SD3 Tester | FerrariChat
SD3 Tester
Discussion in '360/430' started by srosen, Oct 19, 2009.
  1. srosen
    srosen Rookie
    Oct 24, 2005
    2
    #1 srosen, Oct 19, 2009
    I have recently received a SD3 tester, this is the second unit since the first was purchased some time ago and had a timer which counted down every thirty days and sometimes I would wait 60 days plus to get new subscription but enough of that. I would like to know if anybody has successfully used the SD2 emulation mode I do have a SD2 tester and have no issues with it but would like to be able to print documents as well as have the ability to use the SD3 in this mode for earlier cars I do realize I need to use serial port and the last tester I had I spent many hours without success of using this mode.
    Thanks in advance,
    Stewart Rosen
  2. Nick
    Nick Formula Junior
    Sponsor Professional Ferrari Technician
    Oct 31, 2003
    506
    Nick Scianna
    Common communications problem in the SD2 emulation mode. Word of advice, hang on to your SD2. It is getting difficult to keep SD3'S running.
  3. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    #3 rustybits, Nov 18, 2009
  4. Diablo
    Diablo Formula Junior
    RS232 has to be used with the #7 cable bundle.
    Emulation works.
  5. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    The use of the RS232 isn't the issue. The issue is that the pc SD2 program won't read off the software list from the tester, although it aknowledges that it's hooked up. I had exactly the same problem with mine, and i tried it on 3 RS232 equiped laptops. i eventually got mine going by wiping the tester and re-installing everything and also the PC software. That was several months ago and i haven't had a problem since. This isn't the fist instance i've heard about relating to the porting software.
  6. Diablo
    Sorry, my mistake.
    I use emulation from pc to sd3 via cable 01-serial com port
