Buy
Replacing 328 Oil Retainers for Timing Belt Pulleys
Discussion in '308/328' started by dirk, May 14, 2008.
  1. dirk
    dirk Rookie
    Nov 4, 2003
    33
    Europe
    Dirk
    Is it possible to replace the timing belt pulley oil retainers, in a 328, without engine off ?
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    11,579
    San Carlos, CA
    Mitchell Le
    More clarification please.
    Oil retainer ... do you mean oil seals?
    Timing belt pulley ... the lower ones (drive) or the upper ones (cam shaft)?
  4. dirk
    dirk Rookie
    Nov 4, 2003
    33
    Europe
    Dirk
    The lower ones, the oil retainer should be behind the bearing.
    Dirk
  5. yelcab
    Nov 29, 2001
    11,579
    San Carlos, CA
    Mitchell Le
    Yes, it is possible after you remove the drive pulley.
