Spyder top issue | FerrariChat
Spyder top issue
Discussion in '360/430' started by Todd Stuart, Jul 2, 2020.
  1. Todd Stuart
    Todd Stuart Rookie
    Apr 10, 2020
    8
    Todd Stiart
    I have a new for me 2003 Spyder. The top occasionally freezes in the opening cycle. Reclosing and reopening has worked so far. Anyone else seen this problem? Thanks in advance for any help.
  2. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,742
    Memphis, TN
    The first thing you should know is that you have a SPIDER, not a SPYDER.
    Second, get a good code scanner that can read the capote. I suggest the Autel AP200 ($70 on Amazon) which has virtually all the data for the 360, including live data. You can check the capote ECU for error codes.
    Third. Are you closing and opening the top with the engine running? This is mandatory and is specified in the owner's manual. Operating the capote without the engine running can cause overheating of the pump, among other things, that can cause you endless grief. Low voltage during operation can cause it to stop. Such an event would be indicated in the codes thrown by the capote ECU.
    And finally, welcome to the 360 owner's club!
  3. Todd Stuart
    Todd Stuart Rookie
    Apr 10, 2020
    8
    Todd Stiart
    Thank you. And yes the car was running. FYI I go every year to East Memphis airport to do my jet license recertification.
  4. plastique999
    plastique999 F1 Veteran
    Nov 9, 2008
    8,587
    SoCal
    Edward
    Could be the elastic bands...:
    Sent from my 16M
    Todd Stuart and EastMemphis like this.
  5. cpep
    cpep Formula Junior
    Nov 11, 2017
    399
    new york
    CHARLIE
    Was it a hot day and was it down for a long drive. Mine acts up when it get really hot but I just let it cool down and it works fine again.
    Todd Stuart likes this.
  6. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Very common issue...............
    When was the last time the hydraulic fluid was flushed? If it has never been flushed it was way overdue.
    Also, it always helps to warm up the engine a little bit before operating the roof.
  7. Todd Stuart
    Todd Stuart Rookie
    Apr 10, 2020
    8
    Todd Stiart
    I want to thank everyone for their ideas and help. The winner was plastique999. It was the elastic bands. Obviously could have been a lot bigger problem.
    plastique999 likes this.
  8. plastique999
    Nov 9, 2008
    8,587
    SoCal
    Edward
    Woohoo!
    Glad you got it fixed
    Sent from my 16M
