steering rack rebuild | FerrariChat
Discussion in '308/328' started by fstarr56, Jul 5, 2013.
  1. fstarr56
    fstarr56 Rookie
    May 21, 2013
    31
    Tonawanda NY
    Fred Starr
    I'm looking for the replacement bushing for the right side of the rack and a new set of boots. PI motorsports which deals mostly with Pantera parts has a kit for $109.00 the bushing has an OD of 1.213 and ID .844 someone on Fchat said this would work on my 308. anyone know for sure? Or have a better place to go for these parts. Thanks
  2. azfast1
    azfast1 Karting
    Jan 10, 2004
    208
    yes, same rack as on a Pantera.
  3. Peter
    Peter F1 Veteran
    6,432
    B.C., Canada
    Which 308 do you have? An early car will have a CamGears rack, later ones used TRW. The Panteras used CamGears racks.
  4. fstarr56
    fstarr56 Rookie
    May 21, 2013
    31
    Tonawanda NY
    Fred Starr
    My car is a 1980 I can't see the rack that good but the boots have TRW on them.
  5. godabitibi
    godabitibi F1 Veteran
    6,283
    Papineauville, Quebec
    Claude Laforest
    I did mine with the PI motorsport bushing. 1977 and it worked perfect, mine is a cam gear. A new bushing can also be machined locally. I also had the idea of putting a grease fitting in place of the retaining screw so it could be greased occasionnally if a hole is made in the bushing. Any thoughts about that?
  6. fstarr56
    fstarr56 Rookie
    May 21, 2013
    31
    Tonawanda NY
    Fred Starr
    I found a re-pop rack for $250, I think I'll put that in for the rest of the summer and send the original one out over the winter for a rebuild.
  7. fstarr56
    fstarr56 Rookie
    May 21, 2013
    31
    Tonawanda NY
    Fred Starr
    That sounds like a great idea. Grease is good.
