Sodium Valves ... curious to know | Page 5 | FerrariChat
Discussion in '308/328' started by Spitfire, Mar 6, 2008.
  1. mj1pate
    mj1pate Rookie
    Apr 8, 2009
    8
    Maryland, U.S.
    Michael Pate
    Ah, forget it. Didn't read down in the thread far enough, to know that there had already been pyromaniac intervention.
  2. ironring99
    ironring99 Rookie
    Jun 11, 2009
    1
    Does my 1986 328 GTS Euro Version have sodium exhaust valves?
  3. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    No_Only 308's up to 82'.They weren't installed in the QV or 328 engines
  4. Bucci
    Bucci Karting
    Jan 5, 2020
    89
    Mark Bucci
  5. Bucci
    Bucci Karting
    Jan 5, 2020
    89
    Mark Bucci
    So did I hear someone say these are not found in the Quatro?
    NoGoSlow likes this.
  6. NoGoSlow
    NoGoSlow Formula Junior
    641
    Republic of Texas
    Mark Jacks
    Correct, only in the 308 2-valve engines.
  7. Bucci
    Bucci Karting
    Jan 5, 2020
    89
    Mark Bucci
    Good to know, looking at an 83 Quattro.. Probably have something else to worry about. Maybe I just buy another 348, I have no problems with mine now.. tks
  8. expeatfarmer
    expeatfarmer Karting
    Jul 11, 2016
    54
    Cumbria England
    Jonathan Cox
    Is there a way of identifying sodium filled valves? Can you tell if a previous owner has replaced them?
  9. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    There are several things that make them prone to failure: 1) the weld is at the hottest, weakest part of the stem, where the air is injected, 2) the walls were pretty thin to start with 3) the valve springs are much too strong (high rate for the pedantic) so the stresses higher 4) the guides are soft so the eccentric closing of the valve (with high spring forces) puts a bending moment on the stem which causes fatigue over millions of cycles.
    To check with the valves in the engine you can use my method here:
    https://www.ferrarichat.com/forum/threads/dereks-308-engine-rebuild.535247/
    ... but some solid stainless valves have a slight magnetic pull so it is not definitive. The 21-4N valves I sell have a small magnetic effect due to some tiny martensite crystals from the heating and forging process.
