Silhouette thread | Page 14 | FerrariChat
Silhouette thread
Discussion in 'LamborghiniChat.com' started by kc023515, Aug 26, 2010.
  1. 7veloce
    7veloce Karting
    Aug 19, 2010
    235
    Colorado
    Tom
    Do you still have your nice black Jalpa with Bravo wheels? I like the look of it. However, Sil is much lighter and cleaner looking car.
  2. ralfabco
    ralfabco Two Time F1 World Champ
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    I am under the impression, you can still find a driver Countach for 70K. Some claim, the 70K price is too low.
    Joey,
    That is true.
    I drove an injected Jalpa. I liked the shifter and feel.
    In addition, I would guess, a lot of enthusiastic car people, have no idea what a Silhouette is. How can you lust for a car, you do not even know exists ? Over the years, the car has obtained little coverage, from the automotive rags.
    I still cannot imagine a typical buyer choosing the Silhouette over the Countach. I am not taking anything away from the Silhouette. How many Silhouette posters were produced, with a hot girl laying on the hood ? :D
  3. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    Interesting points of view...
    the early cars did come with silhouette/urraco tail lamps, ferrero steering wheel, brake boosters plus various other drivetrain parts.
    imo the bravo wheels makes a world of difference on the jalpas filling out the large wheel wells. im not sure who was responsible P118 since gandini left about the time the silhouette was being baked. for the jalpa, its been said, deschamp thought the larger dia 16inch OZ were much too large aesthetically but the marketing guys insisted. on the athon they were 15incher shod with same tires as the silhs. i always wonder how different the japla drove with the option bravos since the suspension wasnt alter (as far as i know) for the much wider rear P7's.
    the weight difference between the two is much closer than what has been printed between the euro spec cars. I don’t have much faith in the 30 yr old published weight claims or current classic car mags with specs. Worse case comparison can come in at over 600lbs. I say its less than half of that. from what i can tell, the added weight was put to good use in adding reinforcement to scalped urraco platform.
    my 2 cents
  4. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    injected jalpa? must be aftermarket?
    i would love to hear more about it...
    cheers
    hf
  5. ralfabco
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    My mistake :D
    I forgot, the U.S. car, has a pollution-control type of box that encloses the Webers.
  6. P300V8
    P300V8 Formula 3
    Mar 8, 2010
    1,645
    London U.K.
    As part of my adjustable damper development exercise I had my LHD Silhouette corner weighed with a full tank of fuel and original wheels. Here are the results in Kgs.
    ................Left........Right....Total
    Front.........295........307.......602.....42.3%
    Rear..........403........418.......821.....57.7%
    Total.........698........725......1423...100.0%
    ................49.1%....50.9%
    Cross.........710.......713.......1423
    ................49.9%....50.1%
    Judging by the cross weights they certainly knew what they were doing!
  7. rovingtravler
    rovingtravler Formula Junior
    Feb 2, 2004
    309
    Clovis, NM
    David
    There are at least two Fuel Injected Jalpas I know of...Laust's being the most advanced with a twin turbo hooked up in serial /parallel witht he flip of a switch.
    There are also at least two twin turbo cars as well in the US.
  8. P300V8
    P300V8 Formula 3
    Mar 8, 2010
    1,645
    London U.K.
    From what I have been able to discover the Silhouette and Jalpa shared the same rear springs and dampers
    The bump/rebound data is the same for Urraco and Silhouette though there was a different part number, now combined.
    For me the key difference is the tyre diameter. This will affect the ride height, speedometer reading and at the rear the gearing. I took the following data from the web so cannot vouch for its accuracy.
    Front
    P250...........205/70 14" = 645mm diameter
    P300...........195/70 14" = 629mm -14mm
    Silhouette....195/50 15" = 576mm -67mm
    Jalpa...........205/55 16" = 632mm -11mm
    The Silhouette has a chunky spacer (perhaps 50mm) between the top mount and the wheelarch plate, presumbaly to correct the reduced ride height. I think this necessitated the use of the different steering arms on the Silhouette. The Jalpa had a fabricated steel plate between the top mount and the wheelarch plate. There were two heights, I think the the deeper one was probably used for the Jalpas with the Silhouette spring and steering arm and the shallower one with the Urraco spring. No matter. The difference in diameter between 632mm and 576mm is 56 mm or 2" which would give 1" difference in ride height at the front. What happened to the ride height of the Jalpa when the Bravos were fitted?
    Rear
    P300...........205/70 14" = 645mm
    Silhouette....285/40 15" = 609mm
    Jalpa...........225/50 16" = 631mm
    The Silhouette also has a spacer between the top mount and the top of the strut tower (perhaps 25mm) but the Jalpa has no spacer. The difference in diameter between 631mm and 609 is 22mm mm or say 1" which would give 1/2" difference in ride height at the rear.
    And then there is the final drive ratio
    P250..........4.25
    P300..........4.25
    Silhouette...4.00
    Jalpa..........4.25 (? not sure)
    Since the Urraco and Jalpa share similar rear tyre diameter I would imagine that the final drive ratios would both be 4.25. Can anyone confirm this? The Silhouette needed a different ratio to compensate for the smaller diameter tyres. So what happens when Bravos are fitted to a Jalpa?
    Hmmm....
