Shifting too soon? | Page 2 | FerrariChat
Shifting too soon?
Discussion in 'Technical Q&A' started by BLAMPEE, Jan 14, 2011.
  1. tazandjan
    tazandjan Three Time F1 World Champ Lifetime Rossa Owner
    39,417
    Franklin- Low revs will not cause clutch wear as long as the revs are matched. Same with high revs. The test for clutch slip looks for rising revs and no increase in car speed before the clutch locks up. It is done at an engine and car speed where the results are noticeable, not because that rev range is causing more wear.
    Taz
    Terry Phillips
  2. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Its not low revs that cause clutch wear; it is too low revs in a gear too high for that engine speed. A high gear at a very low engine speed places a higher load on the clutch which results in the extra wear.
  3. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    How can low engine speed place a higher load on the clutch?
    I think you are confusing what you feel when you shift with what the clutch "feels" when fully engaged. Yes, if you are trying to start the car from rest in 2nd gear you will have to slip the clutch a lot. But that is a different issue from the clutch failing to transmit the load when fully engaged.
  4. 2NA
    2NA F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I think the OP was just talking about "easy does it" driving at part throttle. Pretty low wear and tear on things that way.
    If the clutch is shuddering or the engine is lugging you're doing it wrong.
  5. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,774
    A clutch suffers NO wear when fully enguaged; just like brakes suffer no wear while cruising donw the interstate at a constant velocity. The only way for a clutch to suffer wear is if the two disks are slipping.
    THus, idiot drivers can suffer clutch wear by trying to use a numerically high gear than corresponds to the rotatioial rate of thw eheels and holding the clutch partially enguaged to keep the engine from blucking.
    But if you foot is off the clutch pedal, the healthy clutch is suffering no wear.
    For me, in my F355, I can use 6th gear down as low as 1150 RPMs, a slow gentle prod on the gas pedal and the engine picks up speed smoothly.
  6. BLAMPEE
    BLAMPEE Man Card Status: Never Issued
    Jun 28, 2008
    15,424
    Sunny Heavenly Beautiful Arizona
    This is exactly what I was talking about. No need for an Italian Tune-up on a 35mph road. :)
  7. tazandjan
    39,417
    Franklin- Baloney. A mismatch of revs will wear more at a higher torque rpm than at a lower torque rpm and there is no clutch wear on an engaged clutch that is not slipping, regardless of rpm. How is something going to wear when it is locked up solidly? The clutch could care less what the engine is doing once it is engaged. That is why the engine stalls if you release the clutch too late as you come to a stop. The solid connection shuts down the engine because nothing is budging the clutch connection, even in first gear with the highest torque multiplication available.
    If that is a pet theory, it does not float. Lugging is bad for the engine, but does nothing to the clutch.
    Taz
    Terry Phillips
  8. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    Maybe in theory, as there IS friction even though clutch is fully engaged. And friction, even with a fully engaged clutch, causes wear in theory, although, may be hard to measure.
    But in reality/practical world, how much is this a factor in a clutch wear? I would gamble any day the other factors like bad clutch engagement//riding clutch/shifting too often (as opposed to moderating traffic and avoiding changing gears)/jack rabitt starts from a red light/etc etc are more to blame-by far.
  9. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    Of course there is friction when the clutch is fully engaged. But provided the clutch is working properly there is NO slip, and hence no wear.
  10. rbf41000
    rbf41000 Formula Junior
    Nov 21, 2005
    698
    Delray Beach FL
    Russell
    Good point, loss of friction is a sign of the cluch wearing out.
    Also to the OP question, lugging an engine is never good and if you can't tell by feel/sound when the engine is happy you should drive an automatic.
    Russell
  11. tazandjan
    39,417
    Crud, a clutch is all friction when locked up, but no slip is no wear.
    Taz
    Terry Phillips
  12. Jedi
    Jedi Moderator Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,402
    Seattle Area
    Dave
    AND he's pretty fond of public breast feeding I hear as well....
    :eek:
    :D:D:D
    Jedi
  13. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    Right. Thats why I said in theory. Just cuz you have no "slip", doesnt mean you have no wear. friction causes heat, and heat causes wear. You can not have heat generated without a consequence. But this type of wear is NOT noticeable. Thats why its in THEORY and not easy to actually measure or even notice.
    The causes I listed are the ones that cause noticeable wear.
