355 - Silicone on paper gaskets | FerrariChat
355 Silicone on paper gaskets
Discussion in '348/355' started by alexanderfitu, Aug 30, 2021.
  1. alexanderfitu
    alexanderfitu Rookie
    May 23, 2020
    35
    Alexander
    Hi all
    In the middle of doing a Major on my 355. I have the rocker covers off to check timing etc, and have noticed that the previous mechanics have used high temperature silicone on all surfaces that use a paper gasket, in addition to the paper gasket:
    In my experience (Mercedes workshop) you never use silicone sealant in addition to an existing gasket, and especially not where there is a possibility this sealant can enter the engine oil ways. I have meticulously cleaned all the surfaces, and intend to use just Loctite 3020 spray on the paper gaskets. Can anyone weigh in?
    Much appreciated.
  3. JoeCab
    JoeCab Rookie
    May 27, 2014
    18
    Colorado
    Joe C
    I've had very good luck using Permatex Ultra Grey in addition to paper gaskets.
    However I use a specific technique - with a gloved finger I spread it on the gasket as thin as possible (so you can almost see through it) and the let it set up for a few minutes. It should still be semi-tacky but not wet. This insures there isn't any way it can squish out and clog things up, but still does an excellent job of preventing leaks.
  4. 26street
    26street Formula Junior
    Jan 30, 2021
    322
    Westchester New York
    Mark k
    Yes M/B is correct about having sealer getting in to the engine and M/B like other high cars spec the torque and clearances with a gasket being used , by a lot of top engine builders use “Honda bond” and works the best And have not had anything leaking after using it on several of my vehicles
  5. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    456
    Victoria, B.C, Can.
    John Glen Wesanko
    I also used a very thin application of Honda Bond. No problem,no leaks. Any paper gasket will have to be replaced after one use. A very thin addition of sealant will reduce the frequency of removal (because of leaks)
  6. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    326
    Chicago IL
    There are 2 kinds of mechanics. Those who've resealed an engine for leaks on their own dime.. and those who will have to reseal on their own dime. Usually only takes once to learn the lesson.
  8. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,265
    Palos Verdes
    Vince V
    Another vote for Honda bond. Look, your car is over two decades old; stuff warps. Honda bond insures a good seal. Use it everywhere there are gaskets. Everywhere.
    26street likes this.
