News
Rubber Torque Spacer for Window Motor Assembly
Discussion in '308/328' started by 308Dadoo, Jul 27, 2020.
  1. 308Dadoo
    308Dadoo Formula Junior
    551
    Irvine Ca
    David
    I’m prepping to repair both of my non working windows so I bought a used assembly from eBay and disassembled it to learn about the inner working and how I’ll clean it before actually removing things from the car. While taking things apart I noticed that the rubber torque spacer between the motor and the work pinion was torn. I took it apart and it is torn in several places. Hopefully you can see in the photos below.
    Does anyone know of a replacement part or do I have to fabricate something ?
    It seems that if it is torn then some of the drive from the motor is wasted on the torn spacer.
  2. 308Dadoo
    551
    Irvine Ca
    David
    I’m going to buy a section of 1” diameter rubber cord and try to make a couple of duplicates.
    Mike Tuason and I think they have to have the correct durometer to act as a shock absorber when the window hits its limits.
  3. mike32
    mike32 F1 Rookie
    May 13, 2016
    2,788
    Uk
    These are a common part in engineering, just need to find a maker
  4. kiwiokie
    kiwiokie Formula Junior
    Aug 19, 2013
    885
    Tulsa, OK
    If the rubber is still soft could you not repair the tears with superglue? It seems to work well bonding rubber to itself.
  5. Hinecker
    Hinecker Formula Junior
    Mar 14, 2011
    341
    Afternoon all,
    I would go that route too, can't be that hard to fabricate. They sell gasket cutting tools, which is nothing more than several sizes of cutting punches.
    If you have a drill press, you can apply pressure to the punch in an efficient way... of course the drill is not running, just use it as a press.
    Just an idea.
    John.
  6. 308Dadoo
    551
    Irvine Ca
    David
    Well aware of the fabrication techniques. Don't think its an off the shelf item and don't want to make it a $100 part.
  7. mike32
    mike32 F1 Rookie
    May 13, 2016
    2,788
    Uk
    They use them as flexible couplings for electrically driven pumps, seen dozens over the years but we get them from the pump makers generally, so search flexable couplings
  8. 308Dadoo
    551
    Irvine Ca
    David
    Bought a couple of 6 inch pieces of 1” diameter Buna N rubber rod off of McMaster Carr. One piece with A 3/8” hole in the middle closest to size of the actual piece. Durometer is 70A. Seems it might be just a bit high but what the heck. I’ll make a few pieces tomorrow.
  9. 308Dadoo
    551
    Irvine Ca
    David
  10. 308Dadoo
    551
    Irvine Ca
    David
    Shore hardness (durometer) a little higher than I would like but we’ll see how it works out.
  11. 308Dadoo
    551
    Irvine Ca
    David
    BigTex and Saabguy like this.
