Stock 308 Air Filter power loss on dyno | FerrariChat
Discussion in 'Technical Q&A' started by snj5, Dec 11, 2003.
  1. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Just a copy from the other thread from my time on the dyno:
    Fun fact: the difference between paper airfilter/airbox and just air box was 8 horsepower !!!! Unlike the Forza article on the 308 comparison, when I took the airbox off I gained 14 horsepower over baseline!!!!! Of course, no ram effect was in play on the dyno, but interesting numbers, don't you think? So where do I get a 308 K&N?
    best
    rt
  2. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,079
    Southeast USA
    Mike Charness
    Get the correct part number from
    www.knfilters.com
    and then your local AutoZone or other local parts store can order it for you. Or order it over the net.
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    12,670
    The twilight zone
    The Butcher
    Russ,
    Your engine is quite rich, removing the filter would tend to lean it and is probably why you saw the hp increase.
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    You know, you're right. I thought about that as well just now and I went back and checked - there was about a max .9 point difference in A/F (11 and 11.9). Would that affect other cars' mixture similarly?
  5. Mike328
    Mike328 F1 Rookie
    2,655
    Boulder, CO
    I just ordered a K&N here: http://www.performanceintl.com/
    $50. E-2930 is confirmed to be the p/n for carb 308s.
    Reference: http://www.ferrariclub.com/faq/knfilter.html
    Item Order Summary:
    E-2930 - 1978 FERRARI 308 GTS - K & N: REPLACEMENT AIR FILTER
    $50.22 x 1 = $50.22 (Shipping: $0.00)
    Subtotal: $50.22
    Shipping Cost: $0.00
    TOTAL: $50.22
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    12,670
    The twilight zone
    The Butcher
    Russ,
    Yes, it would affect all engines the same. In fact dynojet (at least on motorcycles) teaches the dyno tech to make a run then pull the air filter. If hp goes up it's rich, if it falls it's lean. it should only change by a fraction of a % if the mixture is correct, assuming the filter is close to the right size...clearly there would be exeptions, but that's normally how it works.
  7. 308SYSTEMS
    308SYSTEMS Karting
    Dec 16, 2003
    51
    FYI - I ran a back to back dyno test of the K&N vs stock FRAM filter on my 85 308. The K&N actually DECREASED the HP by approx 2hp.
    Mark Lueker
  8. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,079
    Southeast USA
    Mike Charness
    Mark L, I wonder why that would be the case on FI engine...? I guess one might still need to adjust the mixture.
  9. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Russ
    Your data quantifies what we've known: getting the mixture optimized is valuable. I am curious what power increase you see from changed jetting/getting the AF closer to 13:1.
    Philip
