removing window switches 308QV | FerrariChat
Discussion in 'Technical Q&A' started by 308man, May 19, 2006.
  1. 308man
    308man Rookie
    Feb 21, 2004
    46
    MA
    Joe Calareso
    Does anyone know if the window switches be removed without lifting up center console and getting them from behind. Don't want to damage anything trying to pull them out from top.
  2. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,529
    Tuscaloosa, AL
    Drew Altemara
    Yes they should pull out from the top rather easily. You should only have to use your fingers. In the worse case you may have to place a wide blade underneath the lip to get it started. If you have to do this I would pry from the shorter end of the switch. Good luck.
