Suspension Control System Failure message | FerrariChat
Discussion in 'F12/812' started by Jeff3545, Jan 9, 2022.
  1. Jeff3545
    Jeff3545 Karting
    Sep 4, 2018
    113
    SF Bay Area and South Florida
    Jeff Nolan
    I have not driven my 812 Superfast in a month, it has been parked in the warehouse with a battery tender on it. Yesterday I went for a drive and was immediately alerted to a Suspension Control System Failure error. The car drives normally but the bumpy road button is not working, which I assume is related to the error message. Several stop and restart cycles, I am still getting the error and will make an appointment at the dealer this week.
    Any suggestions?
    Related to this, I am wondering if this could be a battery problem. Today I went on an extended drive and watched the battery gauge, it showed 12.1 volts while under normal driving conditions. What is a healthy battery voltage for this car?
  2. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,553
    Austin TX
    Batteries need to cycle some, always being 'topped off' is not the best. For instance, plug in for a few days, unplug for a week, repeat.
    12.1 is low, should be 13 or higher while driving (check against any modern car that shows voltage...)
    Rule of thumb, every 3 years put in new 12v battery and new key fob battery, even early model year 2019's are now 3 years old.
    vraa and Jeff3545 like this.
  3. Jeff3545
    Jeff3545 Karting
    Sep 4, 2018
    113
    Jeff Nolan
    Thanks! This is why I asked, my RAM truck battery voltage is normally 14.2 volts.
  4. vraa
    vraa F1 Rookie
    4,584
    Texas
    Mr. A
    14.2 is a very healthy battery
    Ram TRX?
  5. Jeff3545
    Jeff3545 Karting
    Sep 4, 2018
    113
    Jeff Nolan
    No, RAM 3500. I have 2 batteries and 2 180 amp alternators on that truck. It gets a lot of miles pulling my livestock trailer.
    vraa likes this.
  6. gilly6993
    gilly6993 F1 Rookie
    Aug 20, 2009
    2,555
    Longmeadow, MA
    Eric
    Had the same thing with my Lusso a few months ago. Drove it a few times and it cleared up….Sounds like the dealer should take a look though…
    Jeff3545 likes this.
  7. Jeff3545
    Jeff3545 Karting
    Sep 4, 2018
    113
    Jeff Nolan
    did not clear up for me over 3 days. Dropped it off at the dealer today, I need to get annual service done so they can look at this as well.
  8. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,761
    Weston, MA
    Paul
    Keep us posted, but I bet it's the battery.
    Caeruleus11, vraa and Jeff3545 like this.
  9. sunghyun7
    sunghyun7 Formula Junior
    Oct 7, 2019
    256
    sounds like alternator. with normal driving, my F12 voltage fluctuates from 14v (idle) to 14.5v (normal driving). If it's at a dealership, I'm sure they'll take a look at the alternator with your provided story.
    yea i agree with the above replies. your suspension error is most likely from the low voltage.
  10. wrs
    wrs F1 World Champ
    13,878
    Lakeway, Texas
    William
    When I start mine up and it's cold I get multiple failures. I had to start and stop it three or four times before I could clear all the errors. It happens because the computers don't all come up and report in to the main one fast enough. Computers run slower in the cold and faster in the heat, that's a fact.
  11. Jeff3545
    Jeff3545 Karting
    Sep 4, 2018
    113
    Jeff Nolan
    Thanks, I live in California and the car is stored in a climate controlled warehouse. This is the first time I have experienced this error message.
    wrs likes this.
  12. wrs
    wrs F1 World Champ
    13,878
    Lakeway, Texas
    William
    A lower voltage from the battery to that computer could also be the culprit as the others have noted. I notice that if I go more than a week without starting the car that it does have some issues irrespective of temperature. Not as many errors but it doesn't start right up and may throw a few engine errors. Mostly they will go away with restarts.
    I got it back from service on the .rear windshield back in November and it was a nice sunny day. When I started the car it had an engine control failure so I restarted it twice and it didn't clear. I showed it to the service manager and he said what I just mentioned about the timing of the computers and to restart it again which on the fourth time, did the trick.
  13. Jeff3545
    Jeff3545 Karting
    Sep 4, 2018
    113
    Jeff Nolan
    Update. The tech told me an “acceleration sensor” failed but he did not elaborate so I am not entirely certain which acceleration sensor he is referring to. The battery and alternator are functioning normal. I asked him about the voltage reading and he said it reads low, 12-12.3, under load for reasons related to how the computer measures output across the entire system.
    I had another issue, a ticking in the dash when the AC was on. That noise was actually coming from the AC compressor, so they are replacing it.
