Side Window Latch Repair | Page 2 | FerrariChat
Discussion in '206/246' started by fhenley, Jan 21, 2023.
  1. TTR
    TTR F1 Veteran Rossa Subscribed
    Mar 29, 2007
    6,135
    Riverside, CA
    Timo
    Reads/sounds like a perfect time to consider correcting the aforementioned, underlying manufacturing defect causing the ill-fit of the vent glass and necessitating ungainly, unorthodox "aftermarket" solutions.
  2. Edward 96GTS
    Edward 96GTS F1 World Champ Silver Subscribed
    Nov 1, 2003
    11,162
    i just a slip on? easily reversible?
  3. garybobileff
    garybobileff Formula 3 Sponsor
    Feb 5, 2004
    1,183
    San Diego CA
    Gary
    Yes sir!
    Gary Bobileff
  4. fhenley
    fhenley Karting Silver Subscribed
    Sep 5, 2022
    66
    Saratoga California
    Francois Henley
    These are nice! I understand from the pic that a U-shaped metal bracket is slipped in to give mechanical strength to the affixed latch. A counter-sunk screw holds the latch onto the inside metal plate. The back of the latch would need a tapped screw hole to be made.
    I have a few questions & comments:
    On the plus side:
    a. The approach does not involve changing the window or causing parts to be overly modified, only the tapped hole on the latch.
    b. Looks great if the metal bracket is well made.
    c. If the bracket is glued, the effect is to spread the latch stresses to the metal plate. This should be quite effective to eliminate the original issue.
    Some questions:
    a. There is a balance between the thickness of the metal & the strength of the assembly to work as intended. I assume that the metal plates would need to be glued to the glass. If not, I think the metal U bracket could easily separate under use. Can someone confirm this?
    b. Availability? Seems like there are no commercial sources.
    c. Is it easy to attach? Seems like the window needs to be removed? Any rubber mods required?
    d. The approach would not look original and if glued, may not be easily reversible.
  5. npwmd2
    npwmd2 Formula Junior
    Mar 31, 2015
    262
    Hudson Valley
    Neal
    Why does one need a latch to the side window when closing the window is maintained by the rubber gasket and it appears clean without any violation to the window. This plate is not clean and is unnecessary when one can maintain the function of the window both closed and open in the fashion the window was meant to function! Put the latches in the glovebox and forget it!
  6. fhenley
    Sep 5, 2022
    66
    Saratoga California
    Francois Henley
    Update: latch repair still holding out. Not using the latch but having it mounted there seems better than the alternative of having them in the glove compartment. Image Unavailable, Please Login
  7. Dino246gts
    Dino246gts Formula Junior Silver Subscribed
    Jun 6, 2006
    436
    Just curious as to how many Dinos, or what percentage of Dinos, have not had a latch fall off?
  8. mccand
    mccand Karting Silver Subscribed
    Mar 17, 2020
    124
    San Jose
    Greg!
    This will of course be anecdotal, but when I received my Dino in 2020 the latches were in the glovebox. Being blissfully unaware of any known issue, I promptly glued them on with 3M rear view mirror adhesive. However I did did it in such a was that there is like zero load on them when “parked” by the positioning of them, as I figured that if they came off once they might yet again. My Dino has the original window sails. I have not had any issues for the several years since that have followed, and I do use them, as does my better half, albeit I instruct for gingerly use. Hope this helps.
    MariofromBerlin likes this.
  9. TTR
    Mar 29, 2007
    6,135
    Riverside, CA
    Timo
    Your guess will be as good as anyone’s.
    I doubt many Dino vent latch “fall off’s” have been thoroughly documented and many may have suffered of it more than once, but perhaps closest way to get some idea is to count how many Dinos have any aforementioned aftermarket solution applied or latch attachment currently off its glass.
    Same with Daytonas.
    I’ve repaired the vent latch issues on most Daytonas I’ve worked on, but never resorted to these “aftermarket solutions”, hence my earlier comment about the most opportune time is during any major coach work restoration.
    I’ve never tackled this on Dinos, but since their coach work were made at Scagliettis, at the same time as and side by side with Daytonas, likely using nearly identical construction methods, I wouldn’t be surprised if similar correction efforts are required to adequately address the problem, which in Daytonas, IMO, is a “manufacturing defect/problem”.
