Speedo erratic | FerrariChat
Speedo erratic
Discussion in 'Technical Q&A' started by dhs-9, Mar 27, 2004.
  1. dhs-9
    dhs-9 Formula Junior
    Feb 6, 2004
    292
    I have a 1987 speedo which occassionally has the needle go to zero while driving. Is this likely a problem with the speedo or a sending unit.
    Dave
  2. Diablo
    Diablo Formula Junior
    I would try the sender first. They usually go bad.
    Good Luck to you.
  3. f355spider
    f355spider F1 World Champ
    18,044
    Sender, common problem. Get a new one from one of our sponsors. Should be under $150. 1987? You should be on at least your second or third one by now! :)
  4. Wasco
    Wasco Formula Junior
    Dec 9, 2003
    486
    Salem
    Randy
    Just swapped mine out and it solved the zero at 80 problem, it was intermittent. Make sure and do it now as I have heard that it can fry your speedo if you dont. Sodacoms or Dennis Mcann has em!
