Slight vibration on high rpms | FerrariChat
Discussion in 'Technical Q&A' started by Zed82, Jul 18, 2020.
  1. Zed82
    Zed82 Formula Junior
    Sep 28, 2017
    490
    Sweden
    Has anyone experienced a slight vibration from the drivetrain at high rpms? This happens when I keep the car on high revs (above 5000) for maybe a few seconds in lower gears. Imagine going through a tunnel and revving the engine higher and keeping it there for a little while. Not sure if this is normal.
    The car is a 2006 F430 F1 with full IPE exhaust.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,692
    Central NJ
    Dominick
    Check your trans and motor mounts ..
    Check codes for misfire codes..bad coils or spark plugs
    Sent from my moto g(7) using Tapatalk
