Spark Plugs | FerrariChat
Spark Plugs
Discussion in 'Technical Q&A' started by Philjay50, Aug 28, 2004.
  1. Philjay50
    Philjay50 Formula Junior
    Jan 16, 2003
    595
    Chester, England
    Philip
    Does anybody know about spark plugs. My Mondial is fitted with N6GY Champion Sparkers, the book of words says these are now discontinued. I understand the replacement is N6YCC. I came by a set of N6YC Racing Specification plugs, does anybody know the difference between "ordinary" and racing Spec. plugs. For what it's worth, they don't look any different to any other type.
    I am having difficulty finding the N6YCC plugs, so is there an alternative ? NGK, Bosch. etc.
  2. shifty308
    shifty308 Karting
    Aug 7, 2004
    75
    coulterville ca
    steven schiffler
    throw those champions in the trash where they belong, all but one bad plug (out of the box) i have ever purchased was a champion, try NGK or bosch, i have NGK bpr5egp 7082 in my 308 seem good tho i think i read abt. a new higher perf. NGK somewhere, maybe a tuner rag.
  3. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    NGK BP7 EVX will do just fine.
  4. Dom
    Dom F1 Veteran
    Nov 5, 2002
    8,489
    There was an article in Forza about spark plugs, it was a while ago (maybe a year or so?). I think if you do a search, there was some info posted about it (maybe in the old ferrarichat archives?).
    Their recommendation was NGK. Didn't have too many good things to say about Champions.
    Dom
  5. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    I've posted this before somwhere, but due to an "incident" at the glider club I was a member of, the Tug plane no longer uses champions.....
    I'm sure there are many happy users though, and good luck to 'em.
  6. Fiat Dino 206
    Fiat Dino 206 Karting
    Apr 19, 2004
    144
    Mississippi
    David
    Give these folks a shout ...
    http://www.sparkplugs.co.uk/pages/pricing/applications/ngk_petrol_car_applications.asp
    The above link will allow you to place your requirements for the data base to search for the proper plug ...
    Addendum: Champion N6GY go to the following link for Champion replacement number.
    http://www.championsparkplugs.com/results_cross.asp?pid=n6gy&x=36&y=11&seenCrossWarning=1
    Addendum: The following site will allow you to search several manufacturers for plug applications for your vehicle.
    http://www.clubplug.net/
    Addendum: Just a note regarding your question about "racing plugs" there are several variants of Champion racing spec plugs. For instance, I use N60Y Champion plugs in the Dino (Fiat) 2000 (206) and the plugs are no longer available, however, the replacement gives a description of one variant of the racing series.
    http://www.championsparkplugs.com/more_info.asp?AAIA=&pid=4400
    Addendum: the following link allows you to read the number on your Champion plugs ... well, you asked!
    http://www.championsparkplugs.com/sparkplug411_champion.asp
    Best wishes
  7. Philjay50
    Jan 16, 2003
    595
    Chester, England
    Philip
    "THINKS" I must havea look at our tug engine and see whats in that !!!!!!!!!
  8. Philjay50
    Jan 16, 2003
    595
    Chester, England
    Philip
    Just a bit more info, the problem, a serious misfire started ofter being stuck in a traffic jam at LeMans for 1.5 hrs + in 34 degrees, car did not over heat and behaved very well, it was only when I came to leave that it started to misfire big time. I checked the plugs and the gaps were massive, I reset and things improved loads, but there is still a hint of a misfire.
    I checked the gaps before going on the journey and they were fine and they had covered about 5k miles.
    Anyway new plugs going in, ngk's as my local dealer has them.
    Thanks for the help and info.
  9. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    '84 Mondial QV -- same plug??
    Thanks,
    Steve W.
