Stradale Problem | Page 2 | FerrariChat
Stradale Problem
Discussion in '360/430' started by GWat, Jul 28, 2004.
  1. vincent355
    vincent355 F1 Veteran
    6,539
    Wine Country
    Vincent
    Amazing the things we put up with! Passion I guess.....
  2. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    14,251
    MO
    Omar
    How do you press the button? Do you A, just really tap it to get it started or do you B, hold it in for a while?
    If A, then do B. If B, try doing it longer. If C (B doesnt work) then well remember it is a Ferrari and thus built like a joke and try B some more. :p
  3. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Hmmm...
  4. spyderman
    spyderman Formula 3
    1,623
    Toronto - Canada
    Spyderman
    B, hold it down for about 2 seconds.
  5. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    the CS manual makes mention of not holding this button down too long (though it doesn't provide time guidelines). this suggests to me that it sends a continuous electronic message to the ignition along the lines of turning and holding the key in a mechanical ignition.
    fwiw,
    doody.
  6. TimF40
    TimF40 Formula 3
    Nov 3, 2003
    1,035
    Seattle/Bay Area/NYC
    Tim
    Mine too! Actually, the problem just started about 1 month ago. Before that, it would start right up. Now sometimes, when cold, it does as described above. I have to turn it off and back on - then everything is fine. Something changed in the car for it to act like it does now. I was going to have FoS check it out during my next service. :-| Tim
  7. 4i2fly
    4i2fly Formula 3
    Apr 16, 2004
    1,333
    SF, Bay Area
    You may be on to something...There is a limp mode where the ECU puts the ignition and fuel in a predetermined state and static timing in case there is catastrphic failure to be able to drive the car to a service station. In any case, this should not happen, there has got to be fix for it... Has anyone contacted FNA?
  8. Aradune
    Aradune Karting
    Jul 11, 2004
    76
    San Diego
    I've experienced what you described with my 360CS -- will try holding the start button down longer. And I agree -- gas doesn't matter -- it happens on 91 (crappy California gas), 100 race gas, and mixtures between the two.
  9. thomas_b
    thomas_b Formula Junior
    Sep 15, 2003
    765
    that is the reason I am convinced the engine is stuck in the start-up mode
    the injectors (amount of fuel) between 30-640 RPM are controlled by the ECU program and not by the accelerator – opening the throttle will stall the engine since the air/fuel mixture will be off
    I don't think the ECU programmers ever envisoned the engine stuck in that mode
    on a positive note I rather have this problem than the hot start problems with P cars caused by bubbles in the fuel line - that really put me off
  10. watt
    watt Formula 3
    Jun 17, 2004
    2,398
    Northern Rocky Mountains
    Giuseppe T Hemingway
    if you start too early after turning the key, the fuel pump is unable to generate suffcient pressure. try waiting longer
  11. Auraraptor
    Sep 25, 2002
    14,251
    MO
    Omar
    This is what I am thinking and thus advised holding the button down more. In 'normal' car terms it kinda is like cranking the car too little. Yes holding it down too long will be bad too (ie overcranking)
  12. Rifledriver
    37,356
    Thomas may have something here, sort of. All start signals, (as well as many other signals) are only sent to the to the ECU for 1/4 (right) bank of cylinders and then relayed to the 5/8 (left) bank. It sounds like 5/8 ain't gettin the message. At least until the motor is no longer dependant on the start info and is "seeing" the run info. Thats where Thomas's comments come in. On MANY 360's the connectors at the ECU's had debris in the female ends causing problems. If you have never seen the plug at the ECU end of the 360 there are so many tiny male ends they look like hair, and a little resistance goes a long way. At one of the schools we were given very specific instructions that on any driveability problems we were to clean those and specifically how to do it. On a proper running 360 the motor should explode to life. With the proper equipment it should be easy to narrow down quite a bit with the exception of two things, #1 getting it to do it consistantly (could be a real problem) and #2 finding a dealership that will do it knowing that they won't get paid by Ferrari for it (last I heard Ferrari still wasn't paying for diagnosis time)
  13. thomas_b
    Sep 15, 2003
    765
    Interesting; I get it – it could be also related to a grounding problem
    one should be able to see that pretty quickly with the SD2 - the left bank should not fire at all if the car is stuck in that state
    On the other side the two ECUs talk through a CAN bus – so one would expect that more things are broken if connectivity is compromises - such as the gearbox ECU to engine ECU communication
  14. 4i2fly
    4i2fly Formula 3
    Apr 16, 2004
    1,333
    SF, Bay Area
  15. Brian C. Stradale
    Brian C. Stradale F1 Rookie
    Mar 17, 2002
    3,615
    Dallas, TX, USA
    My Stradale behaves similarly. It starts at real low RPM... giving gas during this time will stall it. It then bumps the RPM to an elevated 1200 or so... this continues for 20-80secs depending upon how cold it is. It then lowers the RPMs down to normal idle in a few steps. (My Modena was a bit different in its startup ritual... but same general idea.)
