News
360 Replacement Tool and Inflator Straps
Discussion in '360/430' started by Neil22, Oct 9, 2019.
  1. Neil22
    Neil22 Karting
    60
    Oxford CT
    Neil Silberkleit
    The pleather tool and inflator straps in my 360 deteriorated to the point of no return.
    It seems very strange to me that $150,000+ Ferrari would use the cheapest material to make these straps.
    There had been a lot of discussion about finding shops to make these straps from real leather.
    While searching for a local company to make the straps I found this company called Two Redbirds out of Texas, who make real leather straps for 360’s.
    I ordered the straps and they are very close to original except made of real leather.
    Website: https://www.tworedbirds.com/ferrari-accessories
    Below are pictures I took of the deteriorated straps and the new ones I ordered.
  2. tazandjan
    Owner Lifetime Rossa
    30,961
    Albuquerque, NM
    Look very nice.
  3. Ghostdiver
    Ghostdiver Formula Junior
    965
    Southeast Texas
    Wally Hollar
    There are a few more threads detailing Randy's (Two Red Birds) work. He has been making leather accessories for a while now but recently has started making the straps for several Ferrari models. Not only does he do the inflator and tool kit straps but I believe he has patterns for the spare tire mount group as well.
  4. Keith360
    Keith360 Formula Junior
    541
    Santa Barbara County
    Keith Williams
    I wish I knew of them years ago when I bought a new set of cheap OEM crap to replace the cheap crap that came with the car. I didn’t think outside the box...
  5. Rjoselaw
    Rjoselaw Rookie
    Mar 10, 2019
    48
    Soutlake, Texas
    Rajish Jose
    Thank you for the referral. I need to replace mine and these look perfect and priced nicely too!
    Ghostdiver likes this.
  6. Ghostdiver
    965
    Southeast Texas
    Wally Hollar
    If it makes you feel better, I first contacted him about my straps in December 2017 and he used my original straps as a pattern! Even though he recently started doing the straps, he has been doing leatherwork for sometime now.
  7. whatheheck
    whatheheck F1 Rookie
    Silver Subscribed Owner
    Mar 27, 2006
    3,425
    Seattle, Wa
    Dan L.
    That looks really nice.
    Thanks for sharing.
    Dan
  8. Neil22
    Neil22 Karting
    60
    Oxford CT
    Neil Silberkleit
    Quick note when you go to install - they are riveted to the carpet in the back and the floor. You will need to remove the rear carpet to install the inflator or spare tire straps. and yes he makes the spare tire straps as well. Fast service excellent quality.
  9. Keith360
    541
    Keith Williams
    I think that makes me feel even worse. ;)
  10. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    507
    Georgia
    Mark Gronsbell
    The straps from Randy are very good quality but to really make it right I matched the OEM color with dye from a local source and used my airbrush to spray the straps for a better match to the tool case.
    f355spider likes this.
  11. Ghostdiver
    965
    Southeast Texas
    Wally Hollar
    Since he was matching to my car (99), it may have been a little off in regards models after that. However, I think I remember the tool kit was a little off compared to the original strap on mine anyway. In the end at least it's real leather instead of the whatever the factory stuff is!
  12. Robert Kenton
    Robert Kenton Formula Junior
    Aug 26, 2005
    354
    Carmel Valley, CA
    R W Kenton
    I haven't yet attempted the strap replacement, though this is on my to-do list. I thought I saw from an old post that the rivets can simply be drilled out, new straps fitted, and then secured with new pop rivets; ie no0 carpet, etc removal necessary.
  13. Neil22
    Neil22 Karting
    60
    Oxford CT
    Neil Silberkleit
    Not true - all the straps except for the floor have small metal plates that will drop once the rivets are drilled out.
    The ones on the bottom carpet can be drilled out without removal since the rivet uses the floor as the metal plate.
    Make sure you size the new rivets correctly.
    removal of the carpet is easy - careful with the plastic rivets on the right side of the carpet - they are available if they break
