Superformance headers | Page 4 | FerrariChat
Discussion in '348/355' started by Jackie and bill, Feb 13, 2019.
  1. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
  2. ShineKen
    ShineKen Two Time F1 World Champ
    20,162
    Southern California
    Nostradamus
  3. Culprit
    Culprit Formula Junior
    509
    Santa Ana, CA
    Ian
    In the records of my car I found a long story about unprotected headers being installed and them frying 3 alternators. Eventually the PO rebuilt the headers and used the original heat shields. The extreme heat cycles almost certainly wear away at other surrounding components as well.
    Would love to get some real heat measurements of different header set ups. My headers get up to about 400-460 degrees on the heat shield surface, that's with insulation and OEM shields. Hard to compare different materials with different radiation/convection properties of course but would be cool to see how Tubis perform vs. Larini vs. ceramic coated etc.
    jimmym likes this.
  4. lanab
    lanab Formula Junior
    Feb 21, 2016
    530
    Stockholm, Sweden
    Jackie and Bill on the forum told me the shields are not necessary, he has been running the Nouvalaris with no heat problems.....
  5. ShineKen
    20,162
    Southern California
    Nostradamus
    Jackie is also from the UK. Is there a day that goes by where it doesn't rain?
  6. ShineKen
    20,162
    Southern California
    Nostradamus
    Not many fabricators have access to the ability to produce shields. Tubi shields are designed from CAD with male and female aluminum molds for both top, bottom, left and right pieces. That is quite a bit in tooling investment.
    jimmym likes this.
  7. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
    Manifold shields are not. However I made shields for vulnerable items in the engine bay including better drive shaft boot covers as well as alternator protection. Also using heat shield material around and wiring and fuel pipes. Not a lot is actually needed.
    lanab likes this.
  8. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    uber2, lanab and ShineKen like this.
  9. ShineKen
    20,162
    Southern California
    Nostradamus
    In 2019, it rained 165 days in the UK.
  10. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    Currently I'm repairing my muffler heat shield because the foil is shot.
    I'm using this. "Constructed with an embossed 10 mil aluminum face bonded to 1/8" composite glass-fiber core and backed with a high temp super strong pressure sensitive backing,....withstands up to 1750°F." Don't have it yet. Will arrive next week. It will be fine for the muffler shield but I'm wondering if it could be formed around the headers.(Also available w/o adhesive backing.)
  11. evo11
    evo11 Karting
    Sep 21, 2020
    195
    K
    pay attention to the fact that oem manifolds often melt, I know that they are made of 1.2 mm thick walls, but it's high temperature fault. The car comes out of the factory with manifolds that have thermal insulation and I think that each next should also have thermal insulation
    jimmym likes this.
  12. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    Found that DIE makes a similar product as the one I used for my muffler heat shield which can be applied directly to headers. "Form-A-Shield™ can be applied to exhaust headers.... Formed from 10 mil dimpled aluminum bonded to a high temperature rated basalt thermal barrier material, Form-A-Shield™ can be applied directly to hot surfaces..." Based on my experience with the muffler shield I would think this material could be easily molded around headers with a top and bottom sheet, and then crimped or stapled at the seams.
  13. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  14. Culprit
    509
    Santa Ana, CA
    Ian
    I got some of the DEI fiberglass stuff, but just working with it I wasn't happy with all the fibers coming off. Even with wearing gloves, the stuff gets everywhere. Maybe the basalt matte is better.
    I'm planning to buy some of this, which is a formable ceramic, normally used in racing applications. Just 2mm thick.
    https://www.zircotec.com/zircoflex-form/
    Might make a muffler shield (engine side) and alternator shield out of it.
    MAD828 likes this.
  15. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    Ian, here is a picture of the back side of the stuff I used on my muffler shield. The glass mat is pretty dense. Pulling on the edge of the mat, it's pretty hard to pull any fibers out. They aren't just falling off. You must have had a different product.
  16. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    492
    London
    Steve C
    JP will also rebuild your cracked manifolds using better quality steel and refit the OEM heatshields.
    jimmym likes this.
