Shifter spacer/gasket CAD design | FerrariChat
Discussion in '456/550/575' started by rhern213, Mar 18, 2021.
  1. rhern213
    rhern213 Formula Junior
    Jan 8, 2021
    576
    Miami, FL
    Richel
    Hi All,
    I recently removed the shift gate on my 550 and encountered a disintegrated spacer/gasket. I did manage to order one from Ricambi, part #168955, but I didn't know if they would be able to get one at all so I had a friend draw up a CAD design for me just in case. I wanted to share it with everyone in case somebody would like to use it. The parts are identical for the 550/575, but not sure if they would properly fit a 456 or some others. For reference the general dimensions of the part is 103x76x12 in mm.
    Below are pics of the broken piece, the new part from Ricambi, and the CAD design links.
    https://drive.google.com/file/d/1v1N4FO9Pxuxwu1OW_uNTuA_nbKM-Sk_L/view?usp=sharing
    Hope this gets some use!
    brogenville, dsd, NE550 and 3 others like this.
  2. tantumaude
    tantumaude Formula Junior
    938
    Burlington, Canada
    Mat
    Very kind of you!
    rhern213 likes this.
  3. rhern213
    Jan 8, 2021
    576
    Miami, FL
    Richel
    #3 rhern213, Mar 18, 2021
    Forgot to mention, the file is an STL format ready for 3D printers.
    And here's a quick sketch of the dimensions.
    dsd, Mirek, brogenville and 1 other person like this.
  4. Qksilver
    Qksilver F1 Rookie
    4,328
    Philadelphia
    Joe
    brogenville and rhern213 like this.
  5. brogenville
    brogenville Formula 3
    2,020
    Robin
    Brilliant - this is an ideal application for a 3d printer. Top work! :)
  6. Aerosurfer
    Aerosurfer Formula 3
    1,304
    Indianapolis
    Nick
    My spacer is in pieces... 95 456. Any consensus if the 550 one will fit or has anyone tried to 3d print?
  7. brogenville
    2,020
    Robin
    Bolt hole spacing is the same. Worst case you would need to trim the edges. If you have a 3d printer or know someone that does, then the cost to make one is pennies. Might as well try?
  8. Aerosurfer
    1,304
    Indianapolis
    Nick
    Thanks i do know someone to ask.. how do i open that file above? I downloaded it, but wont post (at least on my phone)
  9. Jaguar36
    Jaguar36 Formula Junior
    Nov 8, 2010
    841
    Cherry Hill, NJ
    You'll need to open it in a slicer program (like Cura), or at least in a CAD program.
  10. Aerosurfer
    1,304
    Indianapolis
    Nick
    Being printed now by a friend! The link worked fine still. Will post results in a few days
  11. dsd
    dsd F1 Rookie
    Nov 19, 2006
    4,191
    Northern Virginia
    Care to publish on Thingiverse or PrusaPrinters?
  12. Aerosurfer
    1,304
    Indianapolis
    Nick
    Well this was a total success!
    The above file printed very nice and on my 456GT lined up perfectly, screw holes and all.
    If there was any critique, its that a very small portion is visible in the reverse notch. It doesn't interfere at all with operation. It was printed in a light color and i was worried it would be too easily seen, but really its not at all noticeable.
    I can make a small run of these available if there is any interest. Next version would likely be in a darker color or painted
  13. rhern213
    Jan 8, 2021
    576
    Miami, FL
    Richel
    #13 rhern213, Jan 20, 2022
    Awesome great to see it worked!
    Upon closer inspection now, looks like Ferrari changed the shift gate design between the 456 and 456M. Where the later model 98+ 456M uses the 550 shift gate. The earlier model 456 has a shift gate with a thinner left side wall. Since the design is based on the 550 that's why it's thicker than your gate.
    Interesting to see the cavallino design is also different.
    In any case you can just sand it down thinner so it looks better.
  14. Aerosurfer
    1,304
    Indianapolis
    Nick
    I want to say I will trim that edge down or possibly just cut out that section, but unless it really drives me nuts or catches my eye, ill likely leave well enough alone for the time being
  15. rhern213
    Jan 8, 2021
    576
    Miami, FL
    Richel
    Looking at the example above, I think the spacer can be seen in that one as well. Maybe that's just how Ferrari did it?
    Anyone else with an early model 456 chime in if their spacer is visible as well?
  16. dsd
    dsd F1 Rookie
    Nov 19, 2006
    4,191
    Northern Virginia
    Please tell me ABS, ASA, PETG, or another appropriate filament was used. If it was PLA, please reprint as PLA will deform/melt/sticky in summer cabin temperatures.
  17. Aerosurfer
    1,304
    Indianapolis
    Nick
    Thank you, it was PLA.... ill see what alternatives i can eventually come up with, butni have a few months to run it for now
  18. dsd
    dsd F1 Rookie
    Nov 19, 2006
    4,191
    Northern Virginia
    PETG or ASA are easy to print and cost about the same as PLA and should work fine.
  19. fatbillybob
    Aug 10, 2002
    26,430
    socal
    Awesome for 550 owners!
    thanks richel!
  20. dsd
    dsd F1 Rookie
    Nov 19, 2006
    4,191
    Northern Virginia
    As for the thickness differences on the 456 vs 456M, in your 3D printer slicer you can cut the bottom 6-10mm(?) off.
