360 - Refinishing 360 Key - paint color and finish? | FerrariChat
360 Refinishing 360 Key - paint color and finish?
Discussion in '360/430' started by Robb, Jun 18, 2020.
  1. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,322
    Robb
    What color is the paint and finish on the oem 360 ignition key?
    I am going to sand it down and repaint and replace the horse.
    the second key I have is new so I can also use it as a match...
    thanks for any help.
    Robb
  2. Robb
    Robb Moderator
    Feb 28, 2004
    14,322
    Robb
    #2 Robb, Jun 18, 2020
    Performify likes this.
  3. Performify
    Performify Formula Junior
    383
    Sarasota, FL
    Eric
    I plan on doing mine soon and will probably go with Ferrari Red instead of trying to refresh to silver.
    that said i have leftover high temp silver from painting my rotor hats and might start there. I don't think it will match exactly but i'm mostly just looking to have the key look better, not have it exact match.
    if your refinish goes sideways i have one of these and definitely happy with it:
    http://www.klassikcarkeys.com/ferrari_key.html
  4. Robb
    Robb Moderator
    Feb 28, 2004
    14,322
    Robb
    I have a third red key fRom those guys that is also a good extra.
    The original finish of the silver keys is a bit gritty so I’m not sure how they did that
    Robb
  5. JonM
    JonM Karting
    Oct 31, 2017
    132
    South Gippsland, Victoria, Australia
    Jon Maratos
    There's been a few posts about refinishing keys. I chose to remove the clear coat and buff it to a shiny finish. Haven't put the cavalino back in as Im in the process of casting some resin ones in the same colour as my car (Giallo). Here's a pic of the polished key.
  6. Robb
    Robb Moderator
    Feb 28, 2004
    14,322
    Robb
    I'm going to restore the worn key to oem...
    Robb
  7. Performify
    383
    Sarasota, FL
    Eric
    I'd be interested in buying a cavalino (depending on cost) if you have the opportunity to make an extra!
  8. tazandjan
    39,141
    Robb- The key looks like Argento Nurburgring/Argento Metallizzato (same color) Ferrari uses on its silver wheels. PPG code is 36520.
    Robb likes this.
  9. JonM
    JonM Karting
    Oct 31, 2017
    132
    Jon Maratos
    I'd be happy to send you one, but at the moment I'm having trouble getting a clean cast happening. They come out of the mould with a few rough bits and they're so small and fragile that I can't clean them up with a razor blade or anything else. If I get something decent, I'll message you and get your postal details.
    Cheers, Jon
  10. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    906
    S La
    The exact same metal cavallino rampante(1/18 scale) is available from Scale Details on Ebay. It is a Pocher scale model part. ~$12 and fits perfectly in the key depression. I refinished my ratty looking 360 keys and replaced a missing cavallino many years ago and just bead blasted the keys down to clean aluminum and to this day they still look good. No paint to chip, etc. I think they should have been finished that way from the factory. No nonsense. Clean bead blasted aluminum.
  11. BDubbs
    BDubbs Karting
    168
    TN
    B Dubbs
    tifosi101, Graz and Robb like this.
  12. ItalGerBrit
    Mar 15, 2016
    906
    S La
    Yep. That is the way to do it. As it wears a nice patina develops and it looks even better. If you do not like the "patina", bead blast it again.
  13. JonM
    JonM Karting
    Oct 31, 2017
    132
    Jon Maratos
    Would you have a link to it on eBay? Had a look and couldn't find it.
  14. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,728
    Just East of Weird
    Bob
    PM me your address. I have a Pocher one I bought for my 360 key and never used it.
    Sent from my iPad using Tapatalk Pro
  15. tazandjan
    39,141
    Key is likely not aluminum if it did not corrode after being shot blasted or sanded.
  16. BDubbs
    BDubbs Karting
    168
    TN
    B Dubbs
    Pretty sure its aluminum. Corrosion is much slower with aluminum and it will not rust. A simple wash with soap once in a while will reduce the chances of any corrosion or oxidation. Salt exposure can increase the chances of oxidation/corrosion. I was thinking about anodizing it which would provide the perfect corrosion resistance. But so far, its been a year, and no sign of corrosion. It is still raw aluminum, so yes, it is susceptible to some form of corrosion or oxidation. I am no expert, so take with a grain of salt...
    Sent from my SM-N975U using FerrariChat.com mobile app
  17. ItalGerBrit
    Mar 15, 2016
    906
    S La
    https://scaledetails.com/pocher-1-8-ferraris/ I just googled "Scale Details", selected 1/8 Ferraris and it is listed in that section.
    About corrosion. Why would an aluminum car key ever corrode in you pocket, ignition, or in your house? Maybe if you lived in a hut on a beach?
  18. tazandjan
    39,141
    Aluminum corrodes just like most metals and forms a dull oxide on the surface. Aluminum also rubs off as a black residue of the oxide. Happens anywhere there is moisture in the air. Maybe not in the middle of the Sahara, but most other places.
  19. ItalGerBrit
    Mar 15, 2016
    906
    S La
    I live in the very not and humid swamp and my keys have no corrosion at all and no black residue. I stripped my two keys many, many years ago. Stripped Ferrari keys will not corrode under normal circumstances. Maybe an alloy was added to increase corrosion resistance?
    Mimmo Blue likes this.
  20. tazandjan
    39,141
    Maybe they are pot metal and not aluminum?
  21. ItalGerBrit
    Mar 15, 2016
    906
    S La
    I was thinking the same thing.
  22. Robb
    Robb Moderator
    Feb 28, 2004
    14,322
    Robb
    My original (and quite worn) 360 key (right) has successfully been refinished to be a ringer for the new blank I had cut that was never used (left).
    I am pleased.
    Robb
