Rebuilding a Dinoplex AEC103A | Page 8 | FerrariChat
Discussion in '206/246' started by alhbln, Mar 5, 2010.
  1. HMB-Dino
    HMB-Dino Formula 3
    2,344
    Pebble Beach, CA
    RonG
    A couple years ago my mechanic replaced my MSD 6AL with the Dinoplex AEC103A box containing the MSD Street Fire guts (the 6AL guts wouldn't fit). Has worked like a charm and has the original factory appearance required for concours judging. I believe there was minimal modification to the AEC103A box internals.
  2. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    #177 alhbln, Jun 10, 2015
    Yes and yes. The MSD 6AL-2 #6421 is not that new, i remember installing the first one in 2009. It works quite well with the Dino engine, the output is similar to the original AEC103A.
    The MSD 6AL-2 internals will fit into the original AEC103A enclosure but you have to fabricate a small aluminum cooling plate transferring the heat from the transistors/thyristor (at the top of the photo below) to the inside of the enclosure, and use mounting posts for the circuit board to get the correct distance to fit the rectangular thermopad on the underside of the MSD 6A circuit board.
    The MSD 6A requires two wires going to the coil, you need to route one of the two coil wires via a hole in the bottom of the AEC103A enclosure and the other one via the four terminal connector as per factory.
  3. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,071
    Is there a source for these stickers? I have a unit that has the sticker in poor shape, and about to fall off.
  4. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    Just saw its for a AEC104, i'm not aware of a source. Started on print ready layouts for replica labels but the production process (print anodizing on aluminium) is somewhat expensive.
  5. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #180 synchro, Jun 17, 2015
    Thank you, I'm there now.
    Is the two wire device a thermal sensor and where did you mount it or let it float?
    This is the one red wire/one white wired to the single device in the left center of your image (right center in my image) and was attached with heavt thermal grease.
    PS - Best price I found on this was with coil and bracket: http://www.ebay.com/itm/201209306044
  6. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    Scott,
    looks good!
    The two wire device is a power diode, use a bit of thermal grease and mount it somewhere on the inside of the AEC103A enclosure (below the PCB is also fine).
    Take care that you also transfer the orange silicone rubber insulation which was mounted between the original enclosure and the transistors/thyristor. The silicone rubber layer ensures that the transistors/thyristors are not electrically connected to each other via their heatsink.
    The heatsink on the underside of the MSD 6A2 PCB should connect to the AEC103 (or a custom aluminum plate below the PCB) for ensuring a good heat transfer.
    Good luck,
    Adrian
  7. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #182 synchro, Jun 18, 2015
    Thank you, that makes sense it is a power diode as the original install would be too far away from a heat source. Strange thay did not mount this on the circuit board though, I'll secure it to the case.
    I've only just received the unit but am preserving both the thyristor thermal path and the toroid cooling pad and thermal conductor block. I have some large stock to bridge the thyristor's thermal gap to the case heat sink and will use the original insulation pad and backing bar but screwed from the inside. I'll set the board on stand-offs to secure it.
    How is the AEC label oriented on the case when in a Dino, isn't it upside down as viewed from centerline?
  8. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    Looks good!
    If the AEC label is in the correct position (readable) then the connector on the lower enclosure part is on the right side. When installed in the Dino the connector points down so the label is rotated 90 deg CW.
  9. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    You know why it matters, I'm thinking of attaching the thyristor heat sink bar to the Marelli case side and the two fasteners might be seen in one orientation.
    This setup is amazingly simple.
  10. VicJano
    VicJano Karting
    Dec 17, 2011
    233
    Kingston upon Thames
    Chris O'Connor
    Hi Matthias,
    With Adrian's design did the top of the dizzy shaft have to be altered to take the Lumenition components?
    Thanks in advance
    Chris
  11. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    The MSD 6AL2 can take three types of igniter inputs without additional circuitry; electrical points, optical or magnetic.
  12. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    Four including the Hall trigger input :)
  13. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #188 synchro, Jun 29, 2015
    Correct!
    I set the rev limiter to 7800, chose the points as the electrical input trigger, and then heat capped off the unused terminals; mag input, Hall effect, and Rev Limit 2.
    The stock Marelli AEC-103a electrical connector has four terminals which fit perfectly for this setup, these MSD wires attach to the back 4 connector;
    - a single white wire for the points electrical input from the distributor
    - the two coil output wires Orange and Black
    - a single gray wire outout to the tach
    I secured the power diode to the case, laid down an insulating pad, and even included the original coil insulation pad and heat sink bar. I then built a spacer heat sink to conform to the interior geometry while preserving the thyristor heat path using the original backing bar and silicon insulator pad.
    No new fasteners needed.
  14. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    Very nice work! The only thing i would change is the connector wiring you described above to avoid any issue with the original wiring a workshop or 3rd party might have when working on the car.
    To keep it compatible with the original wiring, wire the +12V supply (you can solder the large and small red wire together), tacho wire (grey), points wire (white), coil output (orange) to the original connector, and use a cable sleeve to guide the black coil wire through the unused transistor compartment to the outside/coil.
