Setting valve installation height? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Dave rocks, May 13, 2016.
  1. smg2
    smg2 F1 World Champ Sponsor
    Apr 1, 2004
    16,518
    Dumpster Fire #31
    SMG
    I understand that tolerances can stack up and cause measurement issues. It may seem arbitrary that the keeper groove has no relation to the tip but it does as all the valves are the same, the keeper groove is not arbitrary. Measuring the gap per the WSM is indeed the quickest way, but if you're concerned with angles then my suggestion of basing it off the spring seat would negate that issue all together, however you would need a known good base measurement to compare to. easy enough, measure the center valve with both methods, from base circle of the journal and if it's within spec then the tip to spring seat can be used as a baseline. accurate to 3 or 4 places? no but it's an option.
    Or make a journal tool with indexing stops and three holes for each of the valves, then you can reasonably measure the center-line of each.
    Ferrari WSM leave a lot to be desired, a lot.
  2. Dave rocks
    Dave rocks F1 World Champ BANNED
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    SMG, changing the seat or key groove will effect the spring force, but it will be moot as the springs are not that accurate to begin with. The valve install height is a relationship to the cam and lifter function. I get what you are saying but it's just not the proper datum to use.
  3. magnesium
    magnesium Karting
    Nov 15, 2003
    51
    A bit of moral support for Dave as I believe that his understanding of the problem is correct! Dave - you're absolutely not over-thinking this.
    My response is only a guess but I think that JohnK is correct when he says "Perhaps the measurement should be made along the axis of the valve?"........ simply because this is the ONLY way for such a specification to make sense. I'm guessing that the factory tool for setting this has holes drilled at 3.5 degrees to match the angle of the valve in that plane. I'm also guessing that the base circle on the factory tool is inclined (as it is on the camshaft) at the corresponding angle. If it wasn't, then zeroing your dial gauge on the tool would present you with the same problem. This given, it's not a ten dollar tool.
    Although I'm stressing that this is a guess, I can't see any other valid way of measuring the spec. It must be along the axis of the valve to make sense.
  4. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    Both Johnk and magnesium understand what I'm talking about. Many somewhat brush off this like it's second nature yet at the same time I can't locate details or pictures of the tool in use for this application. I'd venture this is not as universally understood as some like to suggest.
  5. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    29,429
    socal
    Maybe it has multiple holes as needed or lazy ferrari cuts one hole and it is close enough. Ferrari is not as high precision as we think they should be. Perhaps the factory tool is like the mythical steager tensiometer?
    Instead of making a $10 simulation of the factory tool with one hole as implied earlier why not cut a solid lifter blank to simulate a collapsed OEM hydralic lifter and do the math for clearance needed? Then measure the solid lifter blank to your oem cam shaft and cut the valve tip accordingly? Could be a new tool for StickyRX.
  6. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hi Carl,
    Much more to come. I will be fully modeling this and designing a tool. Stay tuned. But, due to my busy schedule this won't be happening over the next few days but it will be done and it will be done right :)
  7. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    Ok, so I recently acquired some factory tools and one of them is the valve height installation tool. I loaned it to a friend working on his heads. First, the tool only works for the exhaust valves. For the intake valves, the cam journal is smaller and while the tool has a diameter to match in the middle, it can't fit.
    I still also have not had a chance to design something for the angled intake valves, but I will. I'm confident that most are not actually measuring valve installation height for the angled intake valves.
  8. ago car nut
    ago car nut F1 Veteran Silver Subscribed
    Aug 29, 2008
    5,552
    Madison Ohio
    David A.
    What about computing the angle with trigonometry, and converting the dimension?
  9. johnk...
    johnk... F1 World Champ Owner
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    How big is the angle? Looking at the cam lobe drawing it only looks to be a couple of, maybe 3 degrees.
  10. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    You can't because first off, you need a way to get an indicator to the dead center (axis) of the valve. A tool must be made to measure collinear to the valve axis.
  11. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    John - look thru the thread, I measured it and posted above.
  12. johnk...
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    Ok, so 3.5 degrees would give a corrections factor of 1.00187. That is if you measure perpendicular to the cam axis the length measure alone the valve stem axis would be greater by a factor of 1.00187. So the measurement perpendicular to the cam axis would be 17.437 to 17.737. Of course, then you have to worry about having the tip of the gauge centered on the valve stem.
  13. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    John - see the layout I did. More than the total tolerance is taken up but the valve angle. Look at the layout and let me know if you agree.
  14. johnk...
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    Agree. That's why I said
    The difference between placing the tip of the gauge on one side or the other side of the valve stem tip would be roughly 6mm x sin (3.5) = 0.366mm
  15. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    Yes, I saw your comment after (reading from phone). Yep - .366mm is the .014 as shown in my layout. I wish I had the time to stay on this to design and build something for Tom to use now, but I really don't.
  16. taz355
    taz355 F1 Veteran Owner Silver Subscribed
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Dave what about using an old valve guide cutting it to a close height maybe 50 thou then you could slide it over the valve stem and use a feeler gauge to gauge how much to trim to get it in spec?
  17. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    Grant, I think you mean old valve, not valve guide. The valve tips are down inside the lifter bores. No way to get down there.
  18. taz355
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I assumed head was off and cams are in since you would be grinding all the new valves you install.
    You would just slide the valve through main guide into modified guide and up towards cam.
    Then you would turn cam and use feelers to get correct length of valve.
    Or am I thinking wrong??
  19. taz355
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I guess you were wanting to check existing?
  20. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    Yes you are thinking wrong. First, the valves register on the seats, not the guides. Second, you cannot gain access as I posted prior.
  21. Merlin Auto Group
    Merlin Auto Group Formula Junior BANNED
    Nov 18, 2016
    397
    Atlanta
    This is Wade Williams.
    Dave I have a tool for 355 heads and can tell you how to use it. I have rebuilt many 355 heads and have not had any issues.
    It is not in the manual and I came up with this tool and set up to save time.
  22. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hi Wade - I'd love to see it. I see it appears you left FoA?
  23. Merlin Auto Group
    Nov 18, 2016
    397
    Atlanta
    I have left to run the shop for *****************.
    Call me and I'll explain it.
