set is just coloured calipers (maybe if not already installed) and the brake pads ;)?
    SoCal1 likes this.
  11. f355spider
    18,044
    Also cross drilled rotors. Basically it included both options for 1998/1999 of optional caliper colors and cross drilled rotors. Then added a special, more aggressive brake pad. But all years, use the same caliper and rotor diameter.
  12. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,340
    Robb
    I have a full set on my car. Just replaced the 4 cross drilled rotors... they run 350 each from Eurospares. 550 each from Ricambi pads f not and rear ran 500.
    Then you gave the calipers...
    So this set seems well priced.
    Robb
  13. Kruegmeister
    Kruegmeister Formula Junior
    519
    Michigan
    Kruegmeister
    I have some interest in this set as I believe my Pads are due for replacement.
    I've read on here "The 355 uses 310 x 28 on front and 300 x 24 on the rear"
    So does that mean these Rotors have minimal use with only 0.5mm wear?
    I measured my Stock Rotors and got similar measurements, tho my fronts look in a good need of a turning as they seem to have some grooves.
    Outside of this set I would just need some Dot 4 Synthetic and possibly Copper Washers for the Banjo fitting?
  14. X-TNSIV
    May 2, 2007
    347
    Irvine, CA
    Allen
    Yes, you are correct. Everything should mount right up.
  15. Red_SLR
    Red_SLR Karting
    Jul 22, 2019
    109
    Simon
    Hi, first post go easy but are we sure the FHP brakes are the same as the standard ones?
    The reason I ask is I was google searching for FHP discs as my car needs a set and I was struggling to find some and I found this thread.
    Its either an optical illusion but my brakes look quite a bit larger than stock?
    The brake caliper is a different design too, again unless its some sort of optical illusion?
    Here is a picture of my cars front brakes
  16. Red_SLR
    Red_SLR Karting
    Jul 22, 2019
    109
    Simon
  17. Red_SLR
    Red_SLR Karting
    Jul 22, 2019
    109
    Simon
  18. X-TNSIV
    May 2, 2007
    347
    Irvine, CA
    Allen
    It appears your have the Brembo GT aftermarket big brake kit on the front of your car.
    Red_SLR and f355spider like this.
  19. Red_SLR
    Red_SLR Karting
    Jul 22, 2019
    109
    Simon
    Interesting never knew that just assumed was part of the FHP. Thanks!
  20. Kruegmeister
    519
    Michigan
    Kruegmeister
    PM'd You
  21. X-TNSIV
    May 2, 2007
    347
    Irvine, CA
    Allen
    SOLD!
    Thank you Kruegmeister!