  9. P300V8
    P300V8 Formula 3
    Mar 8, 2010
    1,645
    London U.K.
    #334 P300V8, Nov 23, 2011
    I have only seen one such period poster. Published in Australia, she was lying on the bonnet of a well known Silhouette, tanned, blonde and completely naked!
  10. BRAVO-V8
    BRAVO-V8 Formula Junior
    Dec 7, 2008
    253
    LYON (France)
    Early and late Jalpa had different springs, I will post some photo.
  11. P300V8
    P300V8 Formula 3
    Mar 8, 2010
    1,645
    London U.K.
    Perhaps you are referring to the front springs. I believe that the first 60 Jalpas had the same front springs as the Silhouette and thereafter they switched to Urraco springs. Any other information would be appreciated.
  12. P300V8
    P300V8 Formula 3
    Mar 8, 2010
    1,645
    London U.K.
    #337 P300V8, Nov 23, 2011
  13. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    what ive documented over the years
    early P250 R&T March 73 :
    1st-2.69
    2nd-2.10
    3rd-1.56
    4th-1.18
    5th-0.90
    FD 4.25
    P111 R&T 76 :
    1st-2.69
    2nd-2.10
    3rd-1.56
    4th-1.18
    5th-0.90
    FD 4.03
    silhouette R&T aug 76 :
    1st-2.93
    2nd-2.10
    3rd-1.56
    4th-1.18
    5th-0.87
    FD 4.00
    jalpa R&T nov 82 , (same as above maybe incorrect?)
    1st-2.93
    2nd-2.10
    3rd-1.56
    4th-1.18
    5th-0.87
    FD 4.00
    jalpa Car & Driver, june 86 Motor june 83, Autocar nov 86 :
    1st-2.80
    2nd-2.11
    3rd-1.48
    4th-1.19
    5th-0.87
    FD 4.00
    of course you cant believe everything you read but i reckon these numbers were
    supplied from the factory rather than taken apart and measured.
    interesting note, the P111 with the weakest motor outside of a P200 and high
    weight has the longest combine 1st gear ratio 10.84:1
    has anyone out there got a different FD and gearbox ratio?
  14. P300V8
    P300V8 Formula 3
    Mar 8, 2010
    1,645
    London U.K.
    #339 P300V8, Nov 25, 2011
    Yes I have seen these published ratios as well.
  15. roytoy2003
    roytoy2003 F1 Veteran
    Jul 30, 2004
    9,591
    Roy L. Cats
    If anyone is intrested, I know a nice Red/Tan one for sale out of a Private collection here in the States..owner is wanting $50,000.00 for it
  16. rovingtravler
    Feb 2, 2004
    309
    Clovis, NM
    David
    Raymond QV has the many differences between early and late Jalpas posted on his site jalpa.ch
    There are more than you would think.
  17. 7veloce
    7veloce Karting
    Aug 19, 2010
    235
    Colorado
    Tom
    Do you have any history on 40102? Please advise.
  18. kc023515
    kc023515 Formula Junior
    Dec 5, 2007
    600
    Belgium
    Kevin Crauwels
    Here’s a bit of #40102 early history;
    - January2, 1978 delivered to Belgian distributor Hollebecq, exterior color: Argento luna (the delivery was 4 days before the start of Brussels Motor Show, although not proven it’s very likely that this car was exhibited at the show)
    - 1986 reported as in US and under restoration, new exterior color: red
    - 1988 owned by R.S. in Michigan , photo shoot executed together with some other Lamborghini’s in front of a dealership in Detroit, pictures appeared in different publications (f.e. Atlas Editions, The great book of Lamborghini)
    - nineties: sold by R.S. to new owner
    - today: lost since many years but pretty sure it’s still alive !
  19. kc023515
    Dec 5, 2007
    600
    Belgium
    Kevin Crauwels
    #344 kc023515, Nov 26, 2011
  20. kc023515
    Dec 5, 2007
    600
    Belgium
    Kevin Crauwels
    #345 kc023515, Nov 26, 2011
    If you’ve any chance to inspect #40102 can you check if this car has an additional ID plate? This plate is mounted on the bar between rear boot and engine room (the same bar on which the body number is engraved). I would be interested to know the PVA number for the Silhouette.
  21. kc023515
    Dec 5, 2007
    600
    Belgium
    Kevin Crauwels
    Can you reveal the chassis number (#40102 ?) and/or pictures ?
  22. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    looks like the interior color has changed when it was repainted red? didnt it used to a dark strips?
  23. P300V8
    P300V8 Formula 3
    Mar 8, 2010
    1,645
    London U.K.
    The seats look original to me with the seat stripe and seat surround matching the door cards. I am less sure about the dashboard. The spoiler has the correct black painted section these days.
  24. 7veloce
    7veloce Karting
    Aug 19, 2010
    235
    Colorado
    Tom
    #349 7veloce, Nov 26, 2011
    Additional info on the car:
    - 1979 owned by J.B., PA, USA. Color: Argento luna
    - 1994-2011 owned by J.B, CO, USA. Color: Repaint in Red again with original tan leather/cloth interior.
  25. 7veloce
    7veloce Karting
    Aug 19, 2010
    235
    Colorado
    Tom
    I do not think so but I will check when I get a chance in mid week.
