Rolex Sea Dweller Issue
Discussion in 'Fine Watches, Jewelry, & Clothes' started by FiveLiterEater96, Mar 19, 2017.
  1. FiveLiterEater96
    FiveLiterEater96 Formula 3
    1,684
    Illinois
    Andrew
    So my Rolex SD stopped the other day from lack of wear and when I went to set the time/date I noticed that when unscrewing the crown it wasn't really detaching from the movement, if that makes any sense. Basically, I can pull it out, wind it up but as I screw the crown back down its changing the time/date. This is a new phenomenon and its making me crazy. I originally thought that it may be because it was 12 hours off but that doesn't seem to be the case. The entire time I turn the crown I can tell that its winding the watch.
    Anyone else had this issue? Any suggestions or is it time to send it in?
    Thanks in advance!
  2. miurasv
    miurasv F1 Veteran
    5,554
    Cardiff, UK
    Steven Robertson
    Which model number Sea Dweller is it? How old is the watch and if an older SD when was it last serviced? Please post some pictures.
  3. FiveLiterEater96
    1,684
    Illinois
    Andrew
    #3 FiveLiterEater96, Mar 19, 2017
    Circa 1992. I picked it up second hand so I can only assume its due for service.
  4. miurasv
    miurasv F1 Veteran
    5,554
    Cardiff, UK
    Steven Robertson
    Get it serviced by Rolex. Personally, I wouldn't use anyone else.
  5. cls
    cls Formula 3
    1,001
    Los Angeles/Montreal
    Chris
    Let's clarify your symptoms
    You have 3 detents:
    Position 1 when you unscrew the crown - manual winding
    Position 2 when you slightly pull out the crown - quickset date
    Position 3 when you pull the crown out all the way - time setting
    You said you pull the crown out for winding? You should be able to wind by just unscrewing the crown - it's spring loaded and pops out on it's own.
    It's possible that the crown is bad, it has a spring and a clutch action when unscrewed / screwed into the case.
    It's also possible that there is something wrong with the keyless works, that's unusual for a 3135 movement as they keyless is a pretty robust design.
    You may or may not want to use Rolex for the repair. If you want someone local AWCI is a good place to start: https://members.awci.com/AWCIWEB/AWCISearch/MemberSearch.aspx
    Rolex does not have a service center in IL as far as I know, so you would have to contact an AD https://www.rolex.com/rolex-dealers/services-locator/
  6. definitelysomeday
    definitelysomeday Formula Junior
    Aug 7, 2009
    541
    Ft. Lauderdale
    Tom Kavan
    Case tube might be kaput? That is the part the crown screws onto.
  7. Tired of seeing this ad? Upgrade now
  8. FiveLiterEater96
    1,684
    Illinois
    Andrew
    Correct. Let me clarify, previously it had all three positions. Now, it literally unscrews through all three positions without ever 'clicking' out. So basically as I'm screwing the crown down it's changing the time/date.
  9. cls
    cls Formula 3
    1,001
    Chris
    When you say changing time / date, you mean changing time, but every 24 hours it changes date? You don't mean the quickset date is changing, correct?
    If it's keyless, I don't think most watchmakers will touch it without a full service (which it may need.) Have someone check the crown first, that's an easy repair and the movement stays in the case. If it stays in time setting position, that sounds more like a keyless issue though.
  10. FiveLiterEater96
    1,684
    Illinois
    Andrew
    The quickset date does change as it 'screws' past that position.
  11. cls
    cls Formula 3
    1,001
    Chris
    For clarification's sake:
    The date changes when the hands rotate 24 hours.
    A quickset date changes with the rotation of the crown, the hands do not rotate when using the quickset date function.
    Impossible to reliably diagnose over the internet, and should be easily diagnosed in a few seconds by someone qualified.
  12. FiveLiterEater96
    1,684
    Illinois
    Andrew
    I know, it's bizarre. I'm going to have my local guy take a look at it this week but in the end will likely send it out. I'm sure it's do for service and I could use the peace of mind.
  13. Adrenalista
    Adrenalista Rookie
    Mar 19, 2017
    11
    Chicagoland
    CD Peacock in Oak Brook IL has an excellent watch servicing technician. The guy is a 2nd or 3rd generation watch craftsman. Lots of attention to detail and almost always at the store no matter when you walk in. Rolex certified but you don't have to send it away, stays in house.
  14. Tired of seeing this ad? Upgrade now
  15. FiveLiterEater96
    1,684
    Illinois
    Andrew
    Thanks for the tip!
  16. WJGESQ
    WJGESQ Formula 3
    Dec 30, 2004
    1,376
    The new ones are 43mm and are "red".
  17. FiveLiterEater96
    1,684
    Illinois
    Andrew
    But that cyclops! Thats seriously the main reason I opted for the SD over the sub. I hate the cyclops.
  18. WJGESQ
    WJGESQ Formula 3
    Dec 30, 2004
    1,376
    They can be removed.