  15. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #190 synchro, Jun 30, 2015
    Thank you
    Mine is an E series Dino and I see the original car wiring to the four pin Marelli connector as:
    1) Yellow is +12V input
    2) Blue is distributor input
    3) Red is the coil + terminal output
    4) Brown is the Tach output
    Again, this is from the car side
  16. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
  17. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #192 synchro, Jul 5, 2015
    Test wired the new unit, substituting only the old, trusty MSD.
    Started right up with no discernable difference in idle speed or exhaust tone
  18. rynoshark
    rynoshark Formula 3
    1,035
    Pacific Northwest
    Very nicely done Scott.
  19. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #194 synchro, Jul 5, 2015
  20. Fred Winterburn
    Fred Winterburn Karting
    Jan 27, 2015
    75
    Folks,
    I've been lurking on this forum for some time. I do not own a Dino, nor is it ever likely that I will, but the Dino's ignition system has a personal interest for me. I've wanted to test an AEC103A to see how it performs on my test rig, but was unable to source one at a reasonable price, so I managed to find a aec103B (red label for 4 cyl). It was supposed to be working, but in fact it was failing and completely died after 5 minutes on the test rig. It was self triggering which told me the SCR was bad and then the SCR shorted completely. In those 5 minutes I was able to determine that its output voltage was extremely high and that is probably what finally led to the SCR failing. This one produced in excess of 50 thousand volts on the test rig while self triggering. Too bad it was potted or the fix would have been really simple and some over-voltage protection could have been added at the same time. It fired negatively like it should on the initial strike, but the spark was truncated part way through the positive voltage swing which limited the energy transfer and duration. It still produces a very powerful spark regardless because of the wicked voltage stored in the capacitor. Current draw was about 3 amps at the self triggering spark rate which I estimated to be about 2800rpm on the test rig. That isn't great, but it's not bad either. I don't know how this ignition compares with the Aec103A found in the Dino, but I'll bet it is almost identical, if not exactly the same.
    So, since the unit became a brick, I've followed the directions, almost to the letter, on removing the old potting and unobtainable connector and I'm going to put a modified version of my own ignition system inside at some point in the future. I've already done so for one Dino owner that sent me his beautifully restored case. It should provide many years of good service, and it is not potted. I hate potting! The connections are exactly the same as the original aec103A connections. No extra wires out the bottom or anything like that. Points triggered only I'm afraid (or Pertronix, but that is a poor substitute for points). See the pic, Fred Winterburn
  21. Fred Winterburn
    Jan 27, 2015
    75
    #196 Fred Winterburn, Jul 6, 2015
    Here's the picture I promised of a retrofit alternative. There are no new holes drilled in the case. The circuit board assembly is attached using the existing mounting points. The power transistors for the power supply are mounted to an aluminum plate fixed to the bottom as a heatsink. The necessary power resistor for the points trigger circuit is heat sunk to the case at the very left side. Fred
  22. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Thank you, several heat cycles show this performs similarly to the prior installed MSD 6200, easy startup, quickly captures idle and no changes to the tach circuit.
  23. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,853
    Southern California
    Fred,
    As one of the first Dino owners to use your unit, I'm really glad you posted your latest development here. I am really satisfied with the performance of your early unit (not encased in Dinoplex housing). After seeing the photos of this latest unit in a Dinoplex housing I will eventually want you to do the same for me! The performance from the Winterburn CDI, I can't say enough good things about. Instant start, instant idle, instant hot restarts and keeping the stock points. Fred, thank you! It is rare that the creator of a product is personally accessible and passionate about what their customer thinks of their product.
    A loyal Winterburn customer!
    Freeman
  24. mar3kl
    mar3kl Formula Junior
    Nov 17, 2011
    471
    Silicon Valley
    Mark
    And as the owner of the retrofitted module in question, I can say I'm very, very happy as well. Completely original look and way better performance.
  25. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,853
    Southern California
    #200 4CamGT, Jul 9, 2015
    Mark,
    I've had the Winterburn CDI in my Dino for about 7/8 months with great results. Adrian was the one who pointed me in the Winterburn direction when I was adamant on keeping the stock points distributor. Adrian was also a great help in creating a wiring diagram on the Winterburn application for the Dino for me. All my vintage racer friends including Tom Shaughnessy said "Keep the points"! It is much easier to problem solve because you can see if it has spark or not. Also it has the added advantage of switching to straight coil to points if need be like the original Dinoplex. Fred has been fantastic support. A straight forward "better" Dinoplex. Of note, I use the NGK Iridium plugs as once recommended by Corbani.
    Freeman
    P.S. Fred's "day job" is writing operating procedures for a nuclear power plant. Fred's dad, Lloyd Winterburn created the very first commercially available CD ignition in early 1962.
    http://www.capacitordischargeignition.com
    https://en.m.wikipedia.org/wiki/Capacitor_discharge_ignition
