Removing Daytona Amp Meter | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Portenos, Jan 12, 2019.
  1. f355spider
    f355spider F1 World Champ
    18,056
    Thanks for the follow up Frank, it's always great to see what the solution was. Please hit me up when you return to the NW after the thaw.
  2. Portenos
    Portenos Formula 3
    Aug 20, 2004
    1,853
    Seattle
    Carguytour
    who is this?
    Ciao
    Portenos
  3. TTR
    TTR F1 Veteran
    6,097
    Riverside, CA
    Timo
    The smaller cube-shaped disconnected relay on the upper RH corner of the board is/was likely used for "Hazard" lights and the slightly larger, rectangular (also disconnected) one toward the middle of the board is/was likely used for "Air (Smog) Pump Clutch".
