Removing cam distributor rotor drive
Discussion in 'Technical Q&A' started by snj5, Jan 10, 2004.
  1. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Am about to remove the pin holding the distributor rotor drive to the cam.
    Is the pin directional, or can take out from either side?
    How hard is it to get the pin out?
    How hard is it then to take the rotor drive out of the cam?
    Many thanks
    rt
  3. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    586
    NW Rural Nevada
    Mike Florio
    I was just playing with one last week, making a distributor machine drive. According to my measurements, it has a straight hole drilled in it, and it accepted a standard roll pin. Be careful, though It is part #108005, and a new one will cost you close to $200!
  4. ria
    ria Formula Junior
    Nov 2, 2003
    728
    ohio
    phill
    on my 80 308gtsi NO PIN it is a small bolt maybe 4 mm that holds the rotor in plase.
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    11,705
    San Carlos, CA
    Mitchell Le
    Mine was a 4mm solid pin that can be driven out from either side, then the gear just pulls off.
  6. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Woo-Hoo.
    Success.
    Thanks everyone!!
    Russ
