Steering Rack Install Question | FerrariChat
Discussion in '308/328' started by chasjen, Aug 26, 2019.
  1. chasjen
    chasjen Karting
    81
    Dublin, Ohio
    Charlie
    I'm getting ready to replace my steering rack (85 308 QV). I'm a little fuzzy regards the steering wheel linkage. Any tips on getting it centered/aligned? Thanks.
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    To index true centerpoint, I probably didn't do it the right way. But here's how I did it. I got the steering box linkage perfectly lined up, and then connected. Once that was locked down, I went with attaching the brackets to the frame. From there reattached the outer tie rods.
    Afterwards, I put the car on the alignment rack and went from there. Alignment was quite nice, so in the end everything worked out nicely.
  3. chasjen
    chasjen Karting
    81
    Dublin, Ohio
    Charlie
    Thanks for the reply. So straighten the steering wheel and connect the linkage?
  4. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
  5. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I think what you are asking for is what orientation of the splines on the rack to column interface to keep the steering wheel centered? If so, attach the column to the rack in any spline, turn all the way left. Carefully count the rotations all the way right. Back up exactly half of that. Separate the two, turn the wheel to be the correct orientation, reattach. Your alignment tech will get it right on using the tie rod ends, but you'll be close.
    Or I misunderstand your question.
  6. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I might have misunderstood the question too. I was referring to putting the rack into the car, not describing how to get the wheels centered relative to the steering wheel.
