SPG oil filter | FerrariChat
SPG oil filter
Discussion in 'Boxers/TR/M' started by ago car nut, Sep 13, 2022.
  1. ago car nut
    ago car nut F1 Veteran
    5,477
    Madison Ohio
    David A.
    What does the TR forum think of:
    SPG 124228X1 oil filter
  2. Rifledriver
    36,864
    Whats an SPG oil filter?
  3. lagunacc
    lagunacc F1 Rookie
    4,145
    He meant SGP
    turbo-joe likes this.
  4. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,432
    romano schwabel
    SGP is a filter producer like fram
  5. Rifledriver
    36,864
    Well it an alternative I dont think we can just reject. Has anyone found a generic supplier to see what they can be had for? Google just kind of ignores the brand. Be interesting to cut one open. Its not like there have been problems on the TRs like the other cars, its just the absurd price. No matter what they say its still just a $20 oil filter.
    After Steves comments I was getting ready to try a 599 oil filter but even those are pretty expensive.
    clean512, MaseratiMike and turbo-joe like this.
  6. lagunacc
    lagunacc F1 Rookie
    4,145
    Superformance sells the SGP for 40 gbp.
  7. lagunacc
    lagunacc F1 Rookie
    4,145
    The 599 is a Purflux LS 928A. Cross references to Hifi SO 11020 which appears to be some agricultural (surprise) transmission filter, for like 10 bucks.
    Got a link to Steve's comments?
  8. Rifledriver
    36,864
    It was a prior thread on TR oil filters. I guess he measured one and its the same thread and gasket size. Any oil flow good enough for a 599 has to be good enough for a TR.
  9. lagunacc
    lagunacc F1 Rookie
    4,145
    This filter is for the 599 and FF but the Purflux part number is not visible:
    https://www.ferrariparts.co.uk/part/ferrari/218429
    This one's for the FF and Purflux LS 928A is visible. But is that the correct filter?
    https://www.ferrariparts.co.uk/part/ferrari/280459?id=216855
    Purflux LS 928A cross references to:
    MAHLE OC 50
    SF SP 4129
    Hifi SO 11020
    Baldwin BT292 cross references to Mahle OC 50.
    Baldwin BT292 specs: https://inlinefilters.co.uk/Filters-Hydraulic/BrandSpecific/Baldwin/FBW-BT292/
    Hifi S0 11020 specs: https://catalog.hifi-filter.com/en-GB/reference/SO 11020/4ca11f01-fd5f-11e8-8c9a-005056867867
  10. lagunacc
    lagunacc F1 Rookie
    4,145
    In Steve's thread Rpissm also mentions the Purflux LS928 so that seems to be the correct one,
    so the cross refs above are correct.
  11. lagunacc
    lagunacc F1 Rookie
    4,145
    MaseratiMike likes this.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,728
    Central NJ
    Dominick
    I know a few indies that use the SGP in the 512tr
  13. MaseratiMike
    MaseratiMike Formula Junior
    Mar 15, 2016
    350
    If the Purflux LS1052 is a true match cross reference replacement for a Testarossa that is great news, as this also cross references to a Bosch 0451103278 and UFI 23.544.00. More choice and trusted brands, this is also used on a BENTLEY MULSANNE 3Y 6.8….
  14. lagunacc
    lagunacc F1 Rookie
    4,145
    It doesn't cross reference to the TR directly.
    The Purflux LS 928A is the filter Purflux makes for the 599 and FF (F part #218429).
    In his post Steve argued that it should be ok for the TR, and someone had bought a TR with that filter already installed.
    The Purflux LS 928A cross references to the Mahle OC50 which cross references to the Purflux LS1052 and consequently to the ones you mention.
  15. Rifledriver
    36,864
    A factor not being mentioned that requires consideration is rated burst strength. Ferrari motors can produce higher pressure than most when cold and the filter has to be rated for it.
    Anything made by Mahle I would trust. It is an outstanding company.
    Also, I have little faith in UFI and have only stuck with them because if I buy through the Ferrari supply chain it carry's a good warranty. A TR client lost an engine as a direct result of a failure due to poor QA of an UFI filter and Ferrari did a complete overhaul on a 20+ year old engine, no questions asked.
    f355spider and MaseratiMike like this.
  16. lagunacc
    lagunacc F1 Rookie
    4,145
    Tangential to that.
    https://www.ferrarichat.com/forum/attachments/dsc00143-3-jpg.118190/
    https://www.ferrarichat.com/forum/threads/testarossa-camshaft-seized.44299/
  17. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,091
    Josh @jtcarprojects
    Hello Brian I have a clutch bleeding? Can you PM me if you don't mind
  18. Rifledriver
    36,864
    Bleed clutch. Pump pedal quickly about 50 times then rebleed. Clutch line goes up and down and forcing air out can be a little difficult. It can get trapped in the high spots. Pumping pedal quickly can get it untrapped.
    ago car nut and clean512 like this.
