Scratched and marred 348 door sills: How to fix? | FerrariChat
Discussion in 'Technical Q&A' started by Husker, Mar 14, 2004.
  1. Husker
    Husker F1 World Champ
    11,786
    western hemisphere
    The sills on the 348's are so wide, they are prone to scraping and marring when you enter and exit the car. Mine are this way. What is the best solution? Just a simply re-spray? I have seen the "carbon fiber" inserts on ebay. Anyone have experience with these?
  3. bigbaddad
    bigbaddad Karting
    Oct 31, 2003
    135
    Arizona
    John Roberts
    I removed mine and sprayed them with black paint. I removed the rubber strip before painting and used contact cement to re-apply it. They look a lot better, but not perfect. But like you said, they take a lot of abuse, so I don't care. They will only get scuffed again. Good luck!
  4. Noelrp
    Noelrp Formula Junior
    Aug 30, 2001
    630
    SSF
    Noel
    They rot too. Pay attention to the outer edge, rear corner.
    The carbon fiber is a good alternative. But in time, it will get scratched as well.
    I dont know if there's a way you can avoid scratches on that area.
