My 575 is going in for its annual service 3 to my dealer tomorrow. It’s due a belt change in October this year. (5 years since the last). Is there any reason, apart from financially delaying the inevitable, to have the belts done now rather than in March 2019? Don’t want to take it in twice this year if I don’t have to. Not planning to sell it or anything crazy like that.
Darius- Should be fine. Plus or minus 6 months is not going to affect anything. Remember your aux belts need to be changed every 3 years, so you have to decide to do that at the 2 year or 3 year point. Either way, one aux belt change will be at 2 years instead of 3.
Belts alone isn’t too bad $2500 or so here in the states. So unless you’re doing other stuff things like spark plugs or water pump I’d say just do it man, your 575 is like $400k, not worth risking it
Thank you for that. I drove the 575 to the dealer today, first drive of the year. Love that car. I drove my 430 coupe (also a gated manual) back. Great car also, but just not in the same league. They have made better cars than the 430 since they made the 430. But they haven't made better cars than a well set up Maranello, since they made the Maranello. Just different ones. It's the last V12 Ferrari to have that louche 1960s tourer feel, as well as the punch of 500+ hp.
Taz, Darius and guys, I thought at first the dealer was pulling my leg, but no, the 456 GT owner's manual does say timing belts should be changed at a "Every 36 months maximum". Now as I know the engine is essentially the same as 550 and 575, especially as far as the timing belts go, I am wondering if this would be overkill. According to the previous service documents the belts used were part numbers: 187744 Eurospares say: Ferrari 456 GT/GTA, Ferrari 575M Maranello, Ferrari 456 M GT/M GTA, Ferrari 550 Maranello, Ferrari 575 Superamerica, Ferrari 550 Barchetta, Ferrari 612 Scaglietti Are those "Kevlar belts" that should be good for at least 60 months, if not for 66 months??? And I would be crazy to allow them to replace them after only 35 months (and 8000kms) and all the related parts and labor? Was the OM saying that only because in 1993-1995 they used different (weaker?) belts? And later there was a change for the parts and service? I know the aux belts need replacing now after 3 years, but there is a significant difference in cost. And many questions I know... Cheers! Image Unavailable, Please Login Image Unavailable, Please Login
Pekka- The official word from Ferrari was the change interval was still 3 years on the 456s and 550s, but that is only because they did not do accelerated wear testing on those models with the new Kevlar belts, part no 187744. That is the only belt Ferrari has been selling for at least a decade (introduced in 2002). On a 456 GT if you have the later tensioner brackets introduced at AN 28614, most owners and independents are now using 5 years for the belt change interval.
Where does a year go? the 575 is going to my Ferrari service shop in a couple of weeks, and this time the belts are definitely on the agenda. It hasn't had plugs for 4 years. Should I ask them to change those? I'm never clear about what fluids to specify they change - gearbox fluid was last changed in 2015 (it's a gated car). Anything else "while they're in there"? Water pump? What about suspension? It's a FHP and it seems fine, but is there anything specific to check? Is there a favourable suspension geometry (toe in, camber, etc) that the car won't have already? Any advice as always appreciated.
My two pennies All fluids, shocked 4 years for the gearbox yikes! Do the belts and check / replace tensioners / bearings Do the plugs inspect the wires Inspect Check engine mounts, trany mounts and hoses etc for leaks Decision is yours on water pump mileage and leakage dependent, I am the school of thought while I am here Inspect cam seals If worried about suspension check tire wear, if it isnt broken don't fix it! Also check ball joints an bushings
575s are a bit different from 550s with coil on plug ignition and wires that only transmit a fire signal to the coils (12) and have no primary current flowing thought them. Darius- Here is a basic breakdown of service intervals, excluding all the checks that are also included in the OM maintenance schedule. 1 year Oil and filter Brake Fluid Environmental Filter 2 year Coolant if G05, longer for ELC coolants with organic acid technology additives (not in OM or any Ferrari OM through the 599) Transaxle fluid/oil Power steering fluid AC refrigerant (not often done unless there is a problem) 3 year Auxiliary belts 5 year Cambelts, most do tensioner bearings at the same time 15,000 miles Suspension alignment 30,000 miles Spark plugs (put in Iridium plugs if not already fitted)
Thanks, RJA and Taz. This gave me a reason to leaf through all the recent service history of the car. Relevant highlights: Cambelts changed 2009, 2011, 2013, 2015 (most recent) Oil, brake fluid and filter changed annually during annual service through 2018 Transaxle fluid last changed 2015 - this was a flag for me PAS fluid last changed 2015 - ditto Aux belts last changed 2015 - ditto Suspension alignment last in 2015 No mention of spark plug changes, car mileage now over 30,000 - flag Tensioner bearings last changed 2013 (unless done but not noted in 2015) According to Taz above, though, cambelts don't need changing for 5 years, ie October 2020 for me. So, is it advisable just to ask shop to do everything listed at 1, 2 and 3 years above, plus iridium plugs, but not belts? (As well as the usual?). It's an official Ferrari service centre, so they will try and go by the book on the cambelts, but while I like to keep my cars well maintained, no point spending $$ when not necessary.
Darius- Lot of money being wasted on cambelt changes. The interval was never less than 3 years for the 575M. Show this to them, and no, it is not just for US spec 575s. They can look it up themselves. It came out in 2002 when the new Kevlar reinforced belts were introduced. View attachment 2700467
Excellent stuff, thanks Taz. I will send it to them. They must hate these educated customers from Fchat.
tazandjan, would this schedule be valid also for my 2001 456m gta please? thank you Sent from my iPhone using FerrariChat.com mobile app
Affirmative, but you need to add in adjusting the tappet clearances, too. Most owners and independents use 5 years for cambelts on 456s with the latest tensioner brackets and all 456Ms.
So the 575 went in today. Reputable official Ferrari service with specialism in classic Ferraris. I said I'd just like an annual oil and filter service as per the above belt intervals are 5 years, and mine was last done (by them) in 2015. They replied belt intervals are 3 years. I sent them the PDF of the technical bulletin above. Watch this space..
Should you reconsider where to service the car with the 3 year interval comment? Perhaps they don't know the car as well as you suspect?
if it were my car id wait for sure. if you had said 5k miles a year id say do it now. at a couple hundred a year you will be fine waiting a bit longer.
The WSM says 3 years and some (many?) dealers do not seem to keep up with service bulletins. Perhaps because most centers are not in the official Ferrari service chain and do not receive the bulletins. This is not a US only change as some service centers have suggested. Since Darius' center is an official Ferrari service agent, the first would seem to be the case.
Yea, it was useful to have the actual bulletin to send them! Let's see what they say, but anyway they can't exactly make me do it.. I bet more would keep up with the bulletins if it were the other way round, more frequent changes of time consuming low cost items at huge labour rates. But I don't want to badmouth them, they have been very good. they spent days hunting around for the cause of a rough idle and slow down light on my F512M, changing various things, and even the esteemed Fchat advisors here couldn't pinpoint the cause. Had new ECU made, etc. In the end it was a thermocouple plus some other cheap part in unison, and they just charged me for that, not any of the investigation.
