SD2 diagnotics software for 550 Maranello | FerrariChat
Discussion in 'Technical Q&A' started by Terence, May 13, 2015.
  1. Terence
    Terence Rookie
    May 13, 2015
    13
    Seoul, South Korea
    Terence Lim
    I have a 2002 Ferrari 550 Maranello in South Korea. I am looking for SD2 diagnostics software for 550 Maranello.
    The local dealer refuses serrvicing my Ferrari as it was imported before the local official deal was set up. My car has not been driven much and it has around 19,000 km on it. Recenly, the suspension warning signal comes on whenever I start driving it although it goes out when I stop the engine, wait roughly 10 min and restart it. I think I need to check the suspension related ECUs. My car does not have the OBD but it has four sockets (I think) which are marked engine, immobilizer and two unmarked ones. The repair shop nearby does have the SD2 but not the complete set of diagnotics software (I think). It has the diagnotics options of engine, anti-lock brakes, running loss, multi-spia (?), and a couple of others without the suspension. I wonder if anyone can help me locate the software for SD2 550 and identify which socket I should use to check the suspension. Thanks.
  2. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,506
    Somewhere, anywhere
    Eddie B
    It's behind the fuseboard in the passenger footwell. If they have an SD2 that does Maserati cars (the blue unit) you can look at your suspension using 3200 software. If they have the Ferrari SD2 (red unit) they can use 355 suspension software to check it...
  3. Terence
    Terence Rookie
    May 13, 2015
    13
    Seoul, South Korea
    Terence Lim
    Thanks. I will try it.
  4. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    I just bought one for my Maserati. the same co. has an sd3 for sale $30,000 that is a hard nut to crack.
  5. Terence
    Terence Rookie
    May 13, 2015
    13
    Seoul, South Korea
    Terence Lim
    Eddie, F355 program worked well with 550 suspension ECU. The problem was front right actuator rotated. My mechanic straightened the wire and the error was deleted. I need to find a way to stop actuator rotation. Do I need to replace the shock mount? I heard that 550 shock mount's peripheral balls tend to get worn off and make the acuator rotate. Or should I just put an aluminum panel or something to prevent it from rotating.
    My mechanic also told me that he could not read the airbag ECU with SD2. Is it mostly like the airbag ECU burnt?
  6. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,137
    Bay Area Calif.
    Dave
  7. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    Anyone on Ferrarichat have an SD3?
  8. Rifledriver
    34,122
    Austin TX
    Yes.
  9. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    That reasonable?
  10. Rifledriver
    34,122
    Austin TX
    Don't know. I have had mine for years and I am sure the market changes.
    You need to talk to the people selling them, not the owners.
  11. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    In Canada. Any suggestions. I called Eurospares. They are looking
  12. Rifledriver
    34,122
    Austin TX
    Canada may be the only source left.
  13. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    I am at. SD2 $8,000. SD3 $30,000