    Dino246gts likes this.
  10. fhenley
    Sep 5, 2022
    66
    Saratoga California
    Francois Henley
    Yes I think the key here is zero load. I could not do this without offsetting the latch from the glass face by a few mms, something I did with an aluminum disc. If you can do it some other way, that is what lowers the stresses to the point where they don’t fail.
    I’d say that in the 50yrs+ for these cars, I would bet all have fallen off. During the restoration of my car, the rubber trim seemed to have placed even more force on the latch when closed. It’s just not a great mounting design and approach but “it is what it is”.
  11. Dino246gts
    Jun 6, 2006
    436
    No ...... don't bet on it. Mine are still original. I was just curious as to how many other of us are out there with original window latches, as it appears so common for them to have fallen off.
  12. npwmd2
    Mar 31, 2015
    262
    Hudson Valley
    Neal
    fhenley,
    More objectionable to me than not having a latch glued in place is the lack of the black plastic cover over the rivets! Fashion a cover and put the latches in the glovebox as most of us do and call it a day!!
  13. UroTrash
    UroTrash Four Time F1 World Champ Consultant Owner
    Jan 20, 2004
    40,742
    Purgatory
    Clifford Gunboat
  14. UroTrash
    Jan 20, 2004
    40,742
    Purgatory
    Clifford Gunboat
  15. omgjon
    omgjon F1 Rookie Owner Rossa Subscribed
    Feb 13, 2005
    3,573
    Spicewood, Texas
    Jon Gunderson
    The easiest way is too remove the latch part from the base, either slotted screw or allen head. Then grind down the head of the latch until it latches with little or no pressure.
  16. fhenley
    Sep 5, 2022
    66
    Saratoga California
    Francois Henley
    …or install a spacer as I described at the start of this thread. This will also reduce or eliminate the pressure. That way original parts are not being grinded.
  17. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,353
    Norfolk - UK
    Tony
    TBH thats looks an awful solution and I wouldnt adopt that method, shaving a few mm of the latch is barely noticeable.
    I tried quite few different ignition set ups and all gave trouble even the expensive Black stallion system. Needless to say i went with the standard dizzy and winterburn module, works great.
    Best
    Tony
    celestialcoop likes this.
  18. fhenley
    Sep 5, 2022
    66
    Saratoga California
    Francois Henley
    I guess it’s all about what you care about and hold dear. To me, grinding original parts is the awful solution - and you still have to bond the part. The spacer solution I used maintains the original part and works well. Curious though: you should post a pic of the modification.
  19. TTR
    Mar 29, 2007
    6,135
    Riverside, CA
    Timo
    I just find it interesting so many are willing spend time and effort on ad hoc/band-aid solutions, some of which look worse than others, ...
    ... instead of correcting underlying causes.
  20. UroTrash
    Jan 20, 2004
    40,742
    Purgatory
    Clifford Gunboat
    Huh? They glued a hunk of metal to some friable glass. Uncorrectable problem.
  21. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,353
    Norfolk - UK
    Tony
    No offence intended and each to their own solution. Difficult to post a pic of my solution as its such a miniscule modification that its hardly detectable. It relives excess pressure on the latch assembly / bonded joint.
    Kind Regards
    Tony
  22. TTR
    Mar 29, 2007
    6,135
    Riverside, CA
    Timo
    "Uncorrectable" sounds easy on keyboard, but it can likely* be corrected.
    *I've done it on Daytonas, which are known for same "problem" and many have claimed as "uncorrectable" without ad hoc/band-aid/Mickey Mouse solutions, so I believe it could likely be done on Dinos.
  23. fhenley
    Sep 5, 2022
    66
    Saratoga California
    Francois Henley
    I couldn’t help reading this as Anton Ego, the critic in Ratatouille.
    Edward 96GTS and UroTrash like this.
  24. TTR
    Mar 29, 2007
    6,135
    Riverside, CA
    Timo
    Edit:
  25. UroTrash
    Jan 20, 2004
    40,742
    Purgatory
    Clifford Gunboat
