News
Rolling Road - 355. Is it worth it ?
Discussion in 'Technical Q&A' started by ferrari355gtb, Oct 29, 2004.
  1. ferrari355gtb
    ferrari355gtb Formula 3
    Nov 3, 2003
    1,600
    R
    Is it worth taking my 355 (96 2.7 manual) to a rolling road ? Is there anything they can adjust on the car to make it run smoother/faster/efficiently ? (or is all taken care of through the ECU's - and they need reprogramming)
    Used to be able to take my old carb'd/injections/turbo'd cars to the rolling road and see significant gains (both power and smoothness) afterwards. Has technology moved on now that there is much a mechanic can do versus a computer programmer ?
    Rick
  3. ferrari355gtb
    Nov 3, 2003
    1,600
    R
    Bump.
    Anyone ?
  4. JSL
    JSL Formula 3
    Jan 5, 2002
    2,212
    California
    J.S. Leonard
    Sorry, I'm not familiar with the term "rolling road". What exactly do you mean?
    I take my car (97 GTB) on a foothill twisting, rolling road all the time. It is great fun!
  5. malibumk
    malibumk Karting
    May 14, 2002
    167
    Malibu, CA
    Mike Klein
    Scott:
    Rolling Road means Raer Wheel Dynomometer.....to measure rear wheel power. Often used for tuning.
  6. Aircon
    Aircon Eight Time F1 World Champ
    Jun 23, 2003
    87,211
    Melbourne, Australia
    Peter
    Talking strictly as a novice, i'd say there would be no advantage in doing this. AFAIK there is nothing to adjust. It's not like the good old days. I had a sync done of my inlet butterflies once, which made my car idle a bit better, but that's about all you can do, and you don't need a dyno for that
  8. JSL
    JSL Formula 3
    Jan 5, 2002
    2,212
    California
    J.S. Leonard
    Thanks, I have never heard that term.
  9. T0nyGTSt
    T0nyGTSt Karting
    Jul 31, 2004
    196
    Dynos are useless for cars with a standard non-programmable ECU.
    T.
  10. f355b
    f355b Formula Junior
    Jan 23, 2004
    445
    Little Silver,NJ
    the spark plug idea looks good, do a search.
  11. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    Chassis Dyno's are a good way to wear, break, stress and/or overheat stuff. They're only good for very brief tests, (10mins per hour?) and keeping road testing to a minimum if local road conditions are not suitable.
    Even for engine tuning, they're only mildly helpful for setting a benchmark. On road dynamics of airflow and engine bay thermodynamics change many variables.
  13. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    There's no point putting your 355 on the rolling road, as you say rolling roads were used for tuning / re-jetting carbs - back in the seventies I spent a couple of years with Webber Uk / Ferrari developing the best carb set-up on the earlier Ferraris using a rolling road, and as Phil says, we spent more time replacing headgaskets on cooked engines that re-jetting!!
  14. T0nyGTSt
    T0nyGTSt Karting
    Jul 31, 2004
    196
    If you run an ECU like a Motec (no doubt Phil is aware of) - a dyno run then followed by a road tune is probably going to be the best.
    But of course, you need to evaluate if you need a programmable ECU.
    T.
