Shell Helix Ultra 5-40 vs Mobil 1 0-40 | Page 4 | FerrariChat
Discussion in '360/430' started by MalibuGuy, Jun 19, 2008.
  1. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    When I first got my car I had the same question about the oil. I did a very extensive research on this forum but I save some time and just pm on of the sponsors here, Norwood Performance. They took the time to explain why RedLine is the best for my car. Also Brian recommend it, so if two of the best consultants here reconends RedLine why I should get other brand? Two years with RedLibe and just great results.
  2. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    What are they good results you have had ? noone has reported bad results from any synthetic ...why aren't you using Redline in your daily driver. that suffers more of abuse daily
  3. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    this is what I think... Oil naturally gets thinner as temperature rise. additives are added in the oil to stabilize the viscosity so it wont get too thin when it hits(100c). Thinner oil(0w40) contains more additives to prevent it from getting thinner, thicker oil(20W40) requires less additives because it is thick to start with. I think people chose 10w40 over 0w40 because it contains more oil and less additives.
    please correct me if I am wrong
  4. ChuckStyl5
    ChuckStyl5 Karting
    Mar 28, 2004
    180
    The Armpit
    Scuderia and 599 get 10w-60 from the factory and the oil pump is external of the engine block
  5. av2
    av2 Formula Junior
    May 22, 2008
    478
    S. California
    I would just use the factory recommendations as there is no need to over analyzed this. I am sure Ferrari has this figured out when they build this car plus they printed in the manual.
  6. Uomo360F1
    Uomo360F1 Formula Junior
    Aug 24, 2007
    488
    #81 Uomo360F1, Aug 18, 2010
    The above post is perhaps the one M1 users need to look at.
    I just checked and confirmed that Mobil 1 has been reformulated, and "de rated" to group III in the oil category. Oils rated group 3 are NOT 100% synthetic.
    I have been using M1 for many years, and this is really bad news. Will now switch to Redline on my SF car.
  7. DonJuan348
    Aug 5, 2008
    4,442
    Taxing Jersey
    darn i just did an oil change mobile 1 where can you find this rating because now all my cars will only have group 1 oils
  8. av2
    av2 Formula Junior
    May 22, 2008
    478
    S. California
    Can you provide this information or a link to it?
  9. bmw550i
    bmw550i Karting
    Feb 1, 2008
    208
    just ordered a case of valvoline 5-40 fully syn for my 430 ... is that realy synthetic or is that bull too?
  10. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    6,047
    Well after some further research I want to re-visit the original question of Mobil 1 0-40 vs Shell Ultra Helix 5-40.
    I was able to look up the viscosity specs of both oils at 40C and 100C.
    They are identical. In other words, I think you can use either.
    Some say that the Shell oil foams too much which makes reading the dipstick difficult.
    Mobil 1 may also foam a bit, though.
    One F-Chatter blamed Mobil 1 for his engine and head failure.
    Another F-Chatter says that Mobil 1 is not "Fully Synthetic".
    Perhaps AEHAAS can comment.
  11. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    Mobil 1 is not 100% synthetic, it is only made from partial synthetic stock.
  12. MalibuGuy
    Sep 18, 2007
    6,047
    I think that you are right and we should use the thinnest oil when starting with a cold engine.
  13. MalibuGuy
    Sep 18, 2007
    6,047
    If this is true, then when should it be changed. 4K-5K miles?
    I usually change my oil every 4-5K miles.
  14. lilleprins
    lilleprins Formula Junior
    Apr 19, 2010
    446
    Torslanda , Sweden
    Anders T.
  15. MalibuGuy
    Sep 18, 2007
    6,047
    Thanks. I ve seen this test too.
    The problem with most of these tests and comparisons is that the Ferrari engine is a much more powerful high revving engine. I don't know what the test results mean for a Ferrari.
    From my own experience using Mobil 1 in my Mercedes CL- the engine is still great after 230K miles (all my own). So in a lower revving engine, this Oil is excellent. I don't put in thicker oil in an older engine since I'm still running 0-40.
    Sceptical about the Small Oil producers vs Conspiracy theory about the Big Oil producers?
  16. MalibuGuy
    Sep 18, 2007
    6,047
    Decided that thinner was better and put in Mobil 1 0-40.
  17. MalibuGuy
    Sep 18, 2007
    6,047
    Mobil 1 0-40 Measurements
    Cold Engine
    70- 90 pounds/in at Idle RPM
    After 5 minutes < 70 pounds/in at Idle RPM
    Hot Engine
    30-35 pounds/in at Idle RPM and 70-90 pounds/in at 6500 RPM
  18. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    #93 Need4Spd, Sep 6, 2010
    Interesting article. Sure makes Royal Purple look good. What the test doesn't measure is how well it continues to protect at high temperatures and how slowly or quickly it breaks down over time and stress, not to mention how effective its detergent and other additives. Nonetheless, I've had good experiences with RP products and may go that route at the next oil change. They do make it in the recommended weights. Be prepared for a bit of shock when you see the oil for the first time. It really is purple, not the usual honey color.
    I will probably stick with the factory recommended 5w-40 range. The engine's clearances I suspect are rather tight, so I don't want to go too light with 0w, and at 5w base, a synthetic oil flows plenty good at the moderate temperatures we see here in California.
    Many people don't drive their cars more than 7500 miles a year, but I like to change my oil somewhere between 5000 and 7500 miles if I did, or at least once a year along with brake and other fluids, regardless of mileage. In most cars, the transmission fluid is the exception to annual changes, but most cars don't have their transmissions nestled so close to the headers, so for me, that will get changed out annually, too.
  19. AceMaster
    Feb 6, 2009
    34,785
    Ontario, Canada
    What is the reason Royal Purple will not release any technical data/specs about their oil? That is one reason I will not use it.
  20. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    That's a good point. I don't know.
  21. riggaz
    riggaz Rookie
    Jul 29, 2009
    6
    Mobil 1 0w40 and Mobil 1 10w60 are mostly group 3 synthetic with some group 4
    Mobil 1 5w-50 and Mobil 1 15w50 are 100% PAO (apart from the usual amount of mineral oil to dilute the additives)
  22. riggaz
    riggaz Rookie
    Jul 29, 2009
    6
    Usually it's to do with ambient temps
  23. riggaz
    riggaz Rookie
    Jul 29, 2009
    6
    This test is a bit of a red herring as it is completely non representative of what is going on inside an engine.
    Also the tests were done with different viscosities so they cannot be compared to eachother.
    I would ignore this test if i were you
  24. RBK
    RBK F1 Rookie
    Jul 27, 2006
    3,105
    Calif and Nev
    Bob
    With all these posts there is not one "controlled" study evident that definitively directs anyone to any place. Why? Because ot does not not matter which synthetics you use, they all work fine. Cars running hundreds of thousands of miles prove it. Additionally, as someone who has raced all types of cars for 25 years, when we break down the motor's you have know idea which synthetic was used or interchanged. The important thing is to keep the oil at the recommended fill level, keep it clean and always change the filter when changing oil. When was the last time anyone on this thread lost a motor because they used Mobil, Redline, Shell, Quaker State?
  25. MalibuGuy
    Sep 18, 2007
    6,047
    I read that Mobil 1 0W-40 is synthetic PAO.
    Perhaps the group 3 rating applies to other Mobil 1 products?
