SpaceX Starship | Page 14 | FerrariChat
SpaceX Starship
Discussion in 'Aviation Chat' started by BJK, Feb 3, 2021.
  1. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,447
    CT
  2. TheBigEasy
    TheBigEasy F1 World Champ
    Jun 21, 2005
    18,618
    California
    Ethan Hunt
    I am watching Everyday Astronaut now...
    Why do I get the feeling that today will not be the success that flight 5 was? A lot of nervous energy around it...
  3. TheBigEasy
    Jun 21, 2005
    18,618
    California
    Ethan Hunt
    Damn... no-go for catch on the booster... diverted to the Gulf
  4. jcurry
    24,004
    In the past
    Jim
    Hope the banana survives
    BJK, tritone and ArtS like this.
  5. ArtS
    ArtS F1 World Champ
    Nov 11, 2003
    13,158
    Central NJ
    Anyone hear the reason for the catch abort? It did seem to come to a stop above the water and the vent exhaust didn't seem to ignite this time. BTW, in spite of the mushroom cloud explosion, the booster is still floating in the Gulf!
    Also, I'm watching LabPadre, any better commentary elsewhere?
    Regards,
    Art S.
  6. ArtS
    ArtS F1 World Champ
    Nov 11, 2003
    13,158
    Central NJ
    Top of the body discolored and venting aggressively!
  7. ArtS
    ArtS F1 World Champ
    Nov 11, 2003
    13,158
    Central NJ
    Impressive!
    Given the 'banana' theme, the conclusion was a 'banana split'... :^)
  8. TheBigEasy
    Jun 21, 2005
    18,618
    California
    Ethan Hunt
    I’m no expert, but on the initial ascent right after launch… it almost seemed like it was pitching too much? It was almost horizontal at hot stage separation. Then the narration was oddly quiet around that part too, something was definitely off. They were able to start the boost back burn, then called for the diversion away from the tower landing.
  9. ArtS
    ArtS F1 World Champ
    Nov 11, 2003
    13,158
    Central NJ
    I would take the video stuff with a grain of salt. I thought the upper section was over-pressure on the way back with the venting and decolorization on the back of the main body but it was fine. Of course it became a 'banana split' once it hit the water (thermal shock or inadequate venting in the water - not a surprise).
    For perspective, the trajectory is to tilt it away from the tower ASAP after liftoff - that way the bits don't fall on it in case of early RUD. Then it's close to vertical (some angle but not much) to get out of the thick, lower atmosphere as quick as possible. As altitude is achieved they begin to tilt it to build lateral velocity - remember, it needs to build speed to over 17,000 mph as well as altitude, that's why it had the 'horizontal' appearance (it was still angled up at reasonable angle based on the altitude gains at time of separation).
    The call outs were go for catch (tower and booster) after separation. The divert call was made about 30 seconds before splashdown.
    Regards,
    Art S.
  10. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,447
    CT
    TheBigEasy, jcurry and ArtS like this.
  11. jcurry
    24,004
    In the past
    Jim
    2yrs, then he has plenty of time to test things out on the moon. Maybe even add to the crater count, lol.
    From the commentary yesterday this launch was really aggressive on the heat shield geometry and landing profile. Gotta hand it to Space-X for pushing the envelope on these tests, and willing to risk loss of a ship to obtain valuable knowledge. Wonder if this is sort of a 'lesson learned' from the shuttle program. When they reach the final design they will have built up a lot of confidence in the configuration.
    ArtS and BJK like this.
  12. tazandjan
    39,138
    The Shuttle was designed for polar launches out of Vandenberg, so its TPS was designed to absorb much higher heat loads than the lower inclination orbits it actually used. The failures on the STS were due to external damage, not being under-designed for reentry and the missions flown never stressed the TPS to design limits.
    Jaguar36 likes this.
  13. jcurry
    24,004
    In the past
    Jim
    I don't recall any of the Vandenburg launches;) Regardless there was a tremendous amount of re-work between launches. Maybe not due to failure of the TPS from a thermal standpoint, more just staying attached. So falling off or being damaged from debris is still a failure. The shuttle TPS had some very thick tiles, and lots of unique shapes. Appears X is a lot different in both respects. The fact that they have had serious heat issues, including some by design, and the structure still performs is worth noting.
  14. tazandjan
    39,138
    #339 tazandjan, Nov 21, 2024
    Jim- A big driver on STS payload (~66,000 lbs) and reentry requirements was the USAF. Goal was for STS to take over all national security satellite launches for USAF with dual basing at Vandenberg and Cape Canaveral. Challenger caused all that to come to a screaming halt and USAF decided it would never again rely on a single source for launch, ultimately resulting in the NSSL program.
    But then, you already knew that.
    The first failure was due to launching in marginal weather conditions.
    The Orbiter had lost tiles before the last failure without incident. Not lucky that time. Ice caused too much damage in a critical location.
  15. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,447
    CT
    Scott Manley's Flight 6 analysis
    jcurry likes this.
  16. JCR
    JCR F1 World Champ
    10,889
    H-Town, Tejas
    red27 and BJK like this.
  17. jcurry
    24,004
    In the past
    Jim
  18. jcurry
    24,004
    In the past
    Jim
    Big difference between single source and never using a possible source. So more to the story.
  19. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,447
    CT
  20. jcurry
    24,004
    In the past
    Jim
    The coverage of the hot stage adapter being jettisoned was pretty cool.
    BJK likes this.
  21. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,447
    CT
    #346 BJK, Nov 22, 2024
    4k vid - many different views of launch ..... and @ 7:02 Booster splashdown followed by massive fireball :eek: :cool:
    jcurry likes this.
  22. jcurry
    24,004
    In the past
    Jim
    Love the entire production and the music as the booster lands and then explodes. Space-X is at the top in everyway.
  23. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,447
    CT
    I guess there was some fuel left in the tanks. :p
  24. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,447
    CT
  25. BJK
    BJK F1 Veteran
    Jul 18, 2014
    5,447
    CT
    jcurry likes this.