  14. Solid State
    Solid State F1 World Champ
    10,508
    Maximus Decimus Meridius
    That seems like a mix of unrelated issues. Ferrari states that the F12 has an 'intelligent' alternator and others have posted in the past similar 12.x volt readings. Not sure what year your 812 but they ship with crappy batteries and wouldn't be surprised if the battery is involved even though it may have passed the service test. Assuming your car is within the 3 year warrantee perhaps they would just as well let it go if it were borderline and then its on you to replace in a year or so.
  15. Jeff3545
    Jeff3545 Karting
    Sep 4, 2018
    113
    Jeff Nolan
    2019 model year. I bought extended warranty that takes me through the end of 2023 so I’ll ride it out.
    Solid State likes this.
  16. Solid State
    10,508
    Great. Be advised that the two year re-up goes quickly so don't pass-up a chance to get things sorted as soon as they come up. I'm thinking based on your history you are going to need a new battery in that time frame. I think the newer MYs don't do oil and filter changes annually and are based on an algorithm.
  17. Frank_C
    Frank_C F1 Rookie
    2,999
    Whistling through the wheat field in Texas
    Frank
    #17 Frank_C, Jan 18, 2022
    Happened to me today. I had to move my car out of the garage for a remodel. Damn if I forgot to plug it in a couple of weeks ago................
    Fortunately I did not have to jump it. The 812 started time/sequence-wise as normal on the first try. But by the starter sound I could tell the battery was clearly weak. I had just about every imaginary warning light go off- shocks, manettino, parking brake, etc.
    I called & service guy told me that is not unexpected (as noted) and that the warning lights will/should all reset once the battery is fully charged. Now he did ask if I jumped it, so maybe a threshold is there for hard resets. IIRC I had to do one with my F12 but I've drank and slept since then.
    Regardless, he also told me to drive it for an hour as the alternator is weak and will not charge as well at idle. Then plug it in and all will be well again.
    I drove it for an hour. Parked it outside without the tender for another hour or so and then when I restarted it, 'twas as if nothing had ever happened- no warning lights, back to normal.
    FYI the engine load dropped the voltage by nearly 1 volt- in the 13.3-5(ish)V as I was accelerating which jumped to 14.3(ish)V when I took my foot off the loud pedal. Now I did take him to heart and was cruising in the 110-120 mph (141 max) range so YMMV.
    I just love that car...
  18. Jeff3545
    Jeff3545 Karting
    Sep 4, 2018
    113
    Jeff Nolan
    Resolution: RH vertical body accelerometer failed. Tech probed the pins and found pin 2 (signal) shorting. Replaced sensor with the LH sensor and the error message moved to the LH side. Battery and charging system checked out with no issues.
  19. sunghyun7
    Oct 7, 2019
    256
    wow. well I'm glad you got it sorted! I gotta say this is where standard car knowledge just sorta fails. is that the one that's attached to the suspension arm via the short metal connector or the one that's hard mounted to the body? I was always curious what the hard mounted body connector was for.
  20. Jeff3545
    Jeff3545 Karting
    Sep 4, 2018
    113
    Jeff Nolan
    yeah, attached to the body. I believe the other one is the lateral acceleration sensor.
    sunghyun7 likes this.
  21. rjwheels
    rjwheels Rookie
    Oct 24, 2021
    42
    London UK
    Looking like a common fault....exact same problem with my 812SF, in the last week.
    "Suspension control system failure" warning on the display that refused to clear, so car into workshop.
    Fault traced to RH accelerometer, confirmed by "swap" to LH, so replaced.
  22. MaranelloAllTheWay
    Apr 30, 2023
    239
    Whats the cost?
  23. rjwheels
    rjwheels Rookie
    Oct 24, 2021
    42
    London UK
    Cost was £958 including £175 for the part.... and not covered by Power15 warranty.
  24. MaranelloAllTheWay
    Apr 30, 2023
    239
    What exactly does the $7000 annual warranty cover if not for something like this? Catastrophic engine/transmission failure only?
  25. rjwheels
    rjwheels Rookie
    Oct 24, 2021
    42
    London UK
    "Power 15" cover is typically provided with Ferrari pre-owned sales vehicles over 4 years old in UK. So my 2019 812 SF only has the Power15 cover, as it was over 4 years old when I purchased it last year.....my 3rd 812 so far.
    As such, the Power 15 cover is not as comprehensive as the "Extended Factory Warranty" which, I understand, can only be purchased prior to the vehicle hitting 4th birthday (in UK).
    The Power 15 costs less than the extended factory warranty, as it only covers certain major components in various categories and my experience to date with solenoid cover plate, parking sensors and this accelerometer...are not covered.
    I believe with the Extended Factory Warranty you will find most things are covered, as per original Factory Warranty, so hopefully no worry....
