355 - Stand alone EMS on a 355 | FerrariChat
355 Stand alone EMS on a 355
Discussion in '348/355' started by chrisj951, Dec 29, 2019.
  1. chrisj951
    chrisj951 Karting
    Feb 18, 2015
    204
    Metro Atlanta
    Curious if anyone has replaced the Bosch engine management system with a Motec or any other EMS? I know our cars run rich and we are probably leaving power on the table. Having the ability to tune the car exactly how one would want it is intriguing.
  2. INRange
    INRange F1 World Champ
    12,446
    Virginia/Florida/Caymans
    JD
    I believe we had a member a few years ago that was trying to get a Motec to work on a 355.
    I have retrofit F.A.S.T. EMS products to a couple of racing engines but the 355 presents some unique challenges. Without the fuel maps, everything would have to be "learned" by a wide band O2 sensor. I'm not sure that would result in an optimal configuration without access to a 355 engine mounted on a dyno. That would be the only way to get a side by side comparison between a Bosch and another EMS system. Even then.....I'm not sure you will end up in a better place.
  3. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,740
    Lake Villa IL
    Keep seeing this posted but have never seen any evidence to support it. Fwiw both my 95 and 99 had near perfect air/fuel ratios on the dyno.
    I do think it would be nice to run modern engine management. I do plan to do it at some point.
  4. ShineKen
    ShineKen F1 World Champ
    19,838
    Southern California
    Nostradamus
  5. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Yuuup folks are reading too many Honda stories LOL, well thats what the boss told me
  6. Steve355F1
    Steve355F1 F1 World Champ
    Aug 26, 2011
    17,152
    Adelaide, South Aust
    Steve
    There is a prolific poster in the Oz section who has a 355CH (road legal) which is running MOTEC and has been for years.
    I'll see if I can direct him here.
    Of course, you'll have to wade through a mountain of BS, but.... :D
  7. tres55
    tres55 F1 Rookie
    Sep 18, 2012
    3,564
    Canada
    I would find it hard to believe there isn't some gains to be had.
    Whether or not it would be worth the endeavor however is another question.
  8. moretti
    moretti Five Time F1 World Champ
    Nov 1, 2003
    59,757
    Australia
    I have a '96 355CH with MOTEC that has been dyno'd several times with 247KW at the rear wheels
    It's running the M8 version (which is pretty old and I have thought of updating the system)
    One of the expensive portions of the upgrade is you will need to get a new wiring loom along with several other things like throttle position sensor and I was told this is circa AUS$15k
    I have had a couple of WOT issues on track days but generally the system is very good and you don't get stupid "check engine" lights :)
    At least I don't go and buy carbon fibre flappy paddles like someone I know :p
    Qavion and Steve355F1 like this.
  9. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    You forgot to mention that it was dynod side by side on the same dyno with another 355ch, and it had significantly more HP. MoTec can be the only reason.
  10. Andy 355
    Andy 355 Formula Junior
    Jun 2, 2013
    434
    Ill bet that 130ps gain was with the lid open on the dyno. The ambient air temp that engine would draw in with the lid closed would kill the power surely.
  11. ShineKen
    19,838
    Southern California
    Nostradamus
    247 kw = ?? What 330 rwhp? Doesnt sound like much if that is the case. What was the other CH making?
  12. Aircon
    100,524
    Peter
    The other had 20hp less from memory. Not a lot. I don't think you'd bother with it unless you were racing or had expensive ECU problems already. No CEL ever is nice though.
    It has a bit more midrange and better throttle response too.
  13. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    Yeah one of my 95's is the same the other way past that with the 2.7. Trick is loose the bypass valve and retune for that
    Running wide open for an hour or so in 100+ degree temps can get tricky. I'm sure they have lots heat down that side of the world as I been reading :)
  14. moretti
    Nov 1, 2003
    59,757
    Australia
    I think the dyno people I did it with said 410 horses after they fixed the TPS which caused erratic idling (got me an $1800 fine from our "wonderful coppers" for blipping the throttle as I was driving away from a breath testing :rolleyes: )
    I find the MOTEC quite transparent to driving but comes into it's own on the track ..... no other 355 comes near it if all is working as expected :)
    GTUnit likes this.
  15. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,185
    Gold Coast, Aust.
    Patrick
    Hotter than a boilermaker's jockstrap right now
  16. Ferraridoc
    Jun 20, 2012
    17,185
    Gold Coast, Aust.
    Patrick
    Didn't Steve beat you? :D
    Steve355F1 likes this.
  17. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    Yeah I see that on the news STAY SAFE !!!!! We get the same crap out here in summer
  18. Steve355F1
    Aug 26, 2011
    17,152
    Steve
    So, what's the hp v kg equation then with these cars?
    ie. A weight saving of, say, 20kg is equivalent to how many hp?
  19. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,740
    Lake Villa IL
    I don't think there could be a meaningful hp to kg equation.
    For one, weight reduction helps in every category, be it acceleration/handling/braking. (well as long as the weight reduction doesn't completely destroy balance but I don't think that's a common scenario with these cars).
    Even if you're looking at in in terms of purely acceleration, the lighter the car the more weight reduction matters as it's a greater percentage of total weight.
    (100lbs off of a 3000lb car is going to help more than 100lbs off of a 5000lb car)
  20. GTUnit
    GTUnit Karting
    May 25, 2014
    143
    Socal
    Jack
    LOL. Nice. We would get along just fine.
  21. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    I was up at Walkersport in the UK about 6 months ago, and Tim had two Challenge spec cars there, I mentioned I had a couple of spare ecu for them and he said they now run stand alone in the race series they run in, so maybe worth a chat with him
