Southwest Airlines Emergency Landing at PHL | Page 2 | FerrariChat
Discussion in 'Aviation Chat' started by SAFE4NOW, Apr 17, 2018.
  1. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,017
    Shoreline,Washington
    Robert Parks
    Looking at the photos it appears that the leading edge slats were damaged from flying debris. Would be interested in seeing the fuselage, too. That fan case sure tore up the nacelle before it left.
  2. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,395
    FL
    That altitude graph shows it descending up to 3700 ft per min wow! That alone must have freaked out the pax.
  3. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,004
    NE FL
    Ken
    ATC memes put a compilation (serious) of all the ATC coms who dealt with swa1380
    Very sad there was one fatality, but it could have been much worse
    Gre by both pilots and controllers
  4. Gatorrari
    Gatorrari F1 World Champ
    16,379
    Georgia
    Jim Pernikoff
    To me it looks like the shattered window would have been several rows behind the expected route of the shrapnel from the engine.
  5. BoulderFCar
    BoulderFCar F1 World Champ
    13,090
    Asheville, NC/Ft Lauderdale
    Tom
    This whole thing restores faith that there are lots of good honest people doing the right thing everyday.
    arizonaitalian likes this.
  6. donv
    donv Two Time F1 World Champ
    25,827
    Portland, Oregon
    Don
    I agree with you completely!
  7. jgonzalesm6
    jgonzalesm6 Two Time F1 World Champ
    23,697
    Corpus Christi, Tx.
    Joe R Gonzales
  8. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    jgonzalesm6 likes this.
  9. Gatorrari
    16,379
    Georgia
    Jim Pernikoff
    Aha! I was right. So just sitting in the plane of the compressor fan is not the only dangerous place to sit.
  10. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    I'm with you. It looks like the fan blade is not the only problem if it causes the entire fan case to disintegrate.
  11. Tcar
    Tcar F1 Rookie
    I read once that the GE CFM was the most commonly used airliner engine... and one of the most reliable.
    SW has a great safety record.
  12. RWP137
    RWP137 Formula 3
    Apr 29, 2013
    1,594
    AZ
    Rick
    That’s a flight idle descent in the 73...no big deal.
  13. RWP137
    RWP137 Formula 3
    Apr 29, 2013
    1,594
    AZ
    Rick
    SWA maintenance is top notch. 4,000 flights a day...things are bound to happen. If anything, CFM has the issue. Uncontained failures are not supposed to happen...
  14. tazandjan
    39,026
    I always avoid seats adjacent to the fan blades, but that sure did not help the Wells Fargo lady from Albuquerque.
    norcal2 and mike01606 like this.
  15. jgonzalesm6
    23,697
    Corpus Christi, Tx.
    Joe R Gonzales
    Metal fatigue in one of the fan blades in this CFM-56 engine is the likely culprit for the engine failure. SW is doing a rampant maintenance check on all it's CFM-56 engines.
  16. BoulderFCar
    13,090
    Tom
    I don't avoid the seat by the blades but it always crossed my mind. Any idea how this entered the plane so much further back?
  17. thecarreaper
    thecarreaper F1 World Champ
    17,967
    Savannah
    Does this depressurization trigger and EDM response from the aircraft? Our jets have an EDM mode where loss of cabin pressure triggers the auto pilot to command a long spiral downturn to a safe altitude (breathable air) and automatically a EDM emergency squawk on the transponder. This is in case the pilots are not conscious.
    This seemed more like a flight idle / controlled decent to nearest safe airport but I wonder if the loss of cabin pressure triggers automatic responses in the aircraft?
    ATC seemed to just be aware of engine out/ engine fire?
    I also noticed the pilot asked for a single frequency but still had to change frequencies a few times to get on the ground.
    EDM= emergency decent mode.
  18. GuyIncognito
    99,101
    first fatality in US commercial aviation in almost a decade (February 2009). that's incredible.
  19. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
  20. energy88
    energy88 Three Time F1 World Champ
    31,474
    West of Fredericksburg, VA
    It looks like the missing blade is located at the NTSB inspector's right elbow. Also, the next adjacent blade appears to have a bend in it.
  21. JLF
    JLF Formula 3
    Sep 8, 2009
    1,703
    No, we do not have that on our planes.
    thecarreaper likes this.
  22. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    What is interesting is that the blade that left went forward a lot more than is typical before it exited the engine. Note that the fan containment ring that is supposed to catch the blade is still there, the blade went forward as opposed to going radially outward. Considering the blade centrifugal forces you would expect it to go radially outward, but it obviously missed the containment ring. We had a similar thing occur when developing an engine at Pratt back in the 70's. In that case a "stub" stage (LP supercharging stage behind the fan), failed and went forward, around the splitter between the fan and core flow, and then went down the fan duct. The engine started vibrating so we shut it down and the blade was missing, lost it at the root.. We had always assumed that if we lost a blade in that stage it would have gone down the core and destroyed the core, but that isn't what happened. There's a lot of forward force on a fan blade and depending on how it lets go it can twist and obviously "fly" forward more than you would think. Once it got ahead of the containment ring, there wasn't much to slow it down. After it damaged the cowl, the cowl got torn up due to the force of the slipstream. When testing engines for containment, you have do demonstrate that you contain the blade. This is typically done by pre drilling a blade root or disk lug and then using a heater or other means to fail the attachment. Invariably the blade goes pretty much radially although the containment ring does extend a distance ahead of the blade to account for the tendency of the blade to "fly" forward. This failure is different than any that I've seen in that the blade went a lot further forward than is typical of a fan blade failure.
    jcurry likes this.
  23. RWP137
    RWP137 Formula 3
    Apr 29, 2013
    1,594
    AZ
    Rick
    Not equipped with that.
  24. Gatorrari
    16,379
    Georgia
    Jim Pernikoff
    I don't understand it either. The fan itself is otherwise undamaged, as is probably the rest of the engine. Maybe the containment blankets will have to be extended to the front of the cowls.
  25. jgonzalesm6
    23,697
    Corpus Christi, Tx.
    Joe R Gonzales
    First one in SW history.
    GuyIncognito likes this.
