Synthetic Oil in engine, transmission and differential | FerrariChat
Discussion in '308/328' started by jcollingridge, Sep 8, 2006.
  1. jcollingridge
    jcollingridge Karting
    Sep 8, 2006
    70
    Kamloops,B.C.,Canada
    Jim Collingridge
    What experience has the list has in using synthetic oil in the '78 308 GTS carb
    engine, transmission and differential? On the advise of a Mercedes specialist I put Mobile1 Synthetic ATF in my 240D (manual) transmission. The result was much smoother shifting. I have run this oil in the trans. for two seasons now with excellent results. Is it possible that Mobil1 Synthetic ATF would improve the shifting in my 308 GTS without any adverse effects? I have used Mobile1 Synthetic 15/50 in the Mercedes 300TD engine which dramatically improved the cold weather starting. Unfortunately Mobile1 15/50 is not being supplied anymore in the Pacific Northwest so I will likely have to go to 5/50 in the future or Mobile1 5000 unless you have another recommendation. Jim
  2. Shark49
    Shark49 Formula Junior
    Mar 31, 2005
    773
    Boone, NC
    Nathan
  3. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    It seems that I've read quite often that the synthetic transmission fluids are just too slippery (sp?) for the 308 gearbox. Redline 75w90-NS (for "Non-Synthetic") is a commonly used fluid with excellent results. My car currently has Swepco gearbox oil in it, which I believe is available at the dealer. FWIW, I'll be using the Redline stuff at my next change.
    Aaron
  4. Llenroc
    Llenroc F1 Veteran Rossa Subscribed
    Jun 9, 2004
    5,499
    Colorado
    Vern
    NS doesn't mean non synthetic it is Redlines discription for their "non limited slip" product. All of redline products are synthectic. In some Ferrari gear boxes if you use NS formula you may have to add a small amount friction additive. In my 355 I have used both NS formula and the reg. 70-90w they both work fine. In my 348(which has the worst shifting Ferrari gearbox) I used the NS formula with a little GM limited slip additive(the amount seems to vary by car). In my 308s either one seemed to work ok but, I think I would err on the side of using the NS formula and if needed some additive. I also have used Redlines MTL formula in my 308s too and it worked fine. Redline by far is the best gearbox oil to use, I have tried about everything over the last 30 years in Ferraris and other cars I've owned it always seems to equal the best shifting. Regards, Vern
  5. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Thank you for the correction! Just goes to show ya' what "assuming" something does.... :p
  6. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Color me the underdog, have had very good results in the tracked 308QV using Amsoil SVG 70-90 synth. For the record, AM NOT a lame Amsoil head, as i prefer Mobil 1 synth for engine oil. The Amsoil SVG is for 'severe' use and need not any slip additive.
    And shifting is like butter... and second gear is good when cold if a small, tiny bit notchy but once the car is a touch warm (5 miles) second gear is also like butter. NOTE: track the car 25+ times a year so weak oils/fluids ARE NOT in my vocabulary.
  7. nathandarby67
    nathandarby67 F1 Veteran Owner
    Feb 1, 2005
    8,349
    Mississippi
    Nathan
    What symptoms should you look for to tell if you need to add any of the friction additive?
  8. John Harry
    John Harry Formula Junior
    Sep 8, 2005
    328
    Pittsburgh PA
    John Harry
    I had the same question. Do you listen for a grinding/snapping noise from the diff, or what? And, just ballpark, how much would "a little" additive be?