    It is my understanding that part of this start-up ritual is related to a different air mixture designed to reduce emissions at startup until the cats get warm.
    Anyway, I make sure not to push the start button until I see "Check OK"; then I don't touch the accelerator until the RPMs at least start stepping down to normal idle.
    BTW, one time I did have it only fire up one bank. That time when I started the car, the idle was really REALLY low... like it didn't even register on the tach! In fact, I was tremendously confused as I could feel the engine was doing something, but the tach wasn't moving. That caused me to hesitate a few seconds, at which point it bumped up to the normal low 500 rpms or so, running real rough (coughing a bit I think from being a bit flooded), then bumped on up like normal.
    That ended up setting my Check Engine light... the error code indicating mis-fire on all cylinders of one bank.
    That has only happened once so far. It is possible that I pushed the start button too quick that time (not waiting for Check OK).
    FWIW.
  16. BigTex
    79,418
    Houston, Texas
    Bubba
    That's interesting that it sounds like the modern ECUs are programmed to emulated the old "crank it up and hold it a 3000RPM until the plugs all clean up" method of Ferrari starting!
  17. Rifledriver
    37,356
    Statement "A" yes. It could be as simple as that
    "B" No, it takes several seconds for the SD2 to initialize after the Motronic is on for it to read out, and by then by your description the problem is gone.
    "C" Not necessarily. Of the many connections, it could be only one that is causing trouble.
  18. 4RE Bob
    4RE Bob Formula Junior
    Feb 7, 2004
    567
    Muskoka, Ontario
    Bob
    My 04 Modena just started doing this in the last week. The dealer said to leave the ignition on for 30 seconds before starting. Long after "Engine OK" light comes on. Any thoughts?
  19. Rifledriver
    37,356
    Can't think of what good that will do. The fuel pumps only run while cranking or while engine is running and as for the rest, well electricity travels at or about the speed of light so we don't have to wait for it now do we?
  20. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    you know how round-about those italian engineers can be - maybe there's 5 or 10 million miles of wires in the car ;)
    doody.
  21. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    So. Cal and No. Utah
    Rick
    is it difficult and/or time consuming for a dealer to check/clean these ECU connectors? my point is that IF it's relatively quick/cheap then maybe it would be worth asking the dealer (even if it isn't covered by warranty) to check/clean the ECU connectors hoping that this will eliminate the oddball startup problem that is being described by so many 360 owners.
  22. Rifledriver
    37,356
    It is not all that time consuming to ck./clean those. The grounds are another story. You should by all means pursue it with your dealer, any warranty reimbursement problems are not yours, they are his. I have a certain amount of sympathy for their position from having been there but the remedy for the warranty problems are for the dealers to remedy, they have just not done it. You should begin a paper trail, don't let them blow you off, make sure a repair order is generated and you get a copy every time you complain. You paid a hell of a lot of money for the car and should not rest until the car is "Commercially acceptable".
  23. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    Rick
    thanks. btw, i guess i'm in the minority (it seems) in that neither of my stradales have experienced this oddball startup problem. but i've made a mental note of the symtoms and a possible cure if/when it ever happens to me. thanks.
  24. dan360
    dan360 F1 Rookie
    Feb 18, 2003
    2,669
    Boston
    I've had this problem on both my old 360 and my CS - but only when they were parked outside overnight. I figured it was because there was some dampness in the (german) electronics.
    I reckon that some gremlin in Germany has a little toggle switch to make the electronics just that bit less reliable when assembled in Italy :)
  25. albertl
    albertl Formula Junior
    Oct 23, 2002
    440
    Washington
    Albert
    I also have this problem but not when the car was new (1 month). I have also notice that when left, the car does drain the battery somewhat and if I were to connect the charger overhight, the problem does not occur.
    It may be that a minimum amount of voltage is required to get all the electronics going before the start sequence.
    For what's it's worth, my 2000 360 also did this but the problem also went away when I got into a habit of pluging the charger up when I put the car away.
    Anyone else found this to be true?
    Albert
