Rolling 308 | Page 2 | FerrariChat
Rolling 308
Discussion in 'Technical Q&A' started by plahaye, Dec 7, 2003.
  1. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    ya' think the red calipers are too much?
  2. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    done...
  3. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    what do you mean 3 more corners...
  4. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    Begging for steering rack to be hooked up..
  5. plahaye
    plahaye Rookie
    Nov 2, 2003
    49
    S La. swamp
    Phil LaHaye
    Dave,
    Where did he bigger calipers and rotors come from? If they will not stop you what will?
    Phil
  6. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    Phil, they are stock size...
  7. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Dave,
    Have you located polyurethane parts for the rear a-frame outer bushings?
    If so, what mfg & p/n?
  8. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    Verell, at this point I just have the inner which is the same that I used on the front.
  9. nautique
    nautique Rookie
    Nov 1, 2003
    20
    Los angelas, CA
    Craig Tempelton
    Dave,
    I am in the process of doing the same upgrades to my suspension as you (although, I went the stock shock and spring route). Where did you find the drilled rotors and are you using Polyurethane bushing for the sway bar link arms.
    Also, does anyone know how to tell if my Ball joints need replaces. The lower one does not feel that tight but I am not sure how they should feel
    ct
  10. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Dave,
    Tell me about the sway bar grease fitting.... I assume that it is not a 'Ferrari' design??? Did the fitting come with the bushings and new support steel - or is it your own design or??
    Thanks in advance,
    Vince
  11. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    Vince, the sway bar bushing is Energy Suspension # 9.5155G
    greaseable sway bar bushing set...
    Just remember that this is for a GTB, your car may differ.
  12. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    The rotors are Brembo from evosport,
    and for the sway bar link arms I turned some Energy Suspension poly bushings to fit.
  13. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    Philip, I have been looking over the brake cooling situation and don't know if I should buy one of the products already out for the 308, or try and rig my own config.
    What did you end up doing?
  14. 1975gt4don
    1975gt4don Formula Junior
    Nov 5, 2003
    665
    Peoples Rep of CA
    Smog Exempt
    Dave/anyone, anyone have a source for the paper constructed air duct that runs to the front disc? Mine fell apart when you removing the fiberglass wall that goes into the front part of the front wheel well. TIA. I am hoping Pepboys or someone like that sells it.
  15. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Dave
    I bought a couple of large ducts (inlet about 5" x 9", matt black in color) and some 3" corrugated (silicon I think, orange colored) ducting from Pegasus or one of the other race shops. As mine is an early carb'd car, there are no driving lights under the indicator/side lights and I fab'd a couple of mounts to locate the ducts under the bumper and behind the grill. It is 99% hidden to all but a close-up and non-casual eye and it is directly in the air stream.
    From there I routed the ducting to end close to the center of the rotor. I squeezed the heater hose ducts out of the way and tried to avoid having either of the hoses unduly compress.
    After removing the backing plates, I had a couple of mounts made from fairly thick stainless. They attach to the steering arms (where the backing plates usually bolt) with a strong inverted U shaped guide that sits on the steering arm closer to the hub. When in position they are strong and robust. On to this structure I had a 3 inch diameter stub ring welded which forms the male piece on to which the (female) hose piece is attached. I then tie wrap the hose to the ARB to keep it out of the way of any wheel turning movement.
    I think this is one of those times when a picture is worth a thousand words! I'll see if I can get the digital camera out in the next couple of days and post a pic.
    It has really helped cool the rotors down and (along with upgraded pads and fluid) I don't get brake fade at the track anymore.
