Southwest Airlines Emergency Landing at PHL | Page 3 | FerrariChat
Discussion in 'Aviation Chat' started by SAFE4NOW, Apr 17, 2018.
  1. jcurry
    23,683
    In the past
    Jim
    Statistically, even considering this event, it probably still is.
    jgonzalesm6 likes this.
  2. Tcar
    Tcar F1 Rookie
    First passenger.
    In '05 SW plane slid off a runway on ice and killed a child in a car on the street.
    Those are the only two.
  3. jgonzalesm6
    jgonzalesm6 Two Time F1 World Champ
    23,697
    Corpus Christi, Tx.
    Joe R Gonzales
    On the business channel, they said there were 13,400 or so of these CFM-56 engines in use...globally...moving millons of people. This is one of those "freak" episodes involving the blade under metal fatigue. I am sure the do routine maintenance but to check for stress fractures or metal fatigue on each blade will involve a competely different process.
  4. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,395
    FL
    This is actually second pax death on a swa flight. First one got his ass beat to death by other pax as he rushed and broke into the cockpit (8/11/2000). Flight 1763.
    This is the third swa-related fatality including Midway slide as you pointed out.
  5. BubblesQuah
    BubblesQuah F1 World Champ
    13,199
    Charlotte
    I wonder where the blade landed?
    I assume it must be in an unpopulated area, unless I missed that it was found somewhere.
  6. Tcar
    Tcar F1 Rookie
    Eastern Pennsylvania... prolly will never be found, it's pretty small.
  7. Tcar
    Tcar F1 Rookie
    That's not unusual... look at the chart, it's about the same rate as the climb is.
  8. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,017
    Shoreline,Washington
    Robert Parks
    The best engine in the world will eventually fail if it isn't properly maintained or checked. The blade on this engine failed from metal fatigue that should have been identified with a periodic thorough ultra sound inspection. One can see damage quite a ways outboard on the leading edge slats and it is logical that the shrapnel flew up over the wing and hit the fuselage and the window that blew out.
  9. thecarreaper
    thecarreaper F1 World Champ
    17,967
    Savannah
    I wonder if the shrapnel that broke the window hit the woman and that was where the head injury came from?
    Very sad. :(
  10. jcurry
    23,683
    In the past
    Jim
    No different than the UAL blade separation back in Feb.
    https://aviation-safety.net/wikibase/wiki.php?id=206147
  11. TheMayor
    104,913
    Vegas baby
    Today the NTSB spokes person said
    22 minutes from the incident to the landing
    the landing was 190 knots at 5 degree flaps vs around 160 knots and 20 degree flaps normally under this load
    Severe vibration on the airframe accorded the entire time
    the plane banked at 45 degrees at the time of the incident (that must has scared the crap out of everyone on board) but the pilots righted it quickly
  12. tazandjan
    39,026
    Lots of yaw/roll when the thrust stops on one side and the drag increases greatly at the same time.
  13. JLF
    JLF Formula 3
    Sep 8, 2009
    1,703
    We never land at 160 knots and 20 degrees of flaps. We don’t even have 20 degrees of flaps.
  14. TheMayor
    104,913
    Vegas baby
    Here is the actual video
    You are correct. I repeated it incorrectly as I saw it the news today. He said Flaps 5 instead of flaps 30. I said it as "degrees" so you are correct.
    Also the bank was 41 and not 45 as I stated.
  15. JLF
    JLF Formula 3
    Sep 8, 2009
    1,703
    Yea Flap 5 is the normal single engine landing flap.
  16. BMW.SauberF1Team
    Dec 4, 2004
    14,395
    FL
    I'm sure SWA followed maintenance on it as required without skimping so I don't think it really was preventable. Unless one thinks more frequent checks outside of what is recommended should be performed...I wouldn't hold them or anyone up to that standard. As long as they did what was recommended, it was just bad luck it happened to one of their planes and not a competing airline. If they skipped maintenance checks that led to this...they should pay.
  17. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    I was told by a Boeing person that SWA has maintenance done in Mexico.
  18. joker57676
    joker57676 Two Time F1 World Champ
    Apr 12, 2005
    23,767
    Sin City
    Deplorie McDeplorableface
    #68 joker57676, Apr 18, 2018
    Don't believe everything you hear. Some maintenance is outsourced but they have something like 16 repair stations.
  19. BMW.SauberF1Team
    Dec 4, 2004
    14,395
    FL
  20. joker57676
    Apr 12, 2005
    23,767
    Sin City
  21. BMW.SauberF1Team
    Dec 4, 2004
    14,395
    FL
    That is correct. Houston and Dallas are big maintenance areas. I know there are different levels of maintenance performed, but I don't know where those are done and don't want to speculate.
    I really hope for the families' sake (7 people injured too?) that everything was done properly and was unavoidable based on current required checks. I hope so too so I can fly with less worry as I do fly SWA a lot.
  22. joker57676
    Apr 12, 2005
    23,767
    Sin City
    For what it's worth, I do work for SWA. It is my preferred airline by a long shot.
    Lotaz likes this.
  23. JLF
    JLF Formula 3
    Sep 8, 2009
    1,703
    I’ve never heard of a single crew taking a plane to El Salvador for maintenance. Not saying it hasn’t happened but I’m sure I would have heard about it at some point. Typically maintenance contractors like that would be paint jobs.
  24. BMW.SauberF1Team
    Dec 4, 2004
    14,395
    FL
    https://www.faa.gov/news/press_releases/news_story.cfm?newsId=19334
    That is from 2015.
  25. JLF
    JLF Formula 3
    Sep 8, 2009
    1,703
    Interesting, I’m going to ask a maintenance guy in Dallas tomorrow exactly how much and what is done outside the US.
