Shift indicator not working 360 f1 | FerrariChat
Discussion in '360/430' started by clean512, May 30, 2020.
  1. clean512
    clean512 Formula 3
    2,029
    Josh @jtcarprojects
    so my shift indicator stopped working but the outside temp still works when you scroll thur the options on the dash buttons. Could the gauge cluster finally had its last leg or should I be checking somthing else. Car is a 99
  2. brogenville
    brogenville Formula 3
    2,020
    Robin
    If you had a scan tool that could view live data on your instrument cluster, you could tell if it’s getting the signal for which gear it should be displaying. If it is, it’s a good bet the issue is with the led display in the cluster. The little Autel AP200 can do this.
  3. clean512
    clean512 Formula 3
    2,029
    Josh @jtcarprojects
    Would you happen to no where the sensor on the tranny to tell witch gear its in
  4. vrsurgeon
    vrsurgeon F1 World Champ
    15,920
    Charleston, SC
    Curt
    Did you check the fuse and make sure it's not blown or loose? (front trunk)
  5. clean512
    clean512 Formula 3
    2,029
    Josh @jtcarprojects
    Yep fuses are good
