Rolls Royce Ghost performance | FerrariChat
Discussion in 'British' started by absent, Jul 21, 2009.
  1. absent
    absent F1 Veteran
    Nov 2, 2003
    8,810
    illinois
    mark k.
  2. JM4re
    JM4re Formula 3
    Aug 21, 2006
    1,022
    Nothingcouldbefiner
    JPM
    #2 JM4re, Jul 21, 2009
    I still do not understand an 8-speed gearbox on a luxury sedan that produces high-torque at low engine speed. 575 foot-pounds at 1,500 rpms. Fantastic, but won't that make it constantly shift from one gear to another? I honestly don't get that.
  3. absent
    absent F1 Veteran
    Nov 2, 2003
    8,810
    illinois
    mark k.
    Talked to one of the development guys recently and he claimed that the car is not just about performance,the "waftability" factor is not affected negatively but rather even more enhanced then the Phantom's.
  4. Townshend
    Townshend F1 Veteran
    6,677
    Chicago
    Walter
    It is a bit excessive..wonder how it will drive. Anyone make it out to the NYC preview a few months ago?
  5. JM4re
    JM4re Formula 3
    Aug 21, 2006
    1,022
    Nothingcouldbefiner
    JPM
    #5 JM4re, Jul 22, 2009
    Don't get me wrong, I love the car. I guess I'm just looking at it from a long-term perspective. I want them to remain reliable and at the top and I'm fairly certain modern owners of the Ghost will have no problems. But as we can recall, the older saloons put out similarly alarming figures of torque at very low RPMs, but they used 3 and 4 speed auto gearboxes which make sense to me. All the thrust is on the low end of the spectrum, so shifting is minimally required, but with 8 gears and torque maxing so low in the range, won't the transmissions be constantly moving between gears? As I say, I'm sure they will be silky smooth for modern years, but at what cost to keep them that way and how long-term reliable is that to be? Just a curiosity.
    Did not see the NYC preview, however over Memorial Day weekend in Atlanta they did have a preview of the car for current RR owners. With its stablemates -- the Coupe/Phantom/Drophead.
  6. JM4re
    JM4re Formula 3
    Aug 21, 2006
    1,022
    Nothingcouldbefiner
    JPM
    #6 JM4re, Sep 11, 2009
    Meant to post this earlier. RR emailed me this last Sunday. For those that are intrigued by the Ghost, like myself, here are some official stats on it --
    Dimensions
    Number of doors / seats 4 doors / 5 seats
    Vehicle length 5399 mm / 212.6 in
    Vehicle width 1948 mm / 76.7 in
    Vehicle height (unladen) 1550 mm / 61.0 in
    Wheelbase 3295 mm / 129.7 in
    Turning circle 13.4 m / 44.0ft
    Track, front 1622 mm / 63.9 in
    Track, rear 1660 mm / 65.4 in
    Width at shoulder height, front 1510 mm / 59.4 in
    Width at shoulder height, rear 1418 mm / 55.8 in
    Leg room, front 1060mm / 41.7 in
    Leg room, rear 1075mm / 42.3 in
    Head room, front 1030 mm / 40.6 in
    Head room, rear 990 mm / 39.0 in
    Boot volume (DIN) 490 ltr / 17.3 cu ft
    Fuel tank capacity 82.5 ltr / 18.15 Imp gal
    Weight
    Unladen weight (DIN) 2360 kg / 5203 lb
    Unladen weight (EU) 2435 kg / 5368 lb
    Axle load ratio, rear (unladen) 48.20%
    Gross vehicle weight 2940 kg / 6482 lb
    Payload 580 kg / 1279 lb
    Axle load limit, front 1445 kg / 3172 lb
    Axle load limit, rear 1575 kg / 3472 lb
    Engine
    Engine / cylinders / valves V / 12 / 48
    Fuel management Direct injection
    Displacement 6592 cc / 402.3 cu in
    Stroke 88.3 mm / 3.48 in
    Bore 89.0 mm / 3.5 in
    Power output @ engine speed 563 bhp / 420 kW / 570 PS @5250 rpm
    Max torque @ engine speed 780 Nm / 575 lb ft @ 1500 rpm
    Compression ratio / fuel type 10:0 / premium unleaded²
    Transmission
    Transmission type ZF 8HP90
    Transmission ratios
    1st / 2nd / 3rd / 4.717 / 3.143 / 2.106
    4th / 5th / 6th 1.667 / 1.285 / 1.000
    7th / 8th 0.839 / 0.667
    Reverse 3.317
    Final-drive ratio 2.813
    Steering & brakes
    Steering type Rack & pinion, speed-sensitive variable-rate power assistance
    Steering wheel revolutions lock to lock 3.1
    Steering ratio 19.9:1
    Brakes front / diameter Ventilated disc / 410 mm / 16.1 in
    Brakes rear / diameter Ventilated disc / 402 mm / 15.8 in
    Aerodynamics
    Drag Cd 0.32
    Drag Cd x A 0.863 m2 / 10.6 ft2
    Performance
    Top speed 155 mph / 250 km/h (governed)
    Acceleratation 0-60 mph 4.7 sec
    Acceleration 0-100 km/h 4.9 sec
    Acceleration 0-1000 m 23.1 sec
    Acceleration 1/4 mile To be confirmed
    Fuel consumption
    Urban 20.5 ltr/100 km / 13.8 mpg (Imp gal)
    Extra urban 9.6 ltr/100 km / 29.4 mpg (Imp gal)
    Combined 13.6 ltr/100 km / 20.8 mpg (Imp gal)
    CO2 emissions 317 g/km
    Exhaust Emissions standard EU5
    Wheels
    Tyre, front Goodyear EMT 255/50 R19 103Y
    Wheel size, front 8.5" x 19
    Tyre, rear Goodyear EMT 255/50 R19 103Y
    Wheel size, rear 8.5" x 19
    Wheels (option)
    Tyre, front Goodyear 255/45 R20 101Y Summer
    Wheel size, front 8.5Jx20 EH2+ IS25 Alloy Wheel (width 255 mm)
    Tyre, rear Goodyear 285/40 R20 104Y Summer
    Wheel size, rear 9.5Jx20 EH2+ IS33 Alloy Wheel (width 285mm)
    Filling capacities
    Radiator incl. heater / engine oil 17.2 ltr / 10.5 ltr
    Transmission fluid / final-drive fluid Lifetime filling
    And a beautifully-produced film of the car can be viewed here
    http://www.rolls-roycemotorcars.com/#/ghost/film/
  7. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    #7 jimangle, Sep 11, 2009
    My guess for using an 8 speed auto is for extracting the most performance and fuel efficiency out of the car.
    Merc does it with their cars by using a 7 speed auto, and it's one way to get a 4500lb or more automobile or truck to do a 4.5 to a 5.5 sec sprint from 0-60 and also get 20mpg or more while curising on the highway.
    575lbs of torque at 1500rpm is enough power to run an extremely tall gear at freeway speeds at basically an idle engine speed.
    The car will probably start out in 2nd gear, unless you're in a sport mode then it would start out in 1st. You probably won't even know the car is shifting between gears, and it might even skip gears after a time as it will probably adapt to the drivers driving style.
    Jim
